Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
The drive shaft started vibrating. I've got the reconditioned Ryobi 41002 string electric trimmer, and upon inspection, the upper drive shaft burned the rubber type bushings encasing the flexible metal drive shaft. Rubber junk just fell out in pieces,and there was very little plastic covering over the drive shaft. Obviously it got over heated and melted this stuff. I only used it twice for a total of about 5 hours before I noticed the strong vibrations near the motor housing and upper drive shaft casing. I put it away in storage for about a year and just now inspected it because I need it. Is it worth trying to get an upper drive shaft part or should the better part of valor be to just get another one and be more watchful of my year warranty? Thank you, Randy
  • randyrand May 13, 2010
    The solution was somewhat helpful, I just need a little bit more clarification about the dealership suggestion. Randy
    Thank you very much, and your advice makes the most sense, it helps getting some validation for my unqualified hunch that getting a new one would be the better part of valor here. Again, thanks for the quick and most sensible advice, much appreciated. Over and out.........Randy
    President:
  • 1,382 Answers
Hi,Unless you are mechanically minded you can run into trouble it is best to get a quote from your local dealer.
Thank you.!
Posted on May 13, 2010
    I'm not mechanically minded minded. When you suggest getting a quote from a dealer, do you mean on a repair with a new drive shaft or do you mean just getting another 15" electric string weed whacker that has better performance and fewer mechanical problems? Randy
  • Prakash R May 13, 2010
    Well to be more clear with your problem its better you go with the purchase of new one rather than spending a lump some amount of money on repairing your old driver shaft. Even after repairing you might prone to get some problems since you have not used the unit for long days.So opting for a new unit is the better and best solution.
I have the ryobi rlt30ces strimmer and cant find a piston ring anywhere any help???????????????????????
Here is a 30CC Ryobi 2-stroke trimmer. Your ring is item number B-53 in the diagram. The part number is 03179. They have these in stock also. Hope this helps you!
http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Jul 14, 2011 | Ryobi 15" Electric Factory Reconditioned...
Where can I get Ryobi 130R parts?
www.turfparts.com/
www.hammerwall.com
www.m-and-d.com
Jun 30, 2010 | Ryobi 15" Electric Factory Reconditioned...
The electric motor on my Ryobi 137r string trimmer is vibrating, rattling, and has lost power. It sounds and feels like worn out (binding?) motor bearings. Are they available as a replacement part? What...
You likely are spot on with the diagnosis of bearings. But, I would hesitate to say that they are replaceable. Contact a local electric motor shop (alternator, starter, etc) to see if they would be able to change the bearings, and perhaps the bushings as well.
Jun 25, 2010 | Ryobi 15" Electric Factory Reconditioned...
Runs but acts like in bind when gased
Did you recently take the shaft off of the trimmer? If so, you didn't get the drive shaft seated properly. You will have to take the shaft off again and try to seat the shaft again. You may have to pull on the rope slightly as you fit the shaft into place.
Jim
Jun 08, 2009 | Ryobi 15" Electric Factory Reconditioned...
Head will not drive. Can feel it slip between nut and motor.
inside the shaft is a flexible drive cord, at each end is usually a hex or torx head fitting that slides into a sleeve, theese can sometimes strip or even snap off and need replaced. remove one end of the shaft (either the engine or the spool) and the cord should slide right out easily. inspect each end for stripping and to make sure it didn't snap off inside the sleeves.
Sep 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi weed trimmer
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. i
Jul 06, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Jun 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Sep 09, 2007 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
71 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
