Question about Fender& Standard J Bass Artic
How to remove the noise hazing of fender stratocaster
I think its on the springs of the bridge i saw lately theyre putting some hoss on each spring at the back of strat suddenly i forgot those steps nee
d your help
  • Fender Master
  • 5,603 Answers
I don't know what "hoss" is...
I would probably put some shrink fit tubing over the springs... Another thing I have seen done is to stuff the insides of the springs with felt material to dampen noise.
The noise MIGHT also be worsened right at the loop ends of the springs. Put a tiny bit of lube where the spring loop attaches. Use a light silicone grease like "plumbers grease".
Posted on May 13, 2010
V130147 fender Stratocaster reissue serial number .Im trying to find out what year it was made I think I purchased it in early 90s late 80s
That serial number could be for a guitar was made in Corona California, but it does not give the year, which should be visible on the neck of the guitar.
It could be for a guitar made in the Fuji-Gen Japan plant, in 1996-1997, in which case it should show a neck decal "Made in Japan".
https://support.fender.com/hc/en-us/articles/212774746-How-can-I-find-out-when-my-American-made-instrument-was-manufactured-
Dec 05, 2016 | Fender Music
Woud you check fender serial number z6268670
Your guitar was made at the
Corona Plant (Fender), USA
in the Year(s): 2006 - 2007
Jul 26, 2014 | Fender American DLX Stratocaster V Neck...
I would like to know what year my fender stratocaster custom body guitar serial Number V033170 was Made and its aproximate value
This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
The Year cannot be determined from serial number.
However, you can remove your neck and check the date there.
Worth: $800- $1000
Jul 24, 2014 | Fender Musical Instruments Corporation...
Looking for information on a fender stratocaster guitar
This guitar is from the Signature Series
in the Year(s): 2000
Feb 01, 2014 | Fender Music
I dont know how to put a whammy bar on a fender stratocaster
Look near the near the highest string at the the silver part known as the bridge.There should be a hole right near the bottom of the thinnest string.Take the threaded end of the whammy bar and screw it in clockwise into the body.
Sep 20, 2009 | Squier Stop Dreaming Start Playing...
Bridge problem
There are different tension strings available. Contact your guitar store to find the right weight strings for your guitar as a first step.
Aug 02, 2009 | Fender Classic '50s Stratocaster Electric...
Need help putting my guitar together
The "handle type thing" is a Tremolo or, more often referred to as a "whammy" bar. The thing at the base of the strings is called a bridge. Looking at the strings, there should be a hole to the right of the smallest string. If your "handle" is threaded, stick the threaded end into the hole and rotate in a clockwise motion. Once is hits the bottom of the threads, back it off one turn and gravity will let it hang out of the way while you play. If there are no threads, it will slip in and you will feel a "click" when it's in the proper position.
On the back of the guitar, there is a cover plate that covers the cavity where the springs are located that make the "whammy bar" work. The springs hold tension on the bridge so you can tune it and play normally, but let the "whammy bar" stretch or release tension on the strings when you push or pull it. If you already have springs inside the cavity, the extra spring you have will let you add more tension to the bridge, but you probably won't need it. If there are no springs already installed, you can install your "extra" spring in there to give you the flex and spring for the "bar-handle" to work properly.
To install a spring, loosen or remove your guitar strings, open the cover on the back, and install the spring over the hooks on the bridge and the hook on a metal bar on the other end of the cavity. Replace the cover, insert your "handle", and wiggle-away.
The allen wrenches are most likely for adjustment of the moveable pieces that support the strings on the bridge. The bridge has adjustments for up and down, and forward and back to adjust the height and distance where the string is supported. Don't adjust the bridge supports unless you loosen the strings. It is highly recommended that you don't make any adjustments yourself unless you are familiar with the mechanism. You can adjust your guitar where it's impossible to keep in tune if the adjustments are not perfect. There are usually guitar repair shops close by and offer "set-up" services to get your instrument adjusted properly. It's well worth the money to have it done right, and the service people with often teach you many things that will help keep your instrument playing well.
Hope this helps.
Jim
jimmydsmith@cox.net
Phoenix, Az
Jan 10, 2009 | Fender Squier Std Strat Mn Car
Fender& Standard J Bass Artic Logo
73 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
