Question about Porter Cable 7800 Drywall Sander With Dust Collection
Bearing replacement on 7800
I'm having a hell of a time trying to remove the snap ring, so I can replace the bearing. Went to Lowe's and picked up a pair of Vice-Grip convertible snap ring pliers, and still am unable to remove it! Any tips,advice? Thanks Bill
  • 1,040 Answers
The best way to sand drywall is to use a pole sander (manually). You can pick them up for about $20.
This particular machine tends to leave grooves in the drywall compound if you are not familiar with how to use it.
If you should have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
Hope this helps,
Jim
Posted on Sep 09, 2010
  • Jim Parker
    Jim Parker Sep 13, 2010
    Did this, or would it have help you to solve the problem. Please rate my answer if so.
    Thanks!
    Jim
Replace wheel bearing front awd 2010 ford edge
remove caliper, rotor, caliper bracket, lower ball joint shaft and two strut bolts. remove bearing housing and any snap rings. remove old bearing. replace and repeat in reverse. watch the abs sensor! costly if damaged. This is not for beginners...
Sep 19, 2014 | 2010 Ford Edge
My model MAH5500BWW Neptune does not have a snap ring on the back drum bearing. Is that a problem?
You have the same washer and issue I have it's a compression fit bearing and will require the "tony tool" to remove and install
Jan 04, 2013 | Maytag Washing Machines
I have an older Hilti Te60 i have dissasembled the chuck end but want to replace the bearings. How do i remove the bearings
I assume you are referring to the two roller bearings on the cylinder assy. Without the special jigs this is a tough task. Even tougher to try to explain. Basically the large bevel gear has to be pressed down along with the sleeve on top. This will reveal a snap ring that has to be removed. Everything will slide off to get you to the other bearing which is held on with a snap ring. But this bearing will have to be pressed off.
Oct 08, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
To change the outer main bearing on a t30 - 23405l do you have to take everything apart including taking off the jugs?
Let me give you some info. I guess you are talking about the bearing next to the fly wheel. The crankshaft has to come completely out. the crank can not be removed until you have removed the rods from the crank shaft pin. Most of the time if a bearing goes bad you need to replace the rods and crank shaft pin. I 've never done it but if you can get the rods out of the way the crank will come out. My recommendation would be, remove the fly wheel, remove the inner cooler, remove any small tubing lines, Remove the front frame cover, Remove the 2 bolts holding the crank pin bushing (don't forget to lock wire these bolts back together during assembly), Remove the cylinder, head, piston and rod together as a unit. Don't let the piston come out of the cylinder or move around to much unless replacing the rods. Once you get both LP and HP cylinders, heads etc off you can remove the front bearing cap exposing the bearing and a snap ring. Take a piece of wood or brass and from the crank shaft counter weight side (rod side)knock the crank shaft toward the fly wheel side until the snap ring can be removed. Once the snap ring is removed knock the crankshaft back toward the rod side and continue until out of the bearing races. Then remove the crank. The outer bearing can then be pressed off with the retainer at one time. Remove the sleeve. To remove the large bearing(back bearing) you need to be very careful and cut it off. Don't mess up the crank shaft. I've tried several ways to remove the back bearing but the easiest is cutting it off. To answer your question yes you have to disassemble to change bearings.
Aug 18, 2011 | Ingersoll Rand Air Tools & Compressors
How do i remove the front wheel bearing
I have just finished replacing the RH front wheel bearing on my 2006 F150 Super cab. Time it took was 1-1/2 hours. You will need a freezer to place the new bearing in while you remove the tire and hub.
The hub has a snap ring in the rear which you will need to remove.
Next you will need a HYD press to press out the bad bearing. You may need to find a friend to do this that has access to a press capable of at least 30TON.
It is a must to press out the bearing as square as possible to assure no damage to the hub.
Important step: Clean very well the hub including the snap ring grove clean clean.
Now that the new bearing has been in the freezer for about an hour and fifteen minutes and all the parts are clean you can press in the new bearing, make sure everything is pressing in square (it will require lots of tonnage and possible damage to the bearing or hub can happen.
Ok now that the bearing is pressed in install the clean snap ring and you are done.
Congratulations you just saved $200.00 on an entire assembly from Ford.
Get it in your mind. If it was installed it can be replaced. Don't let anyone tell you that it is not a serviceable part. Think about it if Ford installed it, it can come out and be replaced.
May 15, 2010 | 2006 Ford F-150
How to remove routers for a for bronco 85 302 full sized
Removing rotors.
1. Jack up, put on jack stands and remove tire (obviously)
2. Remove caliper
3. Remove bolts holding locking hub body to hub
4. Remove snap ring from end of axle, Remove hub retainer ring from ID of wheel hub. Use a small screwdriver or pick to start it out of the groove. Remove the hub body
5. Remove the outer bearing lock nut, lock washer and the inner adjusting nut
You need the special socket for this OTC #7158 or similar
6. Remove the outer bearing and then the hub
7. To separate the rotor from the hub, use a soft faced hammer to drive the studs out
8. Turn the hub over and set the new rotor in place. Put the studs back in.
9. I will usually use an air hammer to drive the studs back in. Alternating in a circular pattern. If you don't have access, you can use a large diameter punch or another hammer on the back of the studs.
10. Now would be a good time to repack the bearings and replace the wheel seals. Pull the spindles and check the bearings and seals in the back of them. If they are not rusted, slab some grease on them and put back together.
11. Install the hub and rotor assy, and the outer bearing and bearing adjustment nut.
Apr 25, 2010 | 1985 Ford Bronco
How do you get the rear u-joint out of the drive shaft on 2005 chevy avalanche
It will need to be pressed out.
Universal Joint: Service and Repair
Nylon Injected Ring
Universal Joint Replacement - Nylon Injected Ring
^ Tools Required
- J 9522-3 U Joint Bearing Separator
- J 9522-5 U Joint Bearing Spacer Remover
Disassembly Procedure
Notice: Never clamp propeller shaft tubing in a vise. Clamping could dent or deform the tube causing an imbalance or unsafe condition. Always
clamp on one of the yokes and support the shaft horizontally. Avoid damaging the slip yoke sealing surface. Nicks may damage the bushing or cut
the lip seal.
1. Support the propeller shaft in a line horizontal with the table of a press.
2. Mark the propeller shaft as to which end is the transmission end and which end goes to the rear axle.
3. Place the universal joint so that the lower ear of the yoke is supported on a 30 mm (1 1/8 inch) socket.
4. In order to shear the plastic retaining ring on the bearing cup, place J 9522-3 on the open horizontal bearing cups. Press the lower bearing cup out
of the yoke ear.
5. If you do not completely remove the bearing cup, lift the cross and insert J 9522-5 between the seal and the bearing cup you are removing.
Continue to press the bearing cup out of the yoke.
6. Rotate the propeller shaft. Press the opposite bearing cup out of the yoke.
7. Mark the orientation of the slip yoke to the tube for proper reassembly.
8. Remove the cross from the yoke.
9. Remove the remaining universal joint parts from the yoke. If you are replacing the front universal joint, remove the bearing cups in the slip yoke
in the same manner.
10. Inspect the retaining ring grooves for plastic.
11. Inspect the bearing cup bores in the yoke ears for burrs or imperfections.
12. Clean the remains of the sheared plastic bearing retainers from the grooves in the yoke.
13. The sheared plastic may prevent the bearing cups from pressing into place and thus prevent the bearing retainers from properly seating.
Assembly Procedure
1. Remove the bearing cups from the universal joint.
2. Assemble 1 bearing cup part way into 1 side of the yoke.
3. Turn the yoke ear toward the bottom.
4. Assemble the cross into the yoke so the trunnion seats freely into the bearing cup.
5. With the trunnion seated in the bearing cup, press the bearing cup into the yoke until the bearing cup is flush with the yoke ear.
6. Assemble the opposite bearing cup part way into the yoke ear.
7. Ensure that the trunnions start straight and true into both bearing cups.
8. Press the opposite bearing cup into the yoke ear while working the cross all the time in order to inspect for a free unbinding movement of the
trunnions in the bearing cups.
Important: If there seems to be a hang-up or binding, stop pressing, and inspect the needle bearings for misalignment in the bearing cup.
9. Press the bearing cup into the yoke until the bearing retainer groove clears the inside of the yoke.
10. Assemble the bearing retainer in the retainer groove.
11. Continue pressing until you can snap both retainers into place.
12. If seating the retainer is difficult, spring the yoke slightly with a firm blow from a dead blow hammer.
13. It may be necessary to lubricate the snap ring with a slight amount of chassis grease so the snap ring seats in the bearing cup groove.
External Snap Ring
Universal Joint Replacement - External Snap Ring
^ Tools Required
- J. 9522-3 U-Joint Bearing Separator
- J 9522-5 U-Joint Bearing Spacer Remover
the lip seal.
2. Mark the propeller shaft in order to show which end connects to the transmission and which end goes to the rear axle.
3. Disassemble the snap rings by pinching the ends together with a pair of pliers.
4. If the ring does not readily snap out of the groove in the yoke, tap the end of the cup lightly in order to relieve the pressure from the ring.
5. Place the universal joint so that the lower ear of the yoke is supported on a 30 mm (1-1/8 inch) hex head socket or a 27 mm (1-1/16 inch) socket.
6. Place J 9522-3 on the open horizontal bearing cups. Press the lower bearing cup out of the yoke ear.
7. If you do not completely remove the bearing cup, lift the cross and insert J 9522-5 between the seal and the bearing cup you are removing.
Continue pressing the bearing cup out of the yoke.
8. Rotate the propeller shaft. Press the opposite bearing cup out of the yoke.
9. Mark the orientation of the slip yoke to the tube for proper reassembly.
10. Remove the cross from the yoke.
11. Remove the remaining universal joint parts from the yoke.
12. If you are replacing the front universal joint, remove the bearing cups in the slip yoke in the same manner.
13. Inspect the retaining ring grooves for dirt, corrosion, or pieces of the old ring.
14. Inspect the bearing cup bores for burrs or imperfections.
15. Clean the retaining ring grooves. Corrosion, dirt, rust, or pieces of the old retaining ring may prevent the bearing cups from pressing into place o
Assembly Procedure
2. Assemble 1 bearing cup part way into 1 side of the yoke. Turn the yoke ear toward the bottom.
3. Assemble the cross into the yoke so that the trunnion seats freely into the bearing cup.
4. With the trunnion seated in the bearing cup, press the bearing cup into the yoke until the bearing cup is flush with the yoke ear.
5. Install the opposite bearing cup part way into the yoke ear.
6. Ensure that the trunnions start straight and true into both bearing cups.
7. Press the opposite bearing cup into the yoke ear while working the cross all the time in order to inspect for free unbinding movement of the
Important: If there seems to be a hang up or binding, stop pressing. Inspect the needle bearings for misalignment in the bearing cup.
8. Press the bearing cup into the yoke until the bearing cup retainer groove is visible over the top of the bearing cup.
9. Assemble the bearing retainer in the retainer groove.
10. Continue pressing until both retainers can be snapped into place.
11. If the retainer is difficult to seat, the yoke can be sprung slightly with a firm blow from a dead blow hammer.
12. It may be necessary to lubricate the snap ring with a slight amount of chassis grease so that the snap ring seats in the bearing cup groove.
Oct 30, 2009 | 2005 Chevrolet Avalanche
U-joint changing
1.image
Operation: Most universal joints are held in place with a combination of pressed fit with a snap ring and either a bearing plate, bearing strap or a U-bolt. Advice: Most universal joints have two bearing caps pressed into the driveshaft and use a snap ring either on the inside or outside of the bearing cap to hold it in place. Some manufacturers use injected plastic instead of a snap ring. The injected plastic holds the cap in place under normal conditions but will break free when pressure is applied during the removal process. The replacement universal joint will use a snap ring instead of the injected plastic. The other two bearing caps are usually held in place by either a bearing plate, bearing strap or a U-bolt all of which can be removed with a normal ratchet and socket or wrench. Occasionally you will find all four bearing caps using the press fit method. In these cases two of the bearing caps will be pressed into a flange that unbolts from the differential or a slip yoke that slides off of the transmission tail shaft.
Jun 27, 2009 | 2004 Dodge Ram 1500
Roaring in front end
Bearing is pressed into the knuckle,hub is pressed into bearing.You will need to take knuckle off,remove large snap ring & press out hub,then bearing.Hope this helps
May 03, 2009 | Saturn SL2 Cars & Trucks
Porter Cable 7800 Drywall Sander With Dust Collection Logo
176 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
