Question about GE 24 in. Profile PDW8280JSS Built-in Dishwasher
Dishwasher stops running and won't drain
My GE Profile Dishwasher (PDW8280J10SS) stops running before it has completed draining. I hear it start pumping the water out and can see it go through my garbage disposal. As it pumps I can hear the pump getting louder - like possibly the pump is having to work too hard. After about a couple of minutes and before the water has drained, the dishwasher just turns off. All of the lights on the display are off. (Usually at the end of a cycle, the ''clean'' light is lit.) I've cleaned the air gap, and can't find anything plugging it up.
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
hhf
Posted on Sep 30, 2010
2 Suggested Answers
cesar_quant
  • 74 Answers
SOURCE: dishwasher water comes out of air gap
ur discharge line is to low...try to make a loop
Posted on Mar 10, 2009
GE GLD6700N dishwasher won't drain
remove the drain hose and make sure its not plugged with food debris then hit the drain/cancel button and put the drain hose end in a bucket and see how much water comes out of the end of the hose if any,if the 2 green lights are flashing this too is a clue to this problem,also make sure you can hear the drain pump running when you start it as explained in the above statement
Oct 16, 2012 | GE GLD6700NBB / GLD6700NWW / GLD6700NCC...
Dishwasher won't drain. I made sure the sink drain were clear I don't have a Air Gap. Is there a way to check the drain inside the disherwasher. It started a couple days ago
I would check for obstruction in the drain hose.Take the drain hose off the garbage disposer hold it as low as you can over a pan or bucket and see if the dishwasher will drain centrifugally.If it does I would assume the pump is bad or disconnected.Possibly a utensil jamming it.
May 07, 2011 | GE 24 in. Profile PDW7800 Built-in...
Ge profile dishwasher wont drain. i have already replaced the drain motor. Why wont it drain completely
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
heatman101
Sep 12, 2010 | GE Dishwashers
GE profile dishwasher won't drain. It has happened twice now
Hi
If you can hear a humming noise, then that is the problem due to pump.The pump gets energized but not rotating probably due to something stuck in the impeller. Check for that impeller unit and try to replace it.
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Thank you !!
Jun 24, 2010 | GE Profile PDW8400J Built-in Dishwasher
Common cause of this problem is a partially blocked drain line. Disconnect drain line and make sure entire path is clear, including where it connects to the sink drain or garbage disposal. Also, make sure all screens and the drain area at the bottom of the dishwasher are completely clear.
Sep 21, 2009 | GE 24 in. Profile PDW7800 Built-in...
DW will not drain
If the dishwasher is not completely draining, your dishes probably aren't as clean as they could be either.
Most dishwashers have a filter screen to keep solid food from getting into the pump. This could be stopped up. Also look for kinks in the drain hose.
Aug 21, 2009 | GE 24 in. Profile PDW7880G Built-in...
Dishwasher pdw8280j10ss
clean pump and check fins on impeller..may need pump kit
Aug 06, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
GE Profile PDW8280J10SS: Water won't drain. I
Can you get the water to drain at all in any cycle? If you can, then its possibly the control module .
If you can't get it to drain in other cycles or when you cancel the cycle, then its a possible clog in the drain outlet hose, drain solenoid, or screens.
Here is a good detailed link to check out that explains about it:
http://www.applianceaid.com/gedishdrain.html
Heres another link about general dishwasher draining issues:
http://www.applianceaid.com/drain_wash.html#drain
Apr 16, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
heatman101
Dec 27, 2008 | GE Profile PDW9880NSS Stainless Steel...
GE 24 in. Profile PDW8280JSS Built-in Dishwasher Logo
517 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
