Question about Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal
Zoom G1X Repair!!!!
Hey there, sadly my zoom g1x took a fairly hard hit in practice the other night and the rotory parameter switch took most of the damage. The plastic cover came off and the axis of the switch was off centre.
My question, does anyone have any knowledge of this pedals internal workings? Would it be possible to fix, i know i could get into it but would this perhaps cause more damage? The pedal still works but im just not able to change any setting values.
If anyone can offer any advice or has had a similar experiance any help would be much apprieciated.
Cheers, Chris.
  • chris_masson May 13, 2010
    Nice 1, will open it up and see if theres a part number. Cheers mate. :)
  • Zoom Master
  • 5,603 Answers
If the pedal still works, likely the circuit board is not cracked.
The control that is damaged is LIKELY an encoder.
Many of these are made by ALPS, Bourns and others.
You need to open the unit top get at the device.
The encoders are available from either DigiKey.com or Mouser.com
Here is an example page:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Selection
You need to match the pinout and part number if you can find it on the part.
Posted on May 13, 2010
  • Fred Yearian May 13, 2010
    Sometimes the available parts from sources other than the original manufacturer require a little modification like cutting the shaft a bit shorter to fit, but most stuff can be found without going to the original manufacturer.
Zoom g1x dc supply not working, my zoom g1x is working when battery operated but if i connect it to a adaptor there is no power, i've already checked my adaptor and it was properly working, what can i
Some possibilities:
  • Damaged on the DC-IN socket.
  • Broken solder joints on the center pin of the DC IN socket (see figure: pin 1 on DC208B).
  • Damaged (broken) in D2 or R54
Aug 18, 2014 | Zoom G1x Guitar Multi Effects Pedal with...
Where can i buy this regulator for zoom g1x?
If it is difficult to find 2933BD/29M33, use MC33269-3,3 for SMD package or LM1117-3,3 for TO-220 package.(datasheet LM1117)
You can find or buy here,in Indonesia:
It's very cheap, about 5000 IDR or it's about half US-$.
I repair musical instrument(guitar fx,amps,keyboard etc).
Visit me here.
Nov 27, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
Circuit diagram of zoom g1x
G1X circuit diagram is the same as the G1. They differ only on the pedal circuits.
circuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-0.jpgcircuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-1.jpg
Give your email,and I'll send the circuit diagram.
Jun 24, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
Zoom g1x dc supply not working, my zoom g1x is working when battery operated but if i connect it to a adaptor there is no power, i've already checked my adaptor and it was properly working, what can i...
Is the unit old?? Is it stored in an environment that has temperature fluctuations?? It could be the terminals on the input of the unit have dry jointed. This is when the solder lifts away from the circuit board. I have had the same problem on my ZOOM MRS1608 recording desk. Resolder the connections on the input. The base plate will problably remove easy enough to get to the point where the adapter is soldered onto the circuit board.
Good luck
Aug 11, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
G1x zoom guitar effects no power even using an adaptor
if you're using an adaptor other than the original zoom, make sure it's 300mA or more and try switching the polarity.
Jun 20, 2011 | Samson ZOOM G1x Guitar Effects Pedal
G1X not working
The first thing to check is the power source. A weak battery or adapter will cause this.
Beyond checking these the only other problems will be internal and require electronic servicing.,
Jul 02, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
Where should the Zoom G1X go in a pedal chain?
From an electrical engineering standpoint, an expression or volume pedal should be near the end of the chain so that the other effects don't try to process very weak signals when the volume is very low.
This gives better signal to noise ratio.
May 11, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal Logo
1,742 people viewed this question
Top Zoom Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Barry Webster
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
