Question about Cuisinart CB-600 Blender
The blender smells like something is burning. It gets overworked fast.
Clicking sound plus smell of motor and overheating on 2 with dough hook for bread. i am making 2 large loaves at a time.
Sounds to me like you are overworking the machine. Get some advise from Kitchen Aid themselves, find a helpline and phone it.
Sep 16, 2015 | KitchenAid Professional 600 6 Qt. Stand...
I have a breville kinetic blender - not used for a while. Gives a nasty burning smell when used. Anything I can do?
Unless it is food stuck around the blender bottom , you have parts burning up inside. Its not safe to use. Check to make sure it is clean top an bottom if smell returns stop using. Could burn house down.
Jan 29, 2015 | Breville Blenders
Blender is spinning but not crushing ice and smoke coming out of bottom
Smoke sounds like the motor is burned out, or possibly just overworked. You could let it rest for 15 minutes and try again, but be careful, as the insulation on the wires could have melted.
Smoke in appliances is usually a bad sign!
Nov 17, 2014 | Blenders
Waring 34BL87 blender is loud and gives off a strong burning smell whenever used. Burning smell apparent since first day of use and getting worse with age. Is this odor normal or does it indicate the...
no, that is not normal. it could be from a loose or misallignment rotor or shafting. if its under warranty you should return it from the store...
Jun 17, 2011 | Waring TG15 Blender
The blender stopped working
the motor is burnt. replace with the same motor or have it rewound.
Aug 24, 2009 | Kenmore Blender Single-Speed Blender
Blender died while in use n hasnt worked ever since
As long as you know the plug still had power. Make sure it wasn't a GFI that was tripped. Something inside the unit must have either lost contact or burned up. Did you smell anything burning electrically?
Aug 03, 2009 | Black & Decker Blenders
Blender turns off
I work for Black & Decker appliances and have more than 10 years experience with small appliances.
Anytime you smell something burning while using an appliance that isn't suppose to heat food, something is wrong. You shouldn't smell any foul odors emanating from a blender. The fact that it shuts off while pureeing something as simple as oatmeal indicates that particular blender is defective.
If you contact the manufacture they will be able to inform you as to your warranty eligibility.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jun 18, 2009 | Vitamix 5000 Work Top Blender
Burning smell when used
No need to oil it. The carbon brush maybe sparking already it is located inside the motor. It is due to damaged Armature or overloaded motor.
May 25, 2009 | Waring BB160 2 Speed Blender
Waring blender - model 51bl25
My Waring 51BL16 is having difficulty blending and some mechanism on the inside keeps spinning once the blender has been turned off...any ideas?
Mar 15, 2009 | Waring PBB 201 / 204 / 209 / 212...
Burning smell
That burning smell was possibly the motor windings burning out. If the windings have burned the blender will need to be replaced. Hope this has helped you today,.......... Sea Breeze
Please let me know if this answered you question.
Feb 01, 2009 | Hamilton Beach 52250 BlendMaster Ultra...
Cuisinart CB-600 Blender Logo
465 people viewed this question
Top Cuisinart Blenders Experts
eyecam
ray gallant
richie46
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
