Question about Asko 24 in. D3530FI Built-in Dishwasher
Overfilling fault I have an Asko D3530 reporting an overfilling fault. I checked the outlet hose and found a blockage. I cleared the blockage and the unit pumped the water clear. The unit however continues to opperate the pump with the message "Overfilling" diplayed. The manual indicates "call for service" Does anyone have any idear how to clear the fault? Thanks Steve
  • 159 Answers
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
Posted on May 13, 2010
OPENED UP THE REAR BOTTOM PANEL:
(make sure you turn off power)
1) dried the water from bottom tray
2) turned on whilst open the asko d3630 was o.k but identified leaky hose!!
3) replaced hose
4) saved a heap of money
5)works great hope this has helped you!
regards
Lucas
Posted on Nov 19, 2012
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
interrupted.
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Dado
Oct 06, 2015 | Asko Dishwashers
Asko D3530 Dishwasher Water Inlet Fault
I did research on the net and asko mention a special settings menu in the pdf manuals available
you can download a manual but there is a reference to water not entering the washer in the manual and how to trouble shoot it
Pressure pumps deliver water at pressures from 35 psi to 60 psi and if you have checked all of the slow fill reasons , maybe checking the on/off pressure switch for the pump would be a place to investigate
the machine will start when the water has reached the level set
anyway go google and type in - workshop manual for asko dishwasher model d3530 --and download a pdf version to read
Jun 08, 2017 | Dishwashers
Getting an F4 fault code after about 1 -2 minutes of operation. There is actually water in the bottom of the unit. Have put a vacuum on the inlet feed tubing and also have blown compressed air through the...
Hello & Welcome to FixYa
F4 error in your Asko Dishwasher is a water fill fault and this indicates and over fill fault. To check and solve this problem please follow these steps:
1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | Asko 24 in. D3350 Dishwasher
What does code F2 mean?
Hi, Welcome to FixYa. The "F2" for Asko dishwasher indicates an issue with the unit overfilling. This can be caused by several things, faulty inlet valve, drain pump, a plugged fill switch/overfill hose or a leak which causes the overfill switch to actuate or even a plugged drain hose. ( if you wait a couple of days it may in fact start working as the water in the base evaporates ) I would start by removing the bottom toe panel to see if the base is full of water and then check the drain hose where it connects to your home plumbing. Of course make sure you turn off the power at the breaker panel. If you don't feel like these are things you can check I'd recommend calling an authorized Asko service provider. Let me know what you find. Macmarkus :)
Aug 15, 2010 | Asko D1776 Stainless Steel Built-in...
Water outlet fault. The door wouldn't open, so I drained the unit and then the door opened. I cleaned some coins out of filter and tried again. Same fault, water outlet fault.
Hello and welcome to Fixya. With the Asko washer it is possible to have some coins and debris up in the hose which goes from the tub to the pump as well as downstream of the pump in the drain hose, it is a pretty small diameter and quarters, nickles, dimes and pennies can block it up entirely. It will require a very thorough check. You may in fact have a damaged pump as well. If you watch the pump impeller it should spin freely, if it just sits there with the impeller moving slightly back and forth it is faulty. In any event you'll need to either phone in a pro or remove the pump and hoses ( which are held by one-time clamps ) which will require installing new hose clamps and removing the lower service/access panel. Depending on the actual model of Asko washer you have the process of doing this will vary. Let me know how you make out or if you require further assistance. Thanks for visitng fixya, please rate this info accordingly or please let me know how I can help additionally. Good luck. Macmarkus :)
May 25, 2010 | Asko Washing Machines
Asko washing machine won't drain.
Further on to this F3 problem I had the issue on model W6461. There is a short cut to the fix, instead of taking off the grey pipe from the drain pump (the hose clips are pre crimped in the factory so as stated above are difficult to remove) try this.
Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear through back the coin trap.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water.
Just ran the machine now and fault cleared.
Good luck
Jurgo
Apr 30, 2010 | Asko W660
Asko model 1776 that doesn't drain. We stored it for years and have installed it without any installation guides. It was from a construction auction and it had some mice living in it in the shed. I...
Remove the drain hose and make sure its clear. Inspect the pump outlet where the hose attaches and make sure itts clear. Usually insects build nests in the end of the hoses during storage. If this is not the problem, and it does spray water during the wash cycle, it is either the separate drain pump or the control board. test the drain pump to see if it has resisitance (unplug the unit first) if not it is bad. If the pump has resistance it may be seized. Last check the control board.
Feb 12, 2010 | Asko D1776 Built-in Dishwasher
W640 - Water Outlet Fault
I solved this problem this morning, after several months with intermittent "water outlet fault" error messages.
Our pin trap was cleared many times over the months. The propellor turned freely. However, the problem persisted.
So I unplugged the machine, removed the back panel (8 or so hex screws) and located the point where the drainage hose meets the water draining pump. I then separated the hose from the pump and found 2 United States 10-cent pieces lodged together with gunk that effectively blocked the drainage hose. 10-cent pieces ("dimes") are the perfect diameter to get stuck there and not appear in the pin trap where you could easily see and remove them.
Three loads later, the machine is working according to spec. Hope this helps.
Apr 09, 2008 | Asko W640
ASKO 1475 Does not not pump out and drain at end of cycle.
If dishwasher drains ok into bucket then fault is with the house plumbing
Jan 19, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Asko 24 in. D3530FI Built-in Dishwasher Logo
1,261 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
