Question about Canon iR 2016i Black and White Copier
Canon ir2018 error drum is not set, but the new drum is set- what to do
  • ivlasov May 17, 2010
    the old drum unit and the new give me the same - "drum is not set
    insert the drum"
    I don't see what is checking the drum. The expert is say for the black flapper but this is for waste toner i'm thing.
    sorry for my English
How can change canon ir2018 drum
Posted on Oct 25, 2010
  • 1,219 Answers
Try few times more, check the drum unit- on front of drum units cover , left side, there must be black flapper with spring and it must move freely and go back to the first position. If you change only drum, but not whole unit check the flapper, I had few times problem with it.
Do not forget to turn off and on the copier.
hope tht helped
Pls. rate
Posted on May 14, 2010
If i photocopy mi Canon bring out dark blanker work
Posted on Jul 20, 2012
The canon Copier Brand iR2018 on the screen indicates a System Error E805, when machine is switched on.
Canon iR2018 Error Codes
This weblink states:
Code
E805-0000
Description
Fan failure
The fan is faulty.
Remedy
- Check the fan connector. - Replace the fan. - Replace the DC controller PCB.
Feb 16, 2018 | Canon Office Equipment & Supplies
SYSTEM ERROR E007 ON CANON iR2018
Call to 1-800-243-0019 Canon ir 2018 system error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film.
Apr 15, 2017 | Canon Office Equipment & Supplies
Canon ir2018 error e808 how to clear
To clear the E808 code unplug the machine for about 10 minutes. If the thermistors are bad the code will appear but will not reset until the fixing film assembly is replaced. If you have tried to repair this machine, make sure you have not left the connector unplugged.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/travis_e264b9f3ca4047ae
Jul 30, 2014 | Canon Office Equipment & Supplies
Canon ir2018 copier error messages E000 and E003
hi that errors indicate there is temperature failure in the fixing unit maybe caused by AC energy fluctuations . . . verify energy supply is correct . try to connect the machine in another Ac outlet. if problem persist maybe the fixing heater is malfunctioning
Jun 14, 2012 | Canon Office Equipment & Supplies
Where do i find the fixing film?of the ir2018 canon printer. what does it look like and how do i replace it? mukopaje@live.com
hi,
please do following
m good with laser printers but when it comes to copiers. ... I have a Canon IR2018 MFD copier. It started giving me the e007 error. I know this has somthing to do with the fixing film. ... Does anyone have a service manual or a technical diagram of a canon ir2018 copier.....that would help alot. ...
www.copytechnet.com/.../canon/41455-canon-ir2018-fixing-film-replacement.html - Cached iR2018 fuser replacement... Repost for mnamono‎ - 7 posts - 27 Oct 2010
IR 2018‎ - 9 posts - 20 Apr 2010
More results from copytechnet.com »
May 30, 2011 | Office Equipment & Supplies
Cannon ir2018 system error E007
E007 is fixing film problem. Worn-out fixing film.
Sep 28, 2010 | Canon iR 2016i Black and White Copier
How do i fixed system error e100 on cannon
How many copies do you have? If over then 55000 change the drum unit.
But it can also be the laser trouble.
Mar 15, 2010 | Canon PC1061 Copier
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
Canon IR2018 keeps saying waste toner full
...the waste compartment is same unit in the drum unit...if you know how to take out the drum unit then you can see the waste compartment...but be carefull not to damage the drum...couse its will cost you a lot, the price of a drum is high...and if you can change the blade in the drum unit then you can emptying the waste toner...better call for the expert technician...
Jul 08, 2009 | Toshiba e-Studio162D Copier
Support for Canon IR2018
hi this is fan failer error.. pls check ur machine optics fan or fuser fan. any one geting damaged or not connected properly.. pls check this..
Aug 04, 2008 | Office Equipment & Supplies
Canon iR 2016i Black and White Copier Logo
1,070 people viewed this question
old marine
old marine
