Question about Northstar Garden
I just bought a used and broken Power Washer which I plan to repair and use, hopefully. I can't seem to locate operators/parts manual. NorthStar Pressure Washer ? 2400 PSI, 2 GPM Item#: 157472A Serial #: 1106 4728 Bar Code: 157472A11064720 Engine: 6 HP Tecumseh Pump: Comet VRX with brass manifold and stainless steel plungers Drive: Direct Thanks for your help.
5 Suggested Answers
  • 33 Answers
SOURCE: pump on my pressure washer will not pressuerize
there is a loader and unloader valve on your pump bolted to it. if it frozen in the open position it will never build press. most of the time this is caused by leaving cleaning solutions in system after use and let set up for a long period. it causes the aluminum case to corrode.;you will have to dissassemble and clean if not to bad. if not your going to have to replace.
Posted on Apr 21, 2009
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
  • 3600 Answers
SOURCE: Northstar pressure washer needs new hose
Need to know what country you are located in and if you want a 15 foot hose or 25 foot or 50 foot hose. The reason is We have to know where you are going to buy it and if you have a dealer that that is local or not. it's a 2500 PSI hose so the hose has to be a minimum of 3200 PSI You can also have hoses fixed at local hydraulic shops in the U.S. in the local phone book, they can make up the hose you need if you take it to them let me know.
Posted on Mar 25, 2010
  • 436 Answers
SOURCE: I have lost manual to
Here is the link
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=hqktGGuVh.IjhJvcv4
Hope it helps
Thanks
Please rate FIXYA
Posted on May 20, 2011
I have a northstar 2800psi 2.5gpm washer that doesn't pick up the cleaning soluion, is there an adjustment to make it **** the fluid out more?
There isn't an adjustment for pulling the cleaning solution out faster or slower. It's an automatic function, based on the size of the power washer (meaning it ****s at different rates for different sized washers). Here's a link to the manual for more information:
http://www.northerntool.com/downloads/manuals/1577543.pdf
Hope this helps!
Aug 30, 2010 | Northstar Pressure Washer 2800 PSI
I can't find my manual and no longer remember what the fuel mixture is for my workforce 163cc power washer. Can you help me? Thanks much.
Does your pressure washer engine have a place to add and check the oil level? If it does. And it looks like the picture from your question. It is a four stroke engine and the fuel doesnt need added oil.
Northstar washers are available online at Central Power Equipment.
You might find an electronic owners manual there.
Jul 17, 2010 | Northstar Pressure Washer 3000 PSI
Wrong manual
Here are the Bushnell manual for Northstar:
http://lib.store.yahoo.net/lib/opticsplanet/northstargotorvo.pdf
Aug 14, 2009 | Bushnell NorthStar 78-8846 (675 x 114mm)...
My Northstar Pressure Washer Pump does not boost water pressure
Pump will power up, but when I attempt to use the wand the motor sounds like it is running on one leg & blows circuit breaker----Ser# 1575551-1101 5160 Model #1575551E
May 11, 2009 | Northstar Pressure Washer 3000 PSI
Drain hose broken where it enters washer om back
It appears your hose clamp has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 10, 2009 | Kenmore Elite 45986 Front Load Washer
Driver side power window doesn't roll up
Had same problem, twice (different windows). First time the dealership repaired. Cost was near
$300. Next time it happened, I went to parts Dept. at dealership and bought a new regulator for that specfic window location, used a Haynes Pepair manual to show me the steps of removal and replacement. It seems the plastic in the part breaks and you have to buy the whole part which costs me about $110.00 at the time. Never having done this, I followed the steps in the repair manual and it took me about 20 minutes. You have to pull the inside door panel off and take the glass window out to work on it. Once you get the panel off, you can pretty much see how it all works.
Hope this helps you. You might just pull the panel off and look to see if a broken part is evident?
Jul 25, 2008 | 1997 Isuzu Rodeo
Kenmore washer out of balance
go to sears.com and find the parts listing for the 110 model number you have listed above .http://www.searspartsdirect.com/partsdirect/retrieveModelActionHome!retrieve.action;jsessionid=8mJfynqZfmsdSyTnd9kaQw**.shcapp3005?modelNumber=110.16502694+&pop=flush
You might need one of the springs. unplug the washer and take the cabinet off first. look around for broken or missing parts
May 12, 2008 | Washing Machines
Rear bearing noise when drum rotates
If the rear bearing is bad it will require the replacement of the entire rear tub shell. This is because the bearing is molded into the plastic and cannot be replaced separately (I know, its a stupid design). Sometimes additional damage can occur and the inner spin basket and front shell may also need replaced. In addition, what may seem like a bad rear bearing, might be a broken tub support on the spin basket. In a nutshell, you may have to replace both tub shells and spin basket at a minimum. With parts and labor the repairs could cost $600-$800. If you have no extended warranty or service plan coverage, it may not be worth the effort to repair due to the excessive cost. Sorry...I wish I had better news for you. I hopes this provides you with some answers.
Oct 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Garden Logo
103 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
