THERMOSTAT DANFOSS MODEL repd-phc2 SERVICE MANUAL REQUIRED DOES NOT STORE THE SETPOINT DURING THE POWER SUPPLY INTRUPTS AND RESTORES
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: User manual for Danfoss Tp5
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Posted on Dec 16, 2010
How do I rewire the thermostat on a delfield uc4048h model with an after market thermostat
buy the right one, DANFOSS CONTROL KIT
parts and service manual, http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/DEL-4SERIES_spm.pdf
replacement parts,http://www.partstown.com/is-bin/INTERSHOP.enfinity/WFS/Reedy-PartsTown-Site/en_US/-/USD/ViewEasyAskSearch-Start?Action=CA_AttributeSelected&Question=Model=%27UC4048%27&CategoryPath=All%20Products%2F%2F%2F%2FAttribSelect%3DManufacturer%3D%27Delfield%27&CatalogCategoryID=
Apr 14, 2015 | Delfield Freezers
How do i adjust AC temperature variance on a Honeywell TH5220D1003 thermostat
If you are talking about the difference between heating mode and cooling mode and the room setpoint, you can not change it. It comes from the factory with a 3 degree difference. In other words if you raise the heat setpoint until it is within 3 degrees of the cooling setpoint, for every degree you raise the heat setpoint the cooling will raise a degree.
About all you can do is increase the distance between the heat and cooling setpoint. To do this either lower the cooling setpoint to 3 degrees higher than the heat setpoint you want and then increase the cooling setpoint the desired setting. For example heat and cool setpoints are 67 and 70 respectively, and you want 65 and 73. Lower the cooling setpoint to 68 and then raise the cooling setpoint to 73. Now your heating will come on 3 degress lower than 68, the 65 you wanted and cooling will come on at 73. Remember, the thermostat new setpoints will turn on the cooling at 75 and turn back off at 73 and heat will turn on at 63 and turn off at 65.
You can perform the same using the heating setpoint, just have to look at it backwards. If you need to lower the difference I recommend a 8000 series thermostat. They are the most functional thermostat that Honeywell makes, be in mind they are about 3 times more expensive and many of the setting require a well trained tech to interpret and set properly.
Hope this helps.
Aug 24, 2014 | Honeywell Th5220d1003 Non-programmable...
Can you replace a danfoss TP9 with a honeywell ST699
I believe the TP9 is a programmable thermostat.
While it appears the ST699 is a timer that connects to a thermostat.
So yes, they both control 230Volt boiler-and-pump. But there are differences.
Google search each item and include .pdf in search parameter to find product manual for each, and then compare wiring differences.
Nov 19, 2012 | Honeywell Hardware & Accessories
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Wire colours to numbers on thermostat
GOTO DANFOSS .COM AND THEY HAVE HOW TOS ON EVERYTHING WITH A CUSTOMER SERVICE CONTACT GOOD LUCK HOPE THIS HELPS.
Jan 22, 2010 | Heating & Cooling
Danfoss TP5 programming manual required
This is the full manual:
http://danfoss-randall.co.uk/PCMPDF/6218.pdf
Very well hidden away on the Danfoss website!
Oct 29, 2009 | Honeywell Electronic Programmable...
OMS 160 Require oil seal no for this
Do you have the complete model code? Some of the seals are not the same from series to series.
Oct 15, 2009 | Danfoss Sundstrand-sauer-danfoss...
I need a Manual for a Sundstrand series 15 pump
I just found this free PDF. It is sundstrancd series 15 service manual. It certainly did not answer all my questions but its a good step forward.
www.cushmantrackster.com/pay-pdfs/sundstrand.pdf
Oct 10, 2009 | Danfoss Sundstrand-sauer-danfoss...
Temp shows 2 degrees warmer than what is was set to
sometimes the furnace does a better job than anticipated, i wouldn't worry about it, especially if the furnace shuts off.
the setpoint is the temperature you want it to be
cycle lenghts are determined by how much recovery you are requesting. for instance, in the morning when you wake up, you want the temperature to be at its setpoint. what the thermostat will do is make the furnace run a limited lengths during the recovery process.
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
