Question about Canon PIXMA MP170 All-In-One InkJet Printer
Replacing cartridges I cannot get my cartidges to fit properly into my canon mp170. They are the correct ones they just wont click into place - aaahhh!
  • Mazza37 May 11, 2008
    I have the instruction leaflet but its no help!
When I first got this printer I was really confused too because they didn't slip in like normal cartridges. You have to push them in with the end furthest from you tilted up, then lift the end closest to you so that its angle changes to a more horizontal position, and it should click.
It's a bit like those off kettles where instead of flicking its switch down to turn it on, you have to lift it up.
Posted on Jun 24, 2008
  • 34 Answers
Try going to the canon website and search for your printer there.
you'll find flash file showing you how to replace your Cartredges
Posted on May 11, 2008
SOURCE:
Cartridges won't move
turn off open cartridge unit and try to pull the whole print head. some units you can move only when off. if too hard then its locked. make sure cartridges are set correctly in place if it has a lid make sure its closed( for printer head not printer)
Mar 25, 2014 | Canon PIXMA Office Equipment & Supplies
E15 keeps flashing and wont let me use printer
issue: ERROR LED: E, 1, 5
Solution: Reseat ink cartridge (MP150 / MP170 / MP450) Reseat Ink Cartridges Reseat (remove reinstall) the ink cartridges if an error appears Removing Ink Cartridges: After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.Press down on the semi-circular tab to release the cartridge and then remove it.Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.nstalling ink cartridges after confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position. Note: After confirming that the scanning unit support is fixed into position, release your hands.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.) Confirm that the ink cartridges are installed properly <1> The ink cartridge is not installed properly.<2> The ink cartridge is installed properly.Fold the scanning unit support and close the scanning unit (printer cover).Wait until the preparatory operation is complete; it takes about one to two minutes
Oct 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I got this message on the display (canon pixma mp170): "check ink u051"The cartridge is completely new and original. What can I do? Thank you in advance.
MP170 can only accept PG40, PG50, Cl41 & CL51 only. Please check the cartridge model correctly. if problem still persist, ask for replacement for the faulty cartridge.
May 19, 2010 | Canon PIXMA MP170 All-In-One InkJet...
My canon mp170 has a yellow alarm light on and it says "check ink u051" i already checked the ink and replaced them with new ones..
Canon INkjet MP170 not recognising cartridges
make sure the contacts are clean! get a new cartridge, and it if does the same thing...its UR printer.
Dec 19, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Canon MP170 printer
I HAD THE SAME PROBLEM WITH THIS SAME PRINTER THE ANSWER IS THE INK OVER FLOW SPONGE IN SIDE THE PRINTER IS MOST LIKELY FULL NEED TO BE CLEANED OUT
Jul 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP170 wiont print with non-canon cardridge
yes you should
Most of the canon printers works only with canon cartredges and the canon company ends the warranty agreement when discovering that.
my advice: use the better quality and the Original ink (Canon Cartredges).
Apr 07, 2008 | Canon PIXMA MP170 All-In-One InkJet...
PIXMA MP170
I got that same message and, in desperation, read the manual. It turns out I had skipped the last step in installing the ink cartridge: "Push up on the cartridge until it clicks into place". When I opened the printer back up and pushed the cartridges up, they did indeed click into place, and the error went away.
Jan 14, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Cannon PIXMA MP170, printing problems
Maybe the USB cable was plugged before the driver has been installed : I noticed this advice in my manual.
Apr 16, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP170 All-In-One InkJet Printer Logo
Clive
Clive
old marine
old marine
Ekse
