WASHING MACHINE CAN'T REMOVE AGITAOR
THERE SEEM TO BE NO SCREWS ON THE TOP OF THE AGITATOR BUT I CAN'T PULL IT OFF EITHER. I HAVE NEVER WORKED 0N A WASHING MACHINE, IS THERE SOME TRICK I NEED TO KNOW SO IT WILL PULL OFF OR IS THERE SOME SCREWS ON TOP I NEED TO FIND CAUSE I CAN'T FIND ANY OR SEE ANY. PLZ HELP
  • HELP ME 0 Mar 29, 2008
    MAKE AND MODEL IS GENERAL ELECTRIC
    MODEL # GJSR2080WOWW
    8 CYCLES,2 SPEED
    HEAVY DUTY SUPER CAPACITY
  • 185 Answers
Make and model please
Posted on Mar 29, 2008
  • Anonymous Mar 29, 2008
    may i ask why do you want to pull it off for
SOURCE:
Cannot remove top agitator from bottom agitator on whirlpool ultimate care 2
Easy once you have removed the agitator put both feet on either sides. In other words hold it down and pull. The factory tabs needs to be broken. If that fails used a long screw driver and try and break off the tabs.
Apr 28, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Whilrpool imerial series washer making strange noise
The agitaor coupling or drive mechanism is stripped. You will have to pull the agitator up out of the machine to find which of the parts need to be replace. Most likely th agitator coupling.
Jan 27, 2010 | Washing Machines
Removing the Agitator from a GE model
THERE IS A PLASTIC CAP ON THE TOP OF THE AGITATOR UNDER THAT IS A NUT REMOVE THESE TWO AND TRY REMOVING THE AGITATOR THIS MAY TAKE SOME EFFORT . THEY HAVE A TENDENCY TO FREEZE TO THE SHAFT OVER THE YEARS
Aug 19, 2009 | GE Washing Machines
We can't remove the agitator
Once you remove the cap on the agitator, remove the bolt and pull straight up on the agitator. It will come off the drive shaft and you can pull it out of the tub.
See the illustration below.
Regards,
Aug 19, 2009 | GE Profile WPRE6100G Top Load Washer
Top part of agitator does not move with bottom of agitaor
Hi, Remove the cap on the agitator and locate the 7/16" bolt. Remove the bolt and the agitator will lift out. Seperate the agitator and replace the dog kit inside the upper half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
The slow weak function of the augar
the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 15, 2009 | Whirlpool LSR6332K Top Load Washer
Kenmore 90 series agitation problem
suppose to not spin unitl the lid is closed( safety reasons) the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 14, 2009 | Whirlpool LSB6200PQ Top Load Washer
Trans will not disengage
either you have something stuck betwwen the two tubs(ie. a sock. ) preventing the tub from free spinning.or there is a clutch mounted on top of the transmission not engaging, as far the agitator not spinning correctly sounds liek the agitaor dawgs are stripped preventing proper agitaing(bottom of agitator works fine but upper portion free spins both ways without resistance?? correct??
Mar 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I remove Kitchenaid Washing machine agitator?
with the palm orhte heel of yuor hand smack the top of agitaor, hte fabric softener cup will release.it doenst seperate to clen any furthetr though reccommnd soaking in hot water to clean out. reach down and pull up the opaque cover from the center of agitatr and there you will fond a 7/16 bolt holding the agitator to the tranny shaft. remove bolt adn PULL up
Mar 10, 2008 | KitchenAid KAWS750L Top Load Washer
Washing Machines Logo
156 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
