Question about Yamaha 12V Air Pump
Rough idiling and will not get up to top speed. When on land it will get up to top RPM but when in the water it only will reach 6000 RPM
  • 2,069 Answers
Please refer to this for modifications you may have to make in order to achieve top speeds.
Regards
Posted on May 13, 2010
  • Mark May 13, 2010
    I don't need a modifaction. Last year I achieved speeds over 60mph. It is idiling rough.
My 98 blazer idils rough in drive. When its hot its at 500 rpm what could cause this
Have you explored the meaning of the codes? Check for dirty/stuck EGR valve.
Dec 19, 2014 | 1998 Chevrolet Blazer
What causes bad gas mileage stalling at high speeds and rain idiling rough engine knocking 2003 Isuzu Rodeo
Check the coils, there may be a bad coil. That lets moisture in it, and causes the engine to mis fire. God-Bless! Its worth a try!
Oct 06, 2017 | 2003 Isuzu Rodeo
93 3003 MERCEDES 2.8 DIDNT PASS SMOG NO CHECK ENG LIGHT ON SMOG GUY SAID EGR STUCK IDILES A LITTLE ROUGH BUT RUNS GOOD AT HIGH SPEEDS WHAT DO I DO?
run the fault codes to ensure that the EGR valve is faulty. Engine lights to not always come on unless there is something drastic going on with the engine /gearbox so that you can stop the car before damage is done.
Apr 25, 2014 | 1989 Mercedes-Benz 300-Class
2005 caravan rough idling only when in gear (D or R)
I'm sure your check engine light is on try....
https://www.autozone.com/landing/page.jsp?name=top-five-reasons-check-engine-light
Jan 10, 2018 | 2005 Dodge Grand Caravan
92 NISSAN WITH BOGGING AT 2800 3500 RPM AND AT LEVEL SPEED 4CYL AND 5 SPEED
For this types of problem,there are few help inks to troubleshoot the problem.Click the link below to go through the troubleshooting procedure to resolve the issues :----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
--------------runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
-----------Car still runs Rough after tune up? http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
------------Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
----------High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
------------Engine Backfires? http://technoanswers.blogspot.in/2012/02/jeep-backfires.html----------- Nissan stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Nissan Pathfinder Backfires? http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
---------How to adjust rpm? http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
------------Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
----------This will help.Thanks.
Feb 17, 2012 | 1992 Nissan Pickup
I have a hyosung 2008 gt 250 r fi model. when i start the engine,idle jumps to 5000-6000 rpm . i checked the isc selenoid and while the ignition switch off the selenoid long,while ignition switch on the...
This doesn't sound like an electrical problem. It sounds more like an air leak between the carburetor and the cylinder. Air that has not gone through the carburetor makes the fuel/air mixture lean. This causes the engine to run super fast and hotter as well. Check all rubber fittings and seals between the carb and the cylinder. Be sure the clamps are tight and all mounting bolts are tight.
May 11, 2011 | 2008 Hyosung GT250R
My 1998 Explorer on startup idiling to high, it occasionally revs up and down while idiling. Is there a trottle position sensor that controls the idiling rpm?
there is a tps located on the intake where the inlet tube for air intake connects, it would be on the left side of the throttle body. does the trk run rough on idle? up/down sputter sometimes stall? Is check engine light on? if no light,check all vacuum lines for cracks/splits loose fit. do this by spraying carb choke cleaner on connections motor rpms will change if leak is present. also spray around perimeter of intake housing where mates with lower intake if engine revs you have bad intake gasket.I Just replaced upper and lower intake on my 98 and shazaam, runs like it should. but do your checks first,unessasary fixes are costly and **** you off.
Jan 03, 2011 | 1998 Ford Explorer
High idile
turn the idle down. you need a flat head screw driver and find the idle switch and turn it down.
Dec 30, 2009 | 1989 Jeep Cherokee
Car runs rough
Make sure heads are torqued (tight) don't over tighten aluminum heads can get warped, heat up re -torque use lock tight on head bolt treads.
Dec 25, 2017 | 1995 Volkswagen Cabrio
Yamaha 12V Air Pump Logo
183 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
