Question about Sony RDR-HX825 DVD Recorder/HDD Recorder
Disk Tray I have Sony RDR HX710 dvd Recorder. Does anybody know ho to open disk tray without having power on? Hello, Very often, I can't open the tray of my Sony RDR-HX825; I have to do the way it's written in the manual, : (unplung the cord, then replug it while depressing the eject button !!!) but it takes a long time; it does'nt work each time, and more, after that the Error message C31:00 is displayed on the screen. I can't ask my wife or children to follow this process in order to read a DVD. I will be glad to know how it's possible to resolve this issue. Regards mouspi
  • mouspi Mar 29, 2008
    Thank you Hollyecho, but there isn't a tiny hole under the tray on the front side; I saw on the net that you have to take off the cover of the RDR to reach this hole !!!
    Regards
    Mouspi
  • 818 Answers
  1. Ensure the child lock feature is disabled.
  2. IMPORTANT: If necessary, consult the instruction manual for specific steps about how to disable the child lock feature.
  3. Attempt to open the disc tray.
  4. If the issue is not resolved, turn off the DVD player.
  5. Unplug the power cord from the electrical outlet for 30 seconds.
  6. Plug the power cord back into the electrical outlet.
  7. Attempt to open the disc tray.
  8. If the disc tray still does not open, simultaneously press the POWER+STOP+EJECT buttons; this will sometimes cause the disc tray to open.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
see this
Sergio
Posted on Mar 29, 2008
  • 3,037 Answers
There should be a small hole around the tray that you can stick a paper clip into to open the tray. The error on the other hand would be a cleaning error problem I believe and you can try cleaning the laser with either a soft cloth or a dvd cleaner. good luck with this
  • Benjamin Patri
    Benjamin Patri Mar 29, 2008
    you can try contacting sony about this problem at 800-488-7669.
    Unfortunately the only other way to open the tray is by opening the casing and turning the gears to release the tray
    Genius:
  • 3,422 Answers
See if there is a little pin hole in the face plate or bezel of your dvd player... stick a paper clip in it and it will release your DVD tray and you can get your DVD out.
Goodluck,
Please don't forget to rate the solution.
    Sergeant:
  • 313 Answers
Using a straighted paper clip *I use a pretty cake tester* - insert it in the tiny small hole just under the tray. When you push, it will manually push the tray open.
Good Luck.
Sony RDR-GX315 DVD Recorder. Error message: "The disk can be neither played nor recorded"
Which blank media do you have?
Check out CDFREAKS.com forum
Does your burner prefer + or- disks?
Try a slower burn speed
Try a different blank media.
Don't buy the cheapest disks
I have good results with Verbatum, Taiyo Yunden (Fuji)
Oct 23, 2017 | Sony RDR-GX315 DVD Recorder
SONY RDR-VX500 DVD eject not working
On most DVDs there is a small hole under the tray where you can insert a straightened paperclip, push in and it will manually open the tray. If not if you can try GENTLY prising the tray open by inserting screwdrivers on both sides of the tray with the power off
Oct 04, 2009 | Sony RDR-VX500 DVD Recorder/VCR
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Cannot open dvd tray as it is locked
    DVD must be stuck in it. And it needs mechanical adjustment. Contact any expert nearby to you.
Thanks for using FIXYA!
Apr 26, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Dvd tray won't open
unplug the power to reset it.
Jul 07, 2008 | Televison & Video
Rubber band lose
It connects on from the big circle to the little circle. The little circle might be under the tray but you might be able to get it on with some tweezers.
Feb 22, 2008 | Sony RDR-GX315 DVD Recorder
Disk Tray
Here is the solution. __Regards,__Arpi
Mar 22, 2007 | Sony (RDR-HX710) DVD±RW Dual Layer...
Sony RDR HX710
Why? Something wrong with your machine? if that is the case, why not unplug and just open the side screws and remove the Disks
Mar 22, 2007 | Panasonic CT-20G13 20" TV
Sony RDR-HX825 DVD Recorder/HDD Recorder Logo
493 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
