Question about Zanussi Refrigerators
Fridge not cold, nay need new thermostsat. Zanussi ZENB2625 nmodel.
  • 269 Answers
This unit is electronically controlled and has a sensor which is set into the insulation of the unit they can be replaced if needed with a kit.But it is a bit of tricky job.If the freezer is cooling ok then I would suspect that the defrost heater has failed or the timer.Defrost the unit over 24 hours then try it again.
Hope this helps.
Posted on May 13, 2010
I have a zanussi frost free fridge freezer and the fridge is not cold but the freezers fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Zanussi Refrigerators
Freezer fine, fridge too cold!
You need a new fridge side Thermistor. If that doesn't solve the problem, then replace the Damper Actuator.
Jan 05, 2018 | Zanussi Z32 / 5 Top Freezer Refrigerator
Zanussi refrigerator/freezer model ZX99/5
I had the same problem...it was a defrost problem in the freezer....mad i know...fridge doesnt work but freezer does...so its the freezer problem right!!!
This is how i solved it....there is fan behind the freezer compartment....you need to remove all the freezer draws then the plate at the back of the freezer compartment(everything is accessible from inside the freezer only) once removed you can put your hand up inside the gap(make sure power is off and unplugged) just in reach is the fan which you should be able to rotate with your fingers...mine was covered in ice and not able to move as a result the cold air couldnt be blown up into the fridge(the only thing controlling the air into the fridge is a flap and depending upon what fridge setting you have this determines how much cold air its letting in.)
If the fan has been frosted up you need to defrost the freezer....and source a new defrost sensor.
hope it helps.
Feb 24, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi Z87 problem
my fridege needed defrosting for a couple of days maybe this is the problem with yours.
Sep 22, 2008 | Zanussi FJS1225W Front Load Washer
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Zanussi fridge freezer
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Fridge not working
Sounds like the refrigerant has leaked out of the system.
Jul 28, 2006 | Zanussi ZSS7 / 5W Compact Refrigerator
Refrigerators Logo
150 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
tony denham
Level 1 Expert
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
