Question about Nokia 6680 Handheld
It does not install any software from my memory card
My memory card is not working
Memory cards, also called memory sticks or MS cards, can create problems with a computer. Sometimes, a computer will not read the card or errors cause problems when removing files from the card to put them onto the computer.
Problems range from a virus on the memory card to inappropriate software on the computer. Fixing the problem partly depends on the cause of the problem, but making the card work is simple and takes only a few minutes.
Scan for viruses. Some viruses or worms infect MS cards.
A computer that suspects a virus might interfere with the memory card as a result.
Look for viruses or problems with the anti-virus software that won't allow the memory card to open. If a virus if found, remove the virus through the anti-virus software before opening the memory card.
Check that the computer has the appropriate software installed to read the card.
Some MS cards or memory sticks might require more updated software or specific software that is not on the computer.
If the software is installed, look for current updates and download any updates to determine if the problem is old software.
Open the control panel.
Click on "Add New Hardware" and see if it is available.
If the hardware for the memory card is not installed on the computer, this will allow installation.
Once installed, the card should read.
If the memory card is not showing up, the problem is often damage to the card, which prevents reading the card. If the card is damaged, it must be replaced.
Use an adapter.
Some memory cards are not designed for reading in a computer directly and require the appropriate adapter.
The adapter changes the data to the appropriate system for the computer to read it.
Hope this helps
Nov 16, 2012 | Electronics - Others
Tip
How To Recover Data From Various Types of Sony Memory Media
The Memory Card File Rescue Service is used to recover data from various types of Sony Memory Media. This software can be used on all Sony brand Memory Sticks, SD Memory Cards and USB Flash Drives except:<br /><br /> * Non-Sony brand Memory Stick and SD Memory Card<br /> * Memory Stick for AIBO robot<br /> * Memory Stick ROM for electronic dictionaries or e-Book readers<br /> * PSP brand Memory Stick, or Memory Stick Micro<br /><br />Note: Defect or damage of a memory card itself cannot be recovered.<br /><br />What type of files can be recovered?<br />JPG (DCF), MPEG-1, MP4(MPEG-4, MPEG-4 AVC) file, and other types of files. This software analyzes FAT file system and recovers a file regardless of file format whenever possible. Recovery of all data is not guaranteed as some files may not be recoverable.<br /><br />Compatible Operating Systems<br /> <ul> <li>Windows 7</li> <li>Windows Vista</li> <li>Windows XP</li></ul> <ol> <li>Log on with an Administrator account when installing Memory Card File Rescue software for Windows XP, Vista and 7.</li> <li>Download the Memory Card File Rescue Service from here: <a href="http://support.sony-europe.com/rme/downloads/downloads.aspx?m=DCR-TRV355E&f=MS_Rescue">http://support.sony-europe.com/rme/downloads/downloads.aspx?m=DCR-TRV355E&f=MS_Rescue</a></li> <li>Install the software and run the Memory Card File Rescue Service.</li> <li>Follow the prompts to recover your Memory Card Data.</li></ol>
on Mar 13, 2011 | Computers & Internet
My problem is that when I store some data in memory card then after some time that data is damiged and alots of virus covered
Hello Afridi,
First scan your memory card using the anti virus installed in your machine.You can scan you memory card for antivirus using the Avira anti virus.Please download the anti virus from :
http://www.avira.com/en/free-download-avira-antivir-personal?
Download the .exe file from the link.
Install the software in your computer.Remove the memory card from the phone and connect in your machine using the memory card reader and scan the card for viruses or malwares.
Then try the Data Recovery Software available in market to recover the files. Install the demo software of the data recovery software( Recover Data for FAT and NTFS) from their particular website. Then scan the memory card using the Data Recovery Software. If the demo software displays all your data you need then purchase their full version software to save your valuable data. Because in demo software you are not able to save the data. Please try the data recovery software for FAT and NTFS partition.
Please download the demo software from the link provided below :
http://www.recoverdatatools.com/download-windows-data-recovery.html
Download the software from the above link and install it. There are two recovery modes available in the software Normal and Exhaustive mode. If the software did not find any data in Normal mode than try the Exhaustive mode available in step 2B in the software. If you are installing the software in Windows Vista or Windows 7 then run the software as administrator after installing it.
Jun 11, 2011 | PNY 2GB microSD Memory Card
How Can I read my Memory Stick Pro Duo MARK 2 on my Computer? MY problem is I cannot read my Memory Stick Pro Duo Mark 2 on my computer but my computer is showing another Removable Disk(F:),which is my...
    • 1 Visit the Sony Support site (see Resources) and download the Sony memory card software. You will need to specify your operating system. Save the file to your desktop.
    • 2 Double-click the downloaded file to launch the installer.
    • 3 Follow the onscreen instructions to install the Sony memory card software. Restart the computer after completion. Once the computer starts back up, it will recognize the Memory Stick Pro Duo when inserted into the computer's memory card reader. You can browse the files using Windows Explorer or the installed x-Pict Story software.
May 31, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
Hi,sir iam using nktel 2008 model.i downloaded softwares through my computer in 2gp memory card of my mobile,after i inserted my memory card it tells to format my memory card .pls solve this problem
You must install files to the memory card after formatting and making sure it is freeof any virus. Also the files installed must be recognisable in the phone as the software supported files only must be installed.
Sep 27, 2010 | Cell Phones
I have purchased a new kingston memory card, and i don't know which software to be installed to read my card on my computer My computer has a port to read memory card.
Normally, You would not need any software to read the memory card. Your windows system should automatically detect it.
The only possible reason why your memory card may not be read by your system is if you are logged in as a normal users and not the administartor. The system would first try to install the device driver for the memory card automatically when you insert it. If you are not an administrator, installation may fail. So I think you should log in as the administrator and then insert your memory card.
It's also possible that the memory card may be damaged; to test it, try using the memory card in someother computer.
Aug 01, 2010 | Computers & Internet
2GB microSD Memory Card memory card is corrupted memory card is corrupted
If its corrupted then simply down load hp format tool software. its free google it and downlaod.
install the software and format the micro sd card it will work fine,
Jul 30, 2010 | SanDisk 2GB microSD Memory Card
How to delete my memory card password in Nokia 3110 .It is 256mb
format the memory card. passwords are dangerous when forgotten. You loose all that you wanted to protect. format it either in the phone or on a PC.
Aug 05, 2009 | Nokia 3110 Cellular Phone
Softwear to install mini memory card reader
software comes with the card reader. if not contact vendor for supply of software
Nov 18, 2008 | SanDisk 2GB microSD Memory Card
Hw do i install a software in to my memory card in nokia n70?
first of all insert the memory card in your phone then open the memory card through the file manager.Then remove it and connect it to the pc through the card reader.Copy all the software to the Others folder. Insert the memory card once again and switsh on the phone .Go through the file manager and open the others folder of your card. There you will find the copied softwares .Just click on it and it will guide you through the installation
Nov 13, 2008 | Nokia N70 Cellular Phone
Nokia 6680 Handheld Logo
62 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
