Laptop wont power up
When i tri and turn on my patriot 3070 laptop the green batterie lighit is on and ther is a plug like green light on to now power light and when i press power on button it goes off all together
    Sergeant:
  • 244 Answers
The problem could be either the motherboard, ac adapter or battery. Try removing the battery and use only the ac adapter and see if it does the same thing, but if not. It means the battery is causing that problem. But if yes, the problem will be the motherboard.
Hope this helps
Posted on May 13, 2010
I think my psp street e1003 has been bricked?
my psp has no sounds or not turn on my sounds
Jul 20, 2012 | Video Game Consoles & Games
All time my z icon is lighiting but my laptop is not running.What can i do now?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 28, 2012 | Lenovo ThinkPad T61 Notebook
Laptop wont charge
Remove the battery and try again. If it solved the problem the battery is shorted and must be replaced. Look at the plug in the back of the laptop for the power. Is it lose? if it is lose you have a short from it touching contactd together and it must be replaced. If neither of these work try using a loner power supply to see if it is that. The D600 has lots of Power problems on of witch is the Motherboard itself. Hope this helps you out.
Jun 06, 2010 | Dell Latitude D600 Notebook
Patriot 3070/ elite G320L1 laptop how do i get to the mobo
Remove all the 13 screws from the bottom. Remove the Battery and 3 more screws from the battery bay. There's another one in the corner under the Fan cover and you'll find two more when you pull out the CD-ROM Drive. Total: 19.
Now turn the whole thing around and extract the keyboard. It is snapped into 4 tiny "claws" at the spacebar side. Positions: below the Fn-key, below the middle between the ALT-key and it's neighbour to the right, below the ALT-GR key and below the cursor-down key. If you can't see them you can feel them either with your finger nails or with a knife. Push them towards yourself, i. e. towards the front side of the laptop, and carefully lift the keyboard either with your finger nails or a knife. Remove the metal shield and unlock the wedge connectors to release the flat cables of touchpad and keyboard and take the keyboard aside.
Now close the cover and unsnap the hinge covers from the rear side. Don't lift, just unsnap. Then open the Cover wide and lift the hinge covers carefully from rear to front. Use a knife if the center area won't unsnap voluntarily. Watch out for the frontside hooks, as they break off easily.
Release the 2 display connectors and the hinges (2 rear and 2 top screws) and remove the cover. Now we have only about 12 screws left to remove.
IMPORTANT:
Put all screws next to their original locations and make photos or a drawing. A long screw in the wrong place can go right through your mobo!!! If in doubt always use the SHORTEST screw that will fit.
Replace all the 1500µF capacitors that show the even slightest swellings on top. Use Ultra Low ESR type caps, like Rubycon MBZ.
Any more questions?
Good Luck!
nirwana
Apr 27, 2010 | EliteGroup G320 Notebook
Wont start
Hi there, please explain what's you face. Also you can follow the steps.
1. plug on the the power cable. Is there green light are on in adepter? Is not then your power cable damaged.
2. if you r battery fully charged then turn on your laptop with out connecting power cable. If your laptop booting then system is perfect.
3. Try to plug on by a different Acer laptop users power cable. and see what's going. I need these information for further instruction. You just say "wont start" i don't want to give you any blind suggestion. so please let me know more about it.
Thanks.
Feb 11, 2010 | Acer Aspire One Netbook 8.9" Notebook
My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Dec 08, 2009 | Acer Aspire 5315 Notebook
Hi Hoping some one can help me I have an acer
U ARE HAVING PROBLEM WITH UR POWER CORD OR YOUR BATTERY
Jul 15, 2009 | Acer Aspire 4520-5582 Notebook
My toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Mar 19, 2009 | Toshiba Satellite 2455-S305 Notebook
Computers & Internet Logo
283 people viewed this question
David Payne
David Payne
