Question about Fujitsu Siemens AMILO D-7830 Notebook
Amilo7600 laptop processor overheating and screen going blank
    Sergeant:
  • 244 Answers
If your laptop switches itself off when overheating, you need to replace the motherboard, heatsink. If you are still covered by warranty, you can have it serviced.
Posted on May 13, 2010
No post
This sounds like it could be an overheating issue. Some manufacturers use a cheap thermal paste on their processors. If you are dealing with a computer this should be an easy fix but if you are dealing with a laptop then it is much more involved. Go to Youtube and research replacing or removing heat sink. You wont be replacing the heat sink but the procedure is the same except you will need to clean the old paste off your heat sink before you apply more. Don't go crazy with the paste, a little goes a long way, all you are doing with the thermal paste is ensuring full contact between the processor and the heat sink with no air gaps.
Feb 28, 2013 | Dell Studio 1558 Notebook
I have got this dell latitude-d510 that comes on only some times after reseting the ram...when it comes on it stays for like 2hours than the screen goes blank but the powerlight is still on and fan still...
It could be the processor overheating, screen saver or overheating GPU. Once the display goes off connect the laptop to an external monitor and check if u get a display on it. If you do, it could be the LCD panel or LCD cable strip. If you dont, clean the processor and see if it helps. If not, the GPU would be faulty.
Dec 06, 2017 | Dell Latitude D510 Notebook Computer for...
Sir, I am using Acer Aspire 4530 laptop. About 3 days ago I unplugged the main power supply. The laptop was running on battery. After an hour all of a sudden there was blank screen. I can seen black and...
You must have hit the screen and damaged it, that's the only way you get those colored lines. Contact Acer tech support for assistance in replacing the LCD. You will have to go through a bit to get a phone number. http://secure3.tx.acer.com/findsystem/FindSystem.aspx?title=Contact+Support&brand=Acer
Mar 05, 2011 | Computers & Internet
15 to 20 mins screen will go blank and will have A black screen reboot and it will work 10 or 15 mins. RELOADED XP AND THIS DID NOT HELP, SAME PROBLEM
Your Dell OptiPlex GX260 PC Desktop computer is overheating. It is shutting itself down to prevent component failure.
Ensure that the Processor heat sink is clean of dust so sufficient air can flow through the heatsink and cool the processor.
Install additional fans in your computer 120mm are best but 80mm fans will do fine.
Clean the computer chassis of dust as well.
Thanking you
damnor01
Feb 02, 2011 | Dell OptiPlex GX260 PC Desktop
Computer has power, hear the fan and HD trying to run however nothing happens, blank screen. Plugged in external monitor and still black screen
HP laptops have several problems with GPU overheating. Could also be a bad stick of RAM or a bad hard drive. You will need to remove each one and try to power on after each is removed. If still wont light up the screen you probably have a motherboard problem with the video chip (AKA: GPU processor)
Jan 17, 2011 | HP Pavilion dv7-1240us Notebook
My computer turns on but with a blank screen doesnt boot up just all blue lights? its a hp pavilion entertainment pc i have shut it down completley but nothing changes is there a hard ware problem
Nope...Graphic card problem. Your computer needs to be opened, the graphic card reheated and copper shims need to be placed between the heatsink contact points with the graphic card and processor to prevent it from overheating again.
Dec 14, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
I have installed windows XP on Acer Aspire 4520 and since it was not booting up normally i installed all the drivers in Safe Mode. Even after doing the same it's not starting normally just a blank (Black)...
your computer your laptop will just shut itself down and get a black screen unexpectedly, which is due to: power overload in the AC adapter, overheated processor / clogged fan, overheated battery, pushing the power button, Windows telling it to, the BIOS telling it to, loose wires (especially the power cord), or intermittent short circuits. The most common problem is cooling. the battery should be removed from the laptop and allowed to cool to room temperature before attempting to use again.
Oct 26, 2010 | Acer Aspire 4520-5141 Notebook
Power on screen blank.. fan on
Did you hear a sound beeping. If you can hear a sound beeping it is a RAM problem. But if there is no sound beeping that is a processor problem. You can disassemble or remove the processor and clean make sure that the processor fan is spinning so that it will control the temperature of the CPU to avoid overheating.
Jul 31, 2010 | HP Pavilion dv6704nr Notebook
Power but screen is blank shop said mother/b or processor ?
The 5535 is a decent computer and if it is doing right by you and you are comfortable with it, then go ahead and repair it. I would suspect that the motherboard may have failed but I doubt the processor did, unless you overheated it so bad that it over rode its thermal shut down protection and melted like Chernobyl. The motherboard can be bought on EBay for a decent price, most likely between $100 to $185 bucks. I'll give you a link below that goes to the service manual for that model. With the manual, you can rebuild the laptop with nothing more than a phillips screwdriver and patience. When you are ready and have the parts, get back to us and we can help further.
When the link comes up, it is around 8 mb in size, make sure you have a pdf file reader like adobe reader. The manual will come up sirt of small, just hold down the Ctrl key and tap the + key to enlarge the view.
http://tim.id.au/laptops/acer/aspire%205535%205235.pdf
Jul 22, 2010 | Acer Aspire 5535-5050 Notebook
A few problems
the lines are either a bad screen or a bad graphic card. overheating could be related because it does happen when the chip overheats.
Overheating
Basically every computer and laptop has a processor inside
That processor gets extremely hot when on however there
Is a heat sink with fan which cools it at all times.
Over the years dust builds up around the fan and heat sink
And blocks the air vents preventing cool air from coming
In and out. This causes the processor to overheat and
The reason why it’s shutting is because your laptop
Is doing so automatically to protect it.
To sort this out, you should switch off your pc or laptop
Remove the cover and access the heatsink and fan
It will need to be cleaned with a brush or an air-can
Properly and once this is done air should go in and
Out easily without overheating.
It is also recommended to add thermal paste
To the top of the processor however
You’ll need to remove the heat sink completely
For that. Making sure it is applies 100% back
On the processor.
Overheating is serious and must be taken care of
Asap. Here’s a link to a tool you can download and
Install to monitor your computers temperature
Download SpeedFan 4.37. free.
Mar 20, 2009 | Acer Aspire 9300 Notebook
Fujitsu Siemens AMILO D-7830 Notebook Logo
289 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
