My Fisher and Paykel Ecosmart topload washer is not emptying or spinning out. I have tried running it back through the whole cycle but it quits at the draining point and starts beeping. Thanks
    Problem Solver:
  • 5 Answers
There is a service summary with error codes under the control panel in a zip lock bag. My pump was being blocked by a bobby pin. removing the basket allowed access to the pump and I was able to clean out the suction. I was amazed by the scum build up under the basket. I will now remove the basket yearly to clean under it.
Posted on Jun 02, 2010
How do I see what is causing my Fisher & Paykel EcoSmart washer to leak water?
If it is leaking when draining this would point to the main seal of the WATER PUMP. (Quite common for older machines.)
The pump can be easily removed by leaning the machine backwards, remove wires and see picture. NOTE: about half a litre of water will gush out so it is best to take machine outdoors. Go to a recycling centre or online auction for a replacement. They can be fiddly to replace.
Jul 20, 2014 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
After washing my fisher paykel toploading washer will not empty out
possible a blocked pump , it shud beep , come up with a code read the 8 lights on the top
Jan 25, 2010 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
Sep 09, 2009 | Fisher Paykel EcoSmart GWL15
I have a 1.5 yr old Fisher Paykel ecosmart washing machine. During the past 2 loads there has been a notable water leak (significant puddling on the floor). I haven't witnessed the problem, but there is...
the play in the tub in normal, it sounds like you have an over sudsing issue, run an empty load with 3 cups of vinager in the tub, set the water temp to hot, cut way down on soap, if you use liquid dont even fill the cup 1/3 of the way, I know this sounds dumb but try it, I have one and this happened to me
Jul 10, 2009 | Fisher and Paykel Washing Machines
I am getting grey marks on my light colored clothing. I have a Fisher & Paykel topload washer.
THE PROBLEM IS THE AMOUNT OF DETERGENT YOU ARE USING.YOU NEED TO BE USING HE OR HIGH EFFECIENT DETERGENT. THIS MACHINE USES MUCH LESS WATER THAN YOUR VERAGE TOP LOADER.
Apr 07, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel clicking sound
it sounds like the bearings are going out as it spins faster the noise quietens down because the bearings are more spread out and as it slows they fall lower leaving an area that it causing "friction" of a kind
Dec 27, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel Washer leaking water
call fisher paykel they will take care of you chances are the diverter valve is bad they have been having problems with them and make sure your repair people are fisher paykel certified VERY IMPORTANT
Dec 18, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
112 people viewed this question
Top Washing Machines Experts
