Question about Hayward SAND FILTER, PRO SERIES
Hyward Variflow valve lets water drain when in filter posi
When I backwash, rinse or set the valve to drain water from the pool then return it to filter, the water continues to flow out of the pool drain exit in the garden. It can be overcome by vigorously rotating the valve handle either side of the filter position a number of times then selecting filter. Is this a fixable problem? If so can a non-expert do it?
Thanks Mike
  • 990 Answers
If you pull the six screws holding the valve top on and open it up. You will see what is called a spider gasket in the bottom of the valve and this is comming loose. If you pull this out and dry the valve. You will have old silicone in the grooves at the bottom. Carefully clean all this out. Take the old one to the store to match it up. Then put a thin layer of silicone on the new one and put in place. Reassemble and let sit for a few hours and you should be good to go.
In the future be shure the pump is off and all the presure is out of the system before you turn the valve. The water inside will resh over the gasket and pull it out of place causing this. So be careful. good luck.
Posted on May 13, 2010
  • 22 Answers
The dude is right, However, you may not have to go to a pool store or get a new gasket. if the conditiion is in fair condition you can remove it lay it on a flat surface. then cover it with a heavy object to flatten it out try to be sure the shape is in the form it needs to be when you put it bback. btw. if your pool equipment is below the water level you may need to close a valve or two to keep pool from draining out while valve is open. you can even just shove paper towels inside the pipe to slow the water flo. the idea is to get the spider gaskett back in the grooves and in place. I have even used plumbers glue to do this while it is wet. just make sure there is no sitcky stuff of the top area of gasket or in valve body of filter valve. you can use alot of lube you may even want to use silicon spray to saturate all areas to help renew the elasticity of the plastic as it is probably from chemicals age and exposure. replace the valve parts like they were before and you may even want to add a ball valve on the part where the discharge comes out. you can just open it when you need to backwash or drain out water. this is a secondary safety device.
Posted on May 14, 2010
What setting do you put it on to drain the pool for plaster repair
There is usually a setting on the handle that says "Drain" but if not you can always use the Backwash setting to get all the water out of the pool or at least most of it.
Rod
US Parts Center
May 12, 2014 | Hayward SAND FILTER, PRO SERIES
How to use backwash to waste
When the filter get clogged the pressure in the filter increases and there is less water flow returning to the pool.
If your filter is a sand filter, when you turn the valve to backwash and turn on the pump it reverses the water flow in the sand filter to flush the dirt out of the filter to waste. Look at the window openning in the waste pipe and keep the backwashing goinging until you see clear water.
Then turn off the pump and move the control valve to Rinse, turn on the pump for a few minutes, this returns the water flow back to normal but the water goes to waste to make sure the sand filter is clean.
Turn off the pump and move the control valve to filter and turn on the pump. This mode is the normal operating mode and the pressure gauge in the sand filter will show a drop in pressure.
Some pressure gauge shows a red section to indicate when backwashing should be carried out.
May 02, 2012 | Hayward Pool & Spa
I need to know what all the settings are like bacwash filter on the valve system
FILTER is the valve position when the system is in the normal filtering mode.
When you backwash the filter you first need to turn off the pump, place in BACKWASH position, and run the motor for 45 seconds (or until the backwash water is clear). Turn off pump and run in the FILTER position for 15 seconds. Repeat twice more.
The RINSE position is to clear any dirt in initial start-up cleaning, plus resetting filter bed after backwashing.
The WASTE
position is for vacuuming directly to waste, lowering pool level, or draining the pool.
The CLOSED position is for shutting off all flow through the valve.
The RECIRCULATE position allows water to flow from the pump through the valve and directly to the pool.
You will probably only to use the FILTER, BACKWASH and maybe the RINSE valve position. The RINSE position is not as important as indicated by the fact that many backwash valves don't have a RINSE position.
I hope this helps.
Sep 05, 2011 | Hayward SAND FILTER, PRO SERIES
Sticker wore off on the filter. which button backwashes? the pool is about to overflow.
b> VALVE SETTING FUNCTIONS OF VALVE POSITIONS FLOW DIRECTION THROUGH VALVE FILTER PUMP - TOP - THROUGH FILTER - BOTTOM - RETURN For normal filtration and vacuuming pool through filter. BACKWASH b> PUMP - BOTTOM - THROUGH FILTER - TOP - WASTE For reversing flow for cleaning filter. RINSE b> PUMP - TOP - THROUGH FILTER - BOTTOM - WASTE For initial start-up cleaning, plus resetting filter bed after backwashing. WASTE b> PUMP - WASTE For vacuuming directly to waste, lowering pool level/draining pool. CLOSED b> NO CIRCULATION PAST PUMP PORT For shutting off all flow to filter and pool. RECIRCULATE b> PUMP - RETURN For bypassing filter, but circulating pool water. May be plumbed for "off-system" pool water access. Ideal for Jet-Air® fittings. WINTER b> VALVE NOT IN USE
Ifthis answer does not fix your problem, please comment with additional detailsprior to rating the answer. Positive feedback is appreciated once your problemis solved! Thank you.
Aug 28, 2011 | Hayward SAND FILTER, PRO SERIES
How to know what cycle to use or when to use filter, backwash or rinse?
during normal operation, your multiport valve should be in the "FILTER" position.
Once the pressure in the filter reaches 10psi more than what it was when the filter was clean, you should backwash. turn the pump off, press down and turn the multiport valve to backwash. turn the pump on and watch the effluent water until it goes from dirty to clean. Then place the multiport valve to the rinse position, this will rinse any remaining dirt from the top of the filter and valves so that it does not return to the pool. Once the water comes out clean, return the valve to the filter position.
Do not turn the valve while the pump is on, always make sure to turn the pump off before servicing any equipment.
Aug 01, 2011 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
What i she sequence when backwashing---Backwash - Rinse - Wash ? I have a Vari Flo
Backwash until water in the sight glass is clear, shut off the pump and change the valve setting to rinse, turn the pump on for a couple seconds and then back off, change the valve setting to filter and return to normal operation. NEVER move the valve handle while the pump is on.
John
May 05, 2011 | Hayward SAND FILTER, PRO SERIES
I was backwashing the pool and put it back to filter and it will not ****. Thanks Rob
After your pool filters on the "backwash" setting, you should move it to the "rinse" setting. With the pump off, set valve to rinse. Start pump and operate for about 1/2 to 1 minute. This ensures that all dirty water from backwashing is rinsed out of the filter to waste, preventing possible return to the pool. Stop pump, set valve to "filter", and start pump for normal filtering. If it still won't start, check for restrictions in the intake and discharge lines.
Oct 06, 2010 | Hayward SAND FILTER, PRO SERIES
No suction from hayward variflow pro series sand filter
Try these tips. I am guessing that one of these is the reason that your pool filter is not working properly. If you try these suggestions and they don't work, let me know and I will trouble shoot with you again.
1. Check skimmer and pump strainer baskets for debris.
2. Check for restrictions in intake and discharge lines.
3. Check for air leak in intake line (indicated by bubbles returning to pool.
4. Backwash your filter.
5. Be sure Vari-Flo valve is set on “Filter” position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
How do i drain my pool with a hayward variflow pump?
To Flush out the filter with the backwash setting. The backwash setting releases trapped particles from the filter back into the swimming pool. You may need to alternate between the rinse and backwash settings until the water runs clear in order to unblock your filtration system and flush out clogs. To Rinse away dislodged items from the backwash setting. The rinse setting flushes clean water through the pipes and carries away any particles or clogs freed during the backwashing. To Drain the pool select waste on the multiport valve. This sends the water directly to the drain rather than back into the swimming pool. Close the filtration equipment and stop the pump with the closed setting. You should only use the closed setting when you turn the pump off. This function allows you to remove the strainer basket, clean the filter tank and perform other swimming pool maintenance on the filtration system.
Aug 08, 2009 | Hayward 1.5 Hp Northstar High Performance...
De filter pressure too high water is cloudy
backwash the filter from main drain until sight glass is clear-this will reduce filter pressure. After backwashing return gate valve to filter position, then filter from main drain only. check water chemistry. add a clarifier to water
Jul 28, 2009 | Pentair 3/4HP Pinnacle High Performance...
Hayward SAND FILTER, PRO SERIES Logo
629 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
