Question about OKI Electric Industry C3520 Laser Printer
OKI C3530 MFP Scanner Sensor locked
"scanner sensor locked" - whats wrong? where is the sensor lock switch?
OKI C3530 MFP
3 Suggested Answers
SOURCE: Oki C3530 MFP
Con el cartucho instalado en su posición, tiramos de él para arriba y sacamos todo el alojamiento del mismo. En la parte derecha del mismo hay un cuadradito con una ventanilla de plástico que debe estar totalmente liberada. El problema es que ésta a veces se queda medio tapada y el sensor no detecta el cartucho. Levantar ese plástico hacia arriba todo lo que se pueda ( con algo que tenga punta, un boli por ejemplo) y volver a poner todo el alojamiento en su sitio. Suele funcionar a la primera, y si no, apagar y encender de nuevo la impresora.
Posted on Sep 17, 2008
SOURCE: brand new c3530mfp menu reads
When you open the top (like putting a document in for scanning) there is a slider (button) on the left hand side of the glass. Just slide it from the "locked" symbol to the "unlocked" symbol.
It took me 2 hours to fix this problem, after the house cleaner turned my MFP to locked without me knowing.
Cheers,
Stefan
Posted on Jan 22, 2010
Where is the sensor lock switch?
The scanner lock is situated at the left side of the flat bed scanner. switch it to UNLOCK.
Sep 04, 2014 | Oki Brand Oki MB480 MFP Multifunction...
Error 3100 in kyocera fs1030 mfp
ISU home position error. Check the scanner lock to make sure it is not engaged. If not it could be the home position sensor for the image scanner unit.
Dec 17, 2013 | Kyocera FS-1030MFP Mono Multifunction...
Scanner home sensor error
check for dust or any forgien particle in the scanner unit clean it ,
Jun 06, 2013 | OKI C3530N Color MFP Printer
NEW MACHINE - IT SAYS RELEASE THE SENSOR LOCK WH...
what model is your printer? if your printer is those AIO printer, which means it comes with a scanner.. you will be able to find the scanner lock at behind or side of the scanner...
May 20, 2010 | Office Equipment & Supplies
Brand new c3530mfp menu reads
Cheers,
Stefan
Nov 05, 2009 | OKI C3530N Color MFP Printer
OKI 3530 MFP Service call: 150
Your error 150 is the toner sensor board not making contact with a drum and therefore not blowing its fuse. Remove the Main board and you will find the toner sensor board behind it. It has a lot of metal contact springs and you will most probably find one is out of position and just requires removing and refitting. If still not working the part number for the board is: 43614901 OR-Board-PRS
Good luck.
Jul 09, 2017 | OKI B4350 Laser Printer
OKI C3530N Multifunction Printer
Check the left side of the drum cartridge.
There's a little door that may be stuck closed.
Carefully push it open with a small screwdriver.
Oct 31, 2008 | OKI C3530N Color MFP Printer
Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 30, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Oki C3530 MFP
Jul 16, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
OKI Electric Industry C3520 Laser Printer Logo
1,526 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
