Question about Northstar 951XD GPS Receiver
Incorect location/ speed 256 knt when sitting at slip
  • tim marks May 14, 2010
    does not give correct location reads 257 knts when not moving goes from fix to tracking . some times itdoes give corect location
    how do u reset no owners man
    President:
  • 1,469 Answers
Hello, it depends on what is wrong with the receiver. Please can you really explain what is really wrong with the receiver?
Posted on May 14, 2010
  • Egwe Emmanuel Onyedikachi
    Hi, have you tried resetting it?, because is like it is about malfunctioning.
    Try and reset it first. And after resetting it, Tell me what happened you i can tell you what to do next.
    Take care.
  • 713 Answers
Hi,please clearly describe your problem,so you can be given a conprehensive solution to solve your problem.
Thanks and take care
Posted on May 13, 2010
Hoe wiellagers achterwiel vervangen
Hallo , Mathkrist voor dit scenario knt u uw dienst / eigenaren manual nodig hebt als je de eerste en de beste tool die je ooit gekocht voor uw Yamaha , wanhoop niet kan niet vinden , voor een luttele $ 0 knt u een ander downloaden. Voor meer informatie over uw probleem en waardevol "FREE" downloads die je nodig hebt , klik dan op de onderstaande links . Veel succes en een mooie dag verder . Yamaha Star 650 Rear Wheel Removal
http://www.xj4ever.com/wheel%20bearing%20replacement.pdf
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Apr 12, 2013 | 1985 Yamaha XJ 700 X Maxim
HOW TO LOG OUT 2GO ACCOUNT ON MOBILE
2go team, nw ma acount wl b invadd kux i used sm1 elsex fone knt logout.pls create a way of logging out
Sep 22, 2011 | Cell Phones
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Engine code PO732
P0732 means problem in yours automatic transmition gearbox. Gear 2 incorect ratio.The problem can be as follow: TR sensor/solenoid switch or shift solenoid . Can be also mechanical problem.
Apr 19, 2010 | 2003 Volkswagen New Beetle Convertible
1999 Kawasaki 1500 Vulcan Drifter clutch slips
Well i would say the clutches have sat dry to long. You may change the oil and it solve the problem but more than likely new clutch discs.
Jan 25, 2010 | 2005 Yamaha Xv 250 Virago S
Hi, I wish to upgrade my Ram speed from 256
Hi friend,
You can use more then 2GB Ram in your motherboard. it should be DDR-1 Ram .....you can change..
Dec 28, 2009 | Intel Motherboard
Would like to convert Japanese to English Car GPS KNT 5175
塚田さん、
恐れ入りますが、支払いの件確認の上、速やかにお願いします。
谷岡
Apr 05, 2009 | Car Audio & Video
Where is the speed sensor located for my 96 caprice?
Your car has the 4L60E trans,and the speed sensor is located in the tailshaft of the trans.The tailshaft is located on the rear of the trans,and is held onto the trans with 4,15mm bolts.The driveshaft slips into the tailshaft.The speed sensor will have at least 2 wires going to it.The speed sensor will be located either on the driverside or passenger side of the trans.95 was a transitional year,so the speed sensor could have been mounted on either side.Good luck
Aug 10, 2008 | 1995 Chevrolet Caprice
I have put a sempron 3.4 processor in but the system only recognises it as 2ghz ?
Your processor speed is actually correct AMD calculate the clock speeds differently from Pentium type processors, a 3400+ is a 2.0 GHZ processor, see the list below for speeds Sempron 2500+ 1.40 GHz 800 MHz 128 KB 754 Sempron 2600+ 1.60 GHz 800 MHz 128 KB 754 Sempron 2800+ 1.60 GHz 800 MHz 256 KB 754 Sempron 3000+ 1.80GHz 800 MHz 128 KB 754 Sempron 3100+ 1.80 GHz 800 MHz 256 KB 754 Sempron 3300+ 2 GHz 800 MHz 256 KB 754 Sempron 3400+ 2 GHz 800 MHz 256 KB 754 Don't worry too much about the proceesor not being recognised as long as you know it is running at the correct speed.
Nov 12, 2006 | Iwill ZPC-SP (ZPCSP) Barebone
Northstar 951XD GPS Receiver Logo
Top Northstar GPS Experts
Jose Ma DM.
Jose Ma DM.
Are you a Northstar GPS Expert? Answer questions, earn points and help others
