Question about Dell OptiPlex GX280 PC Desktop
What do you do if you have a window that say's, "Warning Event Notification;" "chassis intrusion detected. This typically does NOT indicate a hardware failure. 1. Contact your help desk if you did not personally open your chassis. 2. Enter system setup and set chassis to clear.?" i tried entering my system setup but i could not find any thing that said chassis or anything what so ever, please help me
    President:
  • 1,901 Answers
Resetting the Chassis Intrusion Detector Turn on (or restart) your computer. When the blue DELL? logo appears, press immediately. If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer and try again. Select the Chassis Intrusion option and then press the left- or right-arrow key to select Reset. Change the setting to On, On-Silent, or Disabled. Hi, Above is the procedure for resetting the switch. This is directly from the on-line manual. If this does not work, just comment back. Thanks for using Fixya,.
Posted on May 13, 2010
  • Wayne Mineard
    Wayne Mineard May 14, 2010
    That was supposed to be press F2.
How to reset the case intrusion warning
  1. Enter system setup by pressing <F2> during the computer's start-up.
  1. Under the System Security tab, reset the Chassis Intrusion option by pressing the left- or right-arrow key to select Reset. Change the setting to Enabled, Enabled-Silent, or Disabled.
May 20, 2014 | Dell OptiPlex GX270 PC Desktop
The following are warnings that were detected during this boot.These can be viewed in setup on the event log page.Warning: chassis instruction
the following warning that were detected during this boot. these can be viewed in setup on the event log page. warning- chassis intrusion
Dec 18, 2012 | Computers & Internet
I have a dell and it said that i had a chassis intrusion I dont know what it means nor what to do help
That just means the case of the desktop was opened by someone.
http://phubner.eng.ua.edu/Files/Optiplex%20GX620/advfeat0.htm#wp1124663
Security Chassis Intrusion Detection note.gif NOTE: When the administrator password is enabled, you must know the administrator password before you can reset the Chassis Intrusion setting. This feature, if installed and enabled, detects that the chassis was opened and alerts the user. To change the Chassis Intrusion setting:
  1. Enter system setup.
  2. Press the down-arrow keys to move to the System Security option.
  3. Press <Enter> to access the System Security option's pop-up menu.
  4. Press the down-arrow key to move to the Chassis Intrusion setting.
  5. Press <Enter> to select an option setting.
  6. Press <Enter> again after you update the option setting.
  7. Exit and save system setup.
Option Settings
  • On - If the computer cover is opened, the setting changes to Detected, and the following alert message displays during the boot routine at the next computer start-up:
Alert! Cover was previously removed.
To reset the Detected setting, enter system setup. In the Chassis Intrusion option, press the left- or right-arrow key to select Reset, and then choose On, On-Silent, or Off.
  • On-Silent (default setting) - If the computer cover is opened, the setting changes to Detected. No alert message appears during the boot sequence at the next computer start-up.
  • Off - No intrusion monitoring occurs and no messages appear.
May 27, 2012 | Dell OptiPlex GX620n PC Desktop
I am getting the fatal error chasis intruded error on every boot...motherboard model is p5sd2vm...rahul
Chassis intrusion can be disabled one of two ways.
First, Check your bios settings. There should be a security or PC health section where you can clear that error and disable the intrusion warning.
Second, there is likely a small switch near the chassis side when the side panel is removed. This is the chassis intrusion switch. It will likely lead to a 2 or 3-pin connection on the motherboard. this can be disconected without any ill effects.
Aug 13, 2010 | Computers & Internet
P5v800-mx chassis intruded
You can actually disable the chassis intrusion warning from your motherboard BIOS setting.
This can also happen, even if there was no physical 'chassis intrusion' when your BIOS battery (button cell) is about to fail, or has reduced capacity.
This might need replacement. Another indicator that it needs replacing is if you have to set the system time, or any parameter for your mobo after an extended period that you don't use the PC.
Hope this is helpful.
Jun 27, 2009 | ASUS P5V800-MX Motherboard
Chassis Intruded!
Hey,
Go into bios or cmos setup. when you turn the computer on it says what you need to press to get in there, look over the bios, look for chassis intrusion detection, turn it off, then go back to the main screen save and exit.
you won't have the problem anymore.
Thanks and good luck.
Ekse
May 04, 2009 | ASUS P5V800-MX Motherboard
I have a Acer m420 4850B new I put in a PCI
Try going to the horses mouth (Acer) next time. From their on-line support:
Product
Veriton M420
Issue
Chassis Opened Warning Error
Solution
To disable the Chassis Intrusion Alert, please follow the steps below.
  1. With the system powered off; press and release the power button.
    Immediately afer releasing the power button, begin tapping on the Delete key.
    This will enter the system BIOS.
    In the BIOS, use the arrow keys to navigate the menus.
  2. Navigate to Integrated Peripherals and press Enter.
  3. On the Integrated Peripherals screen, there is an option labeled OnBoard IO Setup. Select OnBoard IO Setup and press Enter.
  4. Look for the option, Chassis Opened Warning.
    Select Chassis Opened Warning and press Enter.
  5. Change the currect selection from Enabled to Disabled and press Enter.
  6. Press F10 and then press Enter to Save the Settings and reboot.
The computer should boot without the intrusion alert message.
Feb 20, 2009 | Acer POWER APS290-UC4201P MT CELERON M 420...
Asus Board MOdel Number P4BGL (845 Mxl) is giving an error called Chasis opened or tampered.?
I read a solution of your problems, i did not ry this. But i want you to try in your motherboard: this was qoute by
" 9. anonobomber, 07-05-2002 09:51 read the manual from your motherboard, I'll quote it for you; Chassis Intrusion Lead (4-1 pin CHASSIS) This requires an external detection mechanism such as a chassis intrusion monitor/microswitch. The sensor is triggered when a high level signal is sent to the Chassis Signal Lead, which occurs when a panel or light detector is triggered. This function works with an optional ASUS CIDB chassis intrusion module (see your vendor for more details). If the chassis intrusion lead is not used, a jumper cap must be placed over the pins to close the circuit.
pinout 1[+5volt] [power supply standby] [chassis signal] [ground]
in order to supress the messages you are getting you will need to get a jumper to fit over the chassis signal and ground to bypass the chassis intrusion detection circuit.
This has nothing to do with resetting the CMOS. For board specific locations of the pins check http://www.asus.com.tw for the manual pertaining to your motherboard"
Jan 21, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Intrusion turned off and not detected
If you're refering to the chassis intrusion... (Which is what I'm assuming.)
There should be a switch in the case itself that release itself when you open the case. Make sure that it is properly placed and angled and that it is connected to the appropriate pins on the motherboard. (Often labeled "CH INTR" or something to that effect.)
There is also usually a function in the motherboard's BIOS that enables/disables the chassis intrusion alert. Check to make sure that the function is enabled in the BIOS. (Don't forget to save your settings!)
There may also be a jumper on the motherboard that enables/disables the chassis intrusion detection. (Although this is less common.) Check around for that if the other options aren't making themselves apparent to you.
Good luck with that. Hope I was on the right topic. :P
Cyryl
Nov 02, 2007 | Intrusion Intel PRO/1000 XT Server...
Error 51A2: System cover has probably been opened
I hope there an option in the BIOS that could disable chassis intrution detection. Please check the BIOS settings....
Sep 25, 2007 | Intel SE7320EP2 (SE7320EP2DG) Motherboard
Dell OptiPlex GX280 PC Desktop Logo
318 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
