Question about kawasaki Full Suspension Mountain Bike Men
When my jet ski is wide open its missing every so often and loosing about 15mph before it picks back up
    President:
  • 1,978 Answers
BOAT#1: I experienced the same thing when I had a mouse nest in my water box. When ever you turned left the nest would plug the exhaust and cause an RPM drop till the boat slowed down. BOAT#2: Another thing that can cause intermittent running is moisture in the electronics box. If the box has water in it, open it up overnight to let it dry out, then reseal it and it should run normally again. BOAT#3: The third thing that has caused the same issue you described, was dirty carburetors (SS XI) from bad gas and improper storage. This was made worse because there were also bad spark plug caps on the machine. Hope one of these solutions fixes your problem.
Posted on Sep 06, 2010
Have 2000 kawi ultra 150 jet ski died while driving now will barely turn over was running just fine before
Hey Adam, First thing I would do is run a compression check on each cylinder... you need a minimum of 120psi and no difference between of more than 10psi..run the test with the throttle wide open and turn the engine over for 5-8 seconds.. after you do this, reply back to me on here.. we'll go from there..thanks..,, if it fails this test.. you have found your problem... take it to a qualified professional...
Jul 12, 2017 | Jet Boating
1990 ski doo mach 1
You have dirt in the carburetor jets and or passages, clean the fuel tank and rebuild the carb.
Dec 20, 2016 | Winter Sports
Jet ski is "hard stopping"
Any motor that runs and then develops sudden stopping symptoms gives me suspicions of fuel delivery problems.
I'm not familiar with your machine, but I would be looking at the fuel filter as probably plugged up.
Wild guess, but sometimes I luck out.
Cheerfuls.
Sep 06, 2015 | Cars & Trucks
Jet ski troubleshooting
kawasaki ultra 260's are only cooled by lake or sea water so if the water supply gets blocked then it will overheat ! did it definatly overheat or just loose power because the superchargers do sieze up due to damp air or the pully bearing , also the dipsticks on them sometimes shear off and lock the cogs ! does the engine still run up on a hose pipe ? also has the ski been left a long time not used without fogging the valves in the head ? this is my job so get back to me ( 30 yrs ) ..
Dec 28, 2013 | kawasaki 2010 Jet Ski Ultra 260X
Bad stator on ski doo. how do i change it?
wot model is it , 2 or 4 stroke engine ? let me know as i am a marine engineer for 29 yrs and have worked on jet skis , outboards , inboards of all makes !!! P...
Oct 24, 2013 | Motorcycles
Help!! '97 Seadoo GTI, just had the carburetor rebuild, replaced the Rectifier Regulator, replaced the spark plugs and recharged the battery. But the jet ski would only reach 40mph and it would bog down to...
Sounds like you might have the rotary valve in the wrong position. Also you are going to need to replace your fuel lines and check the fuel petcock for any blockage. Lastly, when u rebuilt this carb did you check the tiny fuel filter behind the pump body?
Sep 23, 2013 | Sea-Doo US Boating
How to maintain my jet ski?
If you plan to store a jet ski in a garage, you will need to make sure it is dry and cool and with limited exposure to the sun. In general, you need to do what you can to prevent rust and other grime that eventually may cause mechanical issues.
Washing your jet ski is also needed after every use. You can use your car wash products. I also suggest to read the user's manual, it may include tips about maintaining your jet ski.
You can protect the engine with a special spray and water repellant.
If you plan to store your jet ski for a while, it is preferred that you will disconnect the battery.
Jan 17, 2013 | Boating
My 1994 kawasaki 750 ss jet ski will only go half speed when I have the throttle wide open?
Is it bogging down, or just stops revving at the point...first check the throttle cable, twist it wide open and make sure it's opening all the way...after awhile they tend to stretch and that won't allow you full power....i hope this helps.
Aug 29, 2011 | 1989 kawasaki GTR 1000
How do you replace a starter on a 2003 kawasaki 1100 jet ski
You will have to unbolt and move the electronic box, unbolt and remove the upper exhaust manifold, and the expansion chamber . This should give you access to the starter underneath.
Jun 01, 2010 | Encore Software Kawasaki Jet Ski...
Need to know what holds the gears in place where the starter turns the flywheel on a 1997 kawaski sts jet ski
You can look up part numbers and study parts diagrams at Kawasaki.com. By comparing the pictures to what you have you can see if you are missing anything.
Sep 10, 2009 | Jet 1 Watersport Ski Kayak Goggles They...
kawasaki Full Suspension Mountain Bike Men Logo
200 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
