Question about HP L1506 15" LCD Monitor
HP L1506 input signal out of range, recommend 1024 x 768 60hz
How to access LCD menu and change resolution to to 1024 x 768 60hz,
budmrtn
  • 11361 Answers
SOURCE: HPL1506 The input signal from pc display foe few
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
Posted on May 21, 2010
  • 19 Answers
SOURCE: Input Signal Out of Range
I have an HP 1730 LCD monitor on a Compaq Presario S5100 desktop PC running Windows XP, up to date on patches as of 2009 Feb 25. For no apparent reason, the "input signal out of range" error message started appearing when the machine switches from boot mode (which looks OK) to regular windows mode. (My configuration does not HAVE a "safe mode" boot, by the way, so the usual advice doesn't apply.) Was the fault in the monitor, or the computer?
Step 1: see whether the computer is actually booting or not. Result: Over the home LAN, I was still able to access the shared directory on the suspect machine. This is good.
Step 2: swap the LCD monitor for an old Compaq MV720 CRT monitor. Result: the monitor does not like the input signal (essentially, the out-of-range error by another name), so the video signal IS faulty.
Step 3: reboot the PC with the analog monitor still attached. Result: the system boots up just fine, so there's something wrong with the way the PC boots with the LCD.
Step 4: swap video cables (without rebooting). Result: the LCD displays the working desktop, so the LCD display is still good, but there's still something wrong with the handshake between the LCD and the PC during boot. But we still don't know whether the LCD monitor is failing to produce the right Plug-and-Play sequence, as it used to, or the PC is no longer correctly interpreting the PnP sequence, so it's mis-configuring the video signal for the monitor.
Step 5: Back everything up, like you always should have been. (Always the last step, after a computer failure. ;-) )
Posted on Feb 26, 2009
  • 415 Answers
SOURCE: it saysmy pc video resolution is out of range
to chabge resolution go to click start
control panel
apperance and themes
display
settings
and down towards lower left hand you'll see screen resolution
then move bar to 1024*768
Mark
Posted on Apr 11, 2009
  • 156 Answers
SOURCE: input signal out of range
Did you mean "out of range". Try reloading video drivers. If that doesn't work, perhaps screen cannot use that resolution.
Posted on Jun 28, 2009
  • 186 Answers
SOURCE: problem with hpl1506 lcd
if your pc display resolution is set to 1024 x 768 and still having this problem... then your LCD control board is faulty. WHat you can do is try to hook up your pc to another monitor and try other resolution setting. If you still get the same error...then you will need to get someone to repair ur LCD...
Posted on May 24, 2010
Pls how can i play my DVD player with my hp 1730 lcd monitor i'v tried connecting through VGA but its saying ''out of range'' what do i do? Help!
The resolution (most likely the 1080p HD) is too high for your monitor
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00477225&lang=en&cc=us&taskId=&prodSeriesId=346693&prodTypeId=382087
. You will need to access the dvd player's menu somehow and reduce the resolution to one that is supported: ideally it should be the 480p SD one that your player surely supports. The exact procedure is in the manual.
Apr 13, 2011 | HP 1730 LCD Monitor
Input signal out of range......my problem...hp w1707
your video card setting may not be compatible with your monitor's capability. you may need to reduce the screen resolution. you need to boot up on safe mode to change this or use another monitor for a while and try to adjust the screen resolution.
Oct 07, 2010 | HP W1707 LCD Monitor
Show on the display input signal out of rang
it is the set resolution. change graphic settings on your computer. probably, reduce the resolution and try untill you get an optimal setting.
Regards
Jun 14, 2010 | HP Pavilion F1523 15" LCD Monitor
Problem with hpl1506 lcd
May 24, 2010 | HP L1506 15" LCD Monitor
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
Try this per HP:
May 20, 2010 | HP L1506 15" LCD Monitor
Jun 28, 2009 | HP Pavilion F1523 15" LCD Monitor
Signal out of range
1: Signal out of range meas the monitor can't handle the input refresh rate. lcd and Tft monitors usually supports 60 and 75Hz refresh rates.
2: The Resolution you are using to view the desktop is too high, this number is depending on the size of the lcd monitor.
a 15" lcd usually runs with: 1024x768 with 60hz
a 17" lcd usually runs with: 1280x1024 with 60hz some of them supports 75hz.
a 19" lcd usually runs with 1600x1200 or higher.
I recommend reading the user manual if you have it, or checking the information on the manufacturer's website.
3: As a solution turn on your computer and after it passes the bios screen press F8 and select VGA mode.
This will enable 640x480 (standard vga) resolution and 60Hz refresh rate, after windows boots up you can change thease nmbers , and windows automatically asks for turning to 800x600 60Hz.
If you want to change the resolution go to: Right click on your desktop, select properties , select settings tab, and adjust the resolution on the bottom of the window.
Hope this helps, good luck.
Nov 10, 2008 | Kogi L7CH Monitor
Cannot remove "input signal out of range"
input signal out of range would normally indicate the the screen resoloution is either too high or too low for the monitor to display properly.
is this on just one game? which version of windows do you use?
Jun 21, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Input Signal Out Of Range
Some monitors have low resolution, that if it doesn't support that resolution then you'll expect an "input signal out of range" message on screen. try to boot on "safe mode" if it works then you have to lower your screen resolution at "display properties" if not then the monitor has a defective data cable. ;)
Oct 30, 2007 | HP Pavilion F1523 15" LCD Monitor
HP L1506 15" LCD Monitor Logo
328 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
