Question about Refrigerators
Could you tell me a what a repairman would do as a routine troubleshoot for the problem of the cooler not cooling? I need to learn as much as I can about refridgeration as soon as possible. I am taking a company to court because I beliveve the techicians they had service my machines were not licensed and being in FL if you advertise that you are a contractor in refridgeration your employees must be certified and PCCLB card. I requested to see this and they never returned my call. So if you could break down the troubleshooting process for me it would be VERY helpful. Thanks
    President:
  • 4,070 Answers
Hi! I believe that the first course of action is check the freon. He should check this by applying leak test and repair if theres a leak. If no leak, he should check the compressor if properly working or maybe its just a fuse problem. He should check the dryer and thermostat too if its working properly and if not he should replace it. Hope this shed some light.
Posted on May 13, 2010
Tip
When should you change the grease on your Oster A5 or 76 clipper
Oster A5 or 76 clipper need to be grease at lease every 4 month so they can run quiet and cool. when changing and removing the grease, You need to remove the old grease completely, or You are doing more harm than good. By doing this on a routine base, You are saving wear and tear on your gear,lever,link and blades. and the clipper motor will run cooler.
on Mar 30, 2010 | Kitchen Appliances - Others
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
Refrigerator won't cool less than 52 degrees
I can tell you if it can be fixed by you or if you need service. Just answer a few questions as we go through this. Pull away from wall and remove the lower panel. Feel top of compressor and see if too hot to keep your hand there or cool. Let me know if freezer fan and fan below are running. Answer those and that will help me answer your questions, Thanks Sea Breeze
Feb 15, 2010 | Maytag Admiral Top-Freezer Refrigerator
Trans fluid getting into rad causing overheating
The only way it can get in the rad is internally.You need to replace the radiater or take to a rad shop to see if can be recored.
Oct 19, 2009 | 1989 Mazda 323
We have a Coke Cooler (True)-- not cooling, icing over
thes are pretty well built unit, did you check th see is the evaporator fan motor is running at full speed" All that you may have to do is clean the evaporator and maybe change out the evaporator fan motor. True has a special one and you cost should be arouud 75 dollars wholesale.
Dec 16, 2008 | Frigidaire FRS23KF7AB Side by Side...
My Koolspace cooler in my VK250 wine fridge quit cooling
I have the same problem with mine and have tried the same things as you have. I took my unit to a air conditioner service place and they said these units are not worth fixing. It would cost about $150 to add a valve so they refill the gas and then try to find out why it is leaking. I am about to order another one which makes me vary mad. My unit is 1.5 years old.
Apr 09, 2008 | Vintage Keeper chillR 300 Wine Cooler
Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Dec 31, 2007 | Avanti EWC28 Wine Cooler
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
