I have a Canon PIXMA MP830 Office All-In-One Printer. when I print there is a 1/4 inch ink line on the back of the paper. I clean the bottom plate and it goes away but if the printer sits for a while and I print again, the 1/4 inch line on the back of the paper comes back.
  • ndesantis1 Mar 29, 2008
    I've replaced the black ink cartraiges twice and I still have the same problem. These were brand new cartraiges (non-refill).
    Do you have any other suggestions.
  • 655 Answers
Your cartriage is leaking ink, thats why it comes like.
Replace your cartraige immediatly if you are using a refill, it might not be refilled correctly.
Put the original one it will fix your problem.
Thanks
Iqbal
Posted on Mar 29, 2008
  • Iqbal Husain
    Iqbal Husain Mar 30, 2008
    I think your printer need servicing.
    Goto canon site and get there supports. Its free.
    Click here for canon:
    Select your region and get support, you may find toll free no there and you can get support on phone.
    Good Luck.
    Iqbal
6ya staff
SOURCE:
Error code 6A00 shut down machine. How do you fix it?
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Oct 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Printing
No black line while you scan, but it only appears while you are printing?
Mar 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Cannon MP500, new ink now printing black line on back page
Got to Printers and Faxes in Start, Right click on the icon for the printer, click properties, click maintenance and try cleaning the backing plate from there.
Jan 19, 2010 | Canon Pixma MP500 All-In-One InkJet...
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannon Pixma MP830 - smearing on front when printing
If you have taken it apart that far then you are way ahead of the game. My suggestion would be to clean the head or anything the ink touches in a vinegar/water solution. The vinegar dissolves any dried ink whereas the soap may actually gum things up. If that doesn't work or improve things I would say that your print head has a seal problem. The replacement print heads are worth more than a new printer so you can probably figure out whats cheaper to do.
Aug 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Solid black horizontal line on the back of printed paper
It means that the ink is coming back up from the ink absorbers, you need to have the absorbers replaced and a mylar strip added that Canon is aware of, to keep this from happening again.
Aug 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hp officejet, pro k5400 printer,when printing i get lines top to bottom on print,about 1 inch apart,tryed print head cleaning,changed the cartridges .need help ,top to bottom,only on...
That is ink or dirt on the rollers, you need to clean them by lifting the lid, as if you were putting new ink in, and wipeing the rollers that the paper runs through.
Jun 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Error Code 6A00 on Canon MP830
try this 1. Opening the cover and wait for ink carriage to center 2. Pull out power cord 3. Pushed carriage to far left (should slide easily) 4. Used paper towel and wiped purge unit a lot of times (press down to soak paper towel with ink). Repeat until the paper towel is relatively clear. 5. Used diluted napisan (oxygen-based cleaning agent in the ratio of 1:3 with powder:water) and soaked paper towel 6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white. 7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down 8. Slided carriage back to original position 9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Jun 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer is putting a 1/2 dark black line on the back of the pages
dear friend
looks like problem related with refilled cartridges
are you using refilled cartridges??
if yes then you have to check whether they are leaking or not,
if they are leaking, you have to maintain cleaning level
thats all you can do
thanks
Apr 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Black line prints on back of paper
I have the same problem and I have not found any fix yet.
Oct 03, 2007 | Canon Pixma MP500 All-In-One InkJet...
Computers & Internet Logo
64 people viewed this question
Ekse
Marvin
Marvin
