Question about Linksys WRT54G2 Wireless Router
I have problem connecting iphone to wrt54g2. other wifi device (notebook) is work okay. Any suggestion?
  • 4,924 Answers
Go to the router settings(insert the http://+router ip address and hit enter) and check the wi fi settings ..
The first thing to check is if the security is not selected by the mac adress I mean there is such a option and it makes the selection by certain mac addresses allowed..
Second change the channel ...there are channels from 1 to 12 and each one in a different bandwidth so ..change one by one ..cause It is the possibility that it is set in one that is not covered by the iphone..(depending the country and such )
3rd Verify that your Wi-Fi router firmware is up-to-date.
This is important if your Wi-Fi router supports 802.11n, as it may still be using the draft specification of the 802.11n standard.For third-party Wi- Fi routers, check the manufacturer's website for details on updating your firmware.
Use WPA or WPA2 wireless security
Check the wireless security option of your Wi-Fi router. If WEP is being used, try using WPA or WPA2.
Some Wi-Fi routers using WEP wireless security may cause intermittent disconnects to iphone which requires re-typing a password. Using WPA or WPA2 wireless security on your network will correct this issue.
Note: WPA and WPA2 encryption protocols are newer, more effective security options for wireless networks than the older WEP protocol.
In fact try to ge rid of all security ..wer or wpa...and the selection by the mac address...just let the connection non security ...and see the connection problems first ..the issue may be from apple ..cause I keep reading about some wi fi problems that they have on some I pad and Iphone ..or is one related with the bandwidth and channel..
Posted on May 13, 2010
Ehome router
D-Link ehome routers are okay for laptops, which have a more robust transmitter, and better antenna for connecting to wifi. iPhones and iPads aren't that lucky. When you get close to the router, I assume they work good. Best bet is to return it and get a stronger router, Even from D-Link, a company whose products are outstanding. You could also get a signal booster, and connect it in the ares where you are having intermittent connectivity.
Jan 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Hp g50-213CA wifi
Try using just "numbers" as password for you iPhone 5 personal hotspot.
Nov 20, 2013 | HEWLETT-PACKARD G50-213Ca Ac Adapter...
My iphone 4s will connect to my wifi but cant download anything new - yet works fine on 3G
check the settings of the wifi ( make sure thats DHCP) in the wifi menu
good luck
Feb 13, 2013 | Apple iPhone 3G
Iphone can't use home wifi
just confirm if the password you have for internet is correct or not.
Now do the manual security settings in your phone same as of router. Like security type & password both.
check for the phone wi-fi, and use it.
Jan 21, 2012 | Linksys WRT54G2 Wireless Router
Random wi-fi dropping
Go to the linksys website, see if they have a firmware flash for the router, that may help in some connectivity issues. You may also find that the ipad/iphone may drop connections when battery levels are low
Nov 02, 2011 | Linksys WRT54G2 Wireless Router
My Iphone 3G won't connect to home wifi after working well for months. In settings, it searches indef. for networks. 3G works fine. My husbands iphone works fine. Any suggestions?
you can try to set your wifi same as your husband's one, check the wep code and wifi shold be enabled.
try this and give feed back!
good luck
Jun 30, 2010 | Apple iPhone 3G
Tells me Unable to connect to Server
My iphone 3g is unable to connect to internet , even though it gets connected to my WIFI modem. Cant vierw any mails of cant even connect to websites thro safari or to Itune store....
Jul 16, 2009 | Apple iPhone Smartphone
Windows vista laptop lost connection to the internet
Start off simple. Try a different port on the router. If that doesn't work, try a new cable. If that doesn't work, go to the Device Manager in Windows. (Right-click My Computer, select Manage, go to Device Manager). Does the card look okay? Has it been disabled or need a driver update? If we're still looking at issues then I would take a look at your router security. How many DHCP licences do you allowed to be assigned? Also do you have security in place (WEP/WPA, Mac Filtering, SSID Broadcast)? If you are light on security and only have a few assignable DHCP licences, you may have neighbors leeching your internet access.
To clarify: DHCP assigns a network IP address to each device on its network. Most Linkys routers have a default of 10, you may have reduced this yourself. If you have, you've limited the # of devices allowed on the network. So if you have 3 DHCP licenses available, and a couple neighbors are leeching, your Dell may not get assigned an ip.
If you still need further help, let me know.
Jun 24, 2009 | Linksys Ultra RangePlus Wireless Routr...
Linksys WRT54G2 Wireless Router Logo
101 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
