Question about Ovens
I don't have a manual for my Samet undercounter
I'm trying to get hold of a manual for my Samet undercounter oven. I cannot a model number anywhere. The measurements of the oven inside are: 43.5cm x 32cm. I am also trying to get a rack and pan for the oven, as it only came with one. I am based in Centurion, South Africa.
5 Suggested Answers
  • 1314 Answers
SOURCE: user/instruction manual
try here under down loads http://miele.com/
Posted on Jan 01, 2008
  • 20 Answers
SOURCE: need oven rack, broil pan/insert for Kenmore Electric Range
Here the web site. http://www.repairclinic.com/Kenmore-Range-Stove-Oven-Parts?s=b6a13c264
Posted on Jul 08, 2009
SOURCE: Hi I have a samet
I have the exact same problem, and we also cant find the fuses??
Posted on Mar 06, 2011
Macmarkus
  • 2605 Answers
SOURCE: old oven, probably from early
Hello, welcome to FixYa. Based on your post I understand you have a problem with a stove/range however without a make & model number I can't speak specifically to your problem without generalizing. Having said that, it is far too old to have an ignitor....at least of the electronic type, most certainly a "standing pilot" (presuming it is as old as you suspect...early 70's). The good news, one typically only requires a flame source to re-light it. (likely the reason you smell gas) Now the generalizing, there should be a broil drawer below the oven door (similar to a utility/pots & pans drawer, without the storage space) if you open and slide it out the burner will be visible at the back...you may need a flashlight. At the very back of the burner tube will be the thermocouple with a small sensing bulb, this is where you'll want to hold the flame to re-ignite the pilot. If it fails to ignite, there may be a position on the oven control that says "lite" or "pilot". If so turn it to that position to ignite the pilot...if not, ultimately you may have a failed thermocouple. Let me know how you manage or if you have any questions going forward. Please let keep me posted in any event. Good luck and thank you for choosing FixYa. Regards, Macmarkus :)
Posted on Aug 30, 2011
Samet model 611 stove wiring diagram
Request the diagram directly from Samet.
Aug 08, 2016 | Stoves Ovens
Where can i find a manual for a samet stove?
look here
https://www.google.ru/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB0QFjAA&url=http%3A%2F%2Ffruitfarm888.ru%2F&ei=eQarU8HeOuXnygOiloCwAg&usg=AFQjCNFYcGEHf3CR7e97fPRnLIBoLH06cg&sig2=Wvqu3y88ReaF03t5zDntqQ&bvm=bv.69620078,d.bGQ
Jun 25, 2014 | Lincoln Conveyor Oven - 1131-000-A
Need User Manual
Sorry, I don't have a manual for that model number.
Nov 23, 2011 | AEG B4101-4 Electric Single Oven
I have a Thermodor SCD302ZP Double Convention Oven. Does the lower heating element come out from the front of oven or do you need to gain access to rear in order to test/replace it? I removed the...
that model number doesn't come up.first make sure the power is off to the machine,you have 240 volts going to that element,all the thermodor ovens i worked on come out from the front,there should be two phillips screws holding it in place,remove the screws and pull the element forwards,some of them you have to lift the element up the end that goes through the wall is bent up so the wires don't hit the metal wall behind it.on some the wires are very short so don't be surprised if they pop into the hole on you,try to hold it with a needle nose,have the other element in there and stick the wire right on the new element so you don't loose the wire into the hole,if that happens you might have to pull the oven and remove the back panel.good luck and i hope this helps you
May 11, 2011 | Ovens
Hi I don't have a manual for my oven (recently
Please check on the official site or send a request to the support center.
check this link below: you have also not mentioned the model number.
http://www.whirlpool.com/catalog/category.jsp?categoryId=83
May 06, 2011 | Whirlpool Ovens
I have a Samet built-in oven (linea italiana #DG941ET) and I want to know what its temperature gauges mean. They range from 1 to 7. Thank you.
Samet Double oven - Small oven on top. Glass door just shattered whle cooking. Can i Buy a new door or have the glass replaced in South Africa.
Jun 16, 2009 | Ovens
I need a bellissimo oven manual
I to have brought a house with this oven and I am sure i am not using it properly, how did you go with instructions. Roz
Mar 28, 2009 | Ovens
Ovens Logo
55 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
