Question about Skull Candy Skullcrushers Headphones
Skullcrusher Bass not working.
My Skullcrushers Bass isn't working becouse the wires are revealed and broken right nex to the bass control part. How do i fix?
  • Skull Candy Master
  • 5,487 Answers
You might want to check out my tip on replacing dodgy cable/plugs on headphones.
Posted on May 14, 2010
What is wrong? my active bass whether i put a new battery in or not sounds passive no change whatsoever. quite a bit of the low end is severely missing. Schecter STARGAZER 5 bass.
That bass combines passive EMG pickups with an active preamp (which provides the bass and treble controls). Sounds like you are never getting the preamp to work, and if that is the case there could be numerous reasons...a dead battery...jack wiring that is broken (meaning the battery ground wire is not attached or is grounding out)...likely should see a tech, but that is a good sounding bass when working correctly.
Feb 07, 2013 | Schecter STARGAZER 5 Bass
The bass vibration suddenly stopped working I changed the battery turned the music up loud and still mo vibration. I constantly have the bass on Max, and if that is the problem then skullcandy should not...
Sounds like you blew out the sub-woofer in the headphones. You could replace them, or if you've only had them for a year (or less) you can use the warranty included and have them fix it. All you have to do is call them up and ship the headphones to them.
Their contact page is listed below:
http://www.skullcandy.com/contact-us.html
May 17, 2011 | Skull Candy Skullcandy Skullcrushers...
The bass is very distorted and i replaced the battery but still the bass is very distorted and i can not hear the words of any song i listen to. whats wrong with it??
you may have blown a speaker. check the wires behind the speaker to see if there is a short(two or more bare wires that touch)
Mar 10, 2011 | Skull Candy Skullcrushers Headset
Whenever I turn up the bass I hear a clicking noise. It gets really annoying when I try to listen to high bass music. How do I fix this?
Same thing with me, got scared and thought they were broken, but all mine needed were battery replacements in the subwoofer part :) hope it works!!!
Mar 06, 2011 | Skull Candy Skullcrushers Headphones
The bass in the headset stopped working. but when i wiggle the wire on the earphone part it works
i had that , it gets worse. the poor design of the amp location means the wires fray inside the portals of the amp case. eventualy they will al sever and you will loose sound altogether. i dont know what kind of warrenty your under but i stripped the wires and solderd them back together and to solve the problem of them fraying again, i duct taped the amp to the headphones.
Apr 06, 2010 | Skull Candy Skullcrushers Headset
Bass speaker buzzing
I've had this problem too multiple times. Usually when it happens, the battery dies soon after, and once I replace the battery, the buzzing goes away. If you are having the same problem as me, try putting a fresh battery in :)
Mar 09, 2010 | Skull Candy Skullcrushers Headset
Only the right side of the headphone works and the left turns on and off when the bass amp moves around.
yea i have the exactly same problem exept on my left??? did u find a way to fix them? i open'd them up and all the four wires were welded to the appropriate port. i think its in the wiring.... :( this is just very sad stuff with such beautiful head phones
Jan 27, 2010 | Skull Candy Skullcrushers Headset
Bass amplifier doesn't work even when i switched the batteries.
The bass unit must be defective. Talk to the guys at Skullcandy for a replacement (they offer lifetime warranties for stuff like this).
Their website has a link directly to the warranty page as well: www.skullcandy.com/warranty
Hope this helps
Apr 14, 2009 | Skull Candy Skullcrushers Headset
Everything else works on the drum set besides the bass drum pedal
i had the same problem but when i hit the set as hard as i could the bass worked without using the pedal. there was a wire on the inside that was probly disconected, i took it back and got the warenty,
if you have the recept try asking if you can return it for a new one becouse it has problemes on the inside of the dumb set, i also knew it wasent the pedal tho becouse i had bought a new one at bestbuy. i took it back and got a new set and it works perfect no matter how hard i hit it
Mar 26, 2009 | MTV Games Rock Band Bundle for Xbox 360
Skull Candy Skullcrushers Headphones Logo
1,162 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Joe Lamb
Joe Lamb
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
