Question about Zanussi WJD1667W Front Load Washer / Dryer
Need to reprogramme after main pcb has been replaced
Pcb burned out,replaced with new main pcb,but will not work until it has been reprogrammed,would be greatful if someone could tell me procedure and code to input on display board,many thanks john
  • 269 Answers
Did you get a configuration code with new pcb if not this is the one for Mod.wjd 1667w ( 1FBCBO7A150789F2 ). You have to enter the diagnostics.
Press the START/PAUSE and SKIP/RESET together keep held then press the on/off button keep hold of the first 2 buttons until the LEDS begin to flash about 4 seconds.Now press FABRICS or TEMPERATURE buttons until LED lights the code relative to the first 16 digits of the configuration code is diplayed.
When SKIP/RESET button is pressed all the digits which make up the configuration are displayed in sequence.
Press the START/PAUSE button to modify the configuration code (digit by digit).
When all 16 digits have been entered, check that the code is correct, then memorize the code by pressing the START/PAUSE and SKIP/RESET at the same time, these buttons should be held down for at least 4 seconds .
Hope that helps.
Posted on May 13, 2010
How do i reprogram my remote?
Sometimes if you press both remote buttons on a transmitter at the same time next to the vehicle for more than 10 seconds it will reprogramme a remote
Oct 05, 2014 | Crime Stopper Vehicle Parts & Accessories
Got the Nikkai JV-TV888D had no problems at all until now...It won't tune - in and just displays 'No Signal' on the screen! Any help will be gratefully received!
Have you checked that the aerial is plugged in? Does it have an external aerial? If so is it plugged in (Socket on rear takes telescopic or external). If external have you tried aerial on another tv?
If your service is digital is it switched to Digital TV? If it's switched to analogue and you're trying to tune in it wont find signals if you're in a digital area. (or to a certain extent vice versa)
May 20, 2014 | Televison & Video
Reprogram computer f350
you need scan tool to reprogram new PCM and keys to PCM before vechicle will start the PCM dont recognize keys.if you used factory scan tool try reprogramm keys again.
Sep 20, 2013 | Ford F-350 Cars & Trucks
Got a Sony Bravia 32 L 4000 3 years ago and worked fine untill now. We have a double image , one partly over the other one. Anything we can do to fix it?
No this is what we call a "convergence" problem, it is due to burned out component(s) on the main pcb board. You either will need to get it repaired or replace it, replacing it will most likely be the best option.
Jan 20, 2012 | Sony KDL32L4000 32 in. LCD HDTV
My 2007 Chevy Equinox AWD LT package, i have to change the whole transmission because its burning the hydrolic oil because the clutches are so bad, so if i changed the transmission it is neccessary to...
are u sure that its the clutches-auto trans arecomplicated--the pump may be bad causing oil to stagnate and burn from overheatin the unit--if u hav trans rebuilt-probly needs reprogram--send ur issue to majicmech@aol.com
Jun 13, 2011 | 2007 Chevrolet Equinox LS New Cars
I have replaced new cartridge in Epson Stylus D120 still printer is not working and shows cartridge empty light on.
I would expect you used a refilled cartridge.
The epson cartridge needs to be reprogrammed to say its full again.
You can get the reprogrammer of ebay very cheaply. you just hold the re programer on the contact pins for a couple of seconds until the light flashes.
Several printer manufactures are now doing this to lock you into their ink cartridges.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Epson Stylus cx7450 All-In-One InkJet...
The light comes on that it is full but will not turn on power. This dehumidifier is not new but did work last winter and is fairly new.
check the main PCB board if has burn connection check fuses if ok if not replace new one on pcb board connect with wire the burn out connection or replace new one.check the resistance of motor & compressor if good using ommeter.
Jan 28, 2011 | Fedders Dehumidifiers
1999 E46 318i car do not want to start. Computer box motherboard is burned where the no 1 plug fits. Can i replace the computer box with a second hand one and is it a question of plug and start or what is...
you can fit a new one from scrapyard but you will need the chip from the key and the transponder to make it work ,a new one in dealers is around a 1000euros and a dealer will not reprogramme a secondhand one for you as they only want to fit a new one (profit) Unless you can find a local auto locksmith who can reprogramme the immobilisor for you but for him to do this you will need the chassis number of the donor vehicle so he can get the 4 figure code to reprogramme the key to the ECU immobilisor .
Jan 24, 2011 | 1999 BMW 318 ti
Err 85 what soes it mean
E85 indicates that the circulation pump is faulty.
You'll need to check the circulation pump, it sits behind the drain pump. If it's obviously burned out you'll need to replace it.
The service manual states, circulation pump, wiring or main pcb as the cause.
In reality, the pump burns out/goes faulty and takes the main PCB with it.
Have a good look at the pump and also the main PCB.
Dec 04, 2010 | Zanussi FJD1266W Front Load Washer
Remote for a 2005 gmc pickup
You shouldn't need to reprogramme it. Check the battery is in correctly. It's worthwhile checking for bent terminals.
Jul 26, 2009 | Sharp RRMCGA342WJSA Remote Control
Zanussi WJD1667W Front Load Washer / Dryer Logo
177 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
