Question about A4tech PK-635 Webcam
How to stall my cam , i install but not working property ..?
Almost the image is clockwise and bleard ...?
    President:
  • 1,138 Answers
Refer to this manual to fix troubles arising from using the PK-635 web cam
1. A4TECHPK-635TroubleShootingManual.pdf
Posted on Jun 21, 2010
My web cam not working pls help me to solve this problem.
HEY
FIRST go to the properties of my com puter then select device manager then check the option imaging device and check ur hardware is installed properly or not .If not installed install ur drivers again and restart ur system
wIn Windows Xp
u will get the option at hardare in tab option then select the device manager
if still not working write the next step question
Jun 10, 2011 | Computers & Internet
I bought the Frontech Diamond webcam and installed the CD and the message shows its successfully installed, as its requested i restarted my system. After i open my cam,, the light will ON but in the CAM...
check if your USB cable is properly plugged.
Also try connecting your webcam directly to your PC instead of through a USB hub
if your webcam's image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Other picture quality problems with webcams can be addressed by changing the video capture properties for the webcam. Most programs that can use a webcam will have an option to access the properties of the video source, which will bring up the video capture properties window.
Feb 13, 2011 | Cameras
NISSAN MURANO 2004 I receive an error on my screen Check Engine & after checking at the garage the problem was P0340 what would it be ?? & how to fix ?? when running on the highway the engine...
the P0340 is a camshaft sensor code, the sensor is located in the front (passengers ) side of the engine, there should be two sensor's one for each camshaft, (front of each head) defective cam sensor's can cause the the problems of stalling and hard starting. I am a Nissan certified tech and replaced a good number of cam sensors in the past, they are quit easy to replace, they are attached by one ten millimeter headed bolt (per sensor) remove the bolt then work the sensor clockwise and counter clockwise while pulling out, there is a o ring seal on the sensor and when installing the new one lightly lube o ring before installing, then install sensor and be sure it fully seated against the mounting surface before installing the bolt or you will break the mounting ear of your new sensor. thanks for using fixya
Jan 01, 2011 | 2004 Nissan Murano
When i click on it, it says web cam is not found or not working properly
check the device manager if imaging device is detected
XP: click start > right click my computer> properties > hardware tab > device manager check if theres any imaging device listed if it has an exclamation point uninstall and reinstall the drivers
if you have other devices listed get your drivers disk and install the drivers.
if theres no bang or let say everything was installed properly camera is busted and needs to be replaced
hope this help
Sep 07, 2010 | Acer Aspire 5610-4648 Notebook
The images produces on my web cam are blurr and can't be viewed. if you pass an object infront of it you just see a shadow.
most webcams have a focus ring on the front of them, try adjusting that ring, turn clockwise and counterclockwise to adjust focal point, the other thing may be the brightness setting in the control panel for the camera, open control panel , look for "cameras" locate your webcam icon , then look under properties. There should be settings for contrast.. brightness. color ect.
Aug 28, 2010 | Computers & Internet
THE WEB CAM DOESN'T WORK PROPERTY I NEED TO INTALL
you can complete remove driver of your web cam, run any registry cleaner and install again if you have driver other wise search the right driver on web.
Apr 02, 2010 | Sony VAIO VGN-CR120E Notebook
I installed the driver in xp but i am unable to use my cam..the image wont come and the options wont work
Can i have details about the cam you are referring to?
Like the brand and the model?
Mar 28, 2010 | Computers & Internet
My web cam is working in xp but not getting installed in vista. what do i do?
Dear User,
Install driver software first from your disc of web cam, then restart your pc
then connect web cam, then follow procedure below,
1. Right click on my computer and select properties
2. click on device manager on left panel of system properties.
3. From list click on + sign of image device, right click on camera driver and click on update driver
4. In update select first option, let windows to find update from internet, windows will find
best driver available from PC it self or Internet (make sure ur pc connected to internet).
Hope fully this will resolve problem
Feb 27, 2010 | QPS QSIPBL2 Network Camera
Web cam do not turn on for pavilion dv6910
There are two files needed for the webcam to work. Go to the HP support driver page and look for the driver for the Cyberlink Youcam. You'll have to put the exact model number in a special search box in order to download the youcam software from HP
Sep 18, 2009 | HP Pavilion DV6910US Laptop
Hi, i have problem in my web cam the model unit is a4tech pk-635m, the reason is i download a web cam effect for free then after downloading it works, then when i use my web cam on the next day it didn't...
goto mycomputer,right click select properties,hardare,device manager, right click image & scanners,right click uninstall, goto action menu, select scan for hardware chages.
wait and see... hope it will detect again and work good.
Jul 04, 2009 | Acer Aspire 6920 Notebook PC
A4tech PK-635 Webcam Logo
32 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
