Question about Freezers
Lec tf 5586 freezer section not droping to lower tempreture for freezing, fridge section is ok
The freezer does not freeze properly only 2 years old
Posted on Sep 23, 2010
Red light on lec freezer keeps on but not freezing
Seems like the compressor on the freezer stopped working
Jun 27, 2016 | LEC Freezers
Where is the thermostat on this model
Behind the adjustment knob inside the fridge,the adjustment is the thermostat.
Aug 06, 2015 | LEC U5010W Freezer
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Jun 16, 2014 | Daewoo FRSU20IA Freezer
I have a Whirlpool wbm46mw Fridge, the freezer is working ok but fridge not getting cold, any suggestions,Thanks
Empty fridge and if possible put steam down vent behind the cover in the freezer section. or hot water. it will com out in the fridge so be carefull. this unblocks the aif feed from the freezer to the fridge section. also make sure the fan is working.
Oct 04, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
Fridge only freezing on top shelf no gas /?
dear sir/madam
first make sure your freezers is clean well sometime evaporatore close by dust and dirt then its cause effect to our equipment,s performence.if its well clean then check tempreture sensor in right location. if all is ok then contect to your maintenance personnel for refilling the gas.
hope answer the question.
thank you
Jul 05, 2010 | Hotpoint Freezers
I have a Lec T250WS Fridge/Freezer. It is in my holiday home and has been turned off for the past 3 months (as it is every year) We have turned it back on but it is freezing everything in the fridge. What...
This sounds like a thermostat issue. Go to a recyclers and ask if you can get a thermostat from them. Even if you have to get an old dial type it will be worth the effort for now. Just disconnect yours and re-connect the used one and see if it fixes the problem. Please be kind with a thumbs up. P.S. You can remove your old one and if you type in google how to test Refrigerator thermostat>> There is a site that tells you how. You take it and put it in the freezer or something like that. Just a thought
Apr 05, 2010 | Freezers
Plugged a new tumble dryer into an extension lead in garage with my lec fridge freezer and blew the fuse,brought new tumble dryer inside house and is working fine,lec fridge freezer in garage now showing a...
you have more than likely ruined the control board on the refrige,a dryer and refrigerator should each be on their own dedicated circuit,they use an enormous amount of current to start, and even if one is running and the other starts thats enough to trip even a 30 amp receptacle, and furthermore extension cord use on these types of appliances even a large gauge cord i.e. 12 ga. that will carry 20 amps is not even a good idea because of voltage drop,as this causes motors to draw excessive current and over heat the motors and reduce appliance efficiency too
Nov 09, 2009 | Freezers
FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Jan 22, 2008 | Freezers
LEC Fridge Freezer
clean up your condenser it's gotta be dirty and check your thermostat put it on the coldest setting and check your freezer fan.
if t ain't running check to see if wired with defrost thermostat if it is suspect it defective.
Dec 17, 2007 | Freezers
Freezers Logo
473 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
