Question about Dell OptiPlex GX150 PC Desktop
I have an older computer and it takes windows 98, what i need to know is how to down load the 98 boot disk onto a cd that is in the lap top it has no floopy disk, my computer has been up graded with windowsxp but i cant even get it to go any where
  • 721 Answers
Www.bootdisk.com try that, but if you had xp on it then get into the bios or press f.1.2 at post & switch it to "boot from cd"(make sure your xp disk is in). It should re-boot & ask to press any key to boot from cd. Continue from there. Trying to put '98 on without a floppy drive can be tricky to say the least. You'll need to find a way to load the windows dos based cd driver, from a cd just to get to the next step of the install. Avoid using 98 unless you really,really need it.
Posted on May 15, 2010
I have my daughters older (small) dell lap top but no one can remember the password to get onto the computer - it is windows XP prossional
Certainly.
Use safe mode always the first choice to recover xp password.
Here how it work:
First, restart your computer, keep pressing F8 before Windows XP loads, then select safe mode and enter, you will see the default administrator account appears in the login screen, click that account and enter your system, go to control panel to change your other account password. When it finishes, restart the computer, log in the related account with the newly created password.
If the method above can't help you ,try to use the Windows Password Reset,it is very easy and safe.
Jun 10, 2012 | Dell Computers & Internet
I forgot my windows password. so i can't get by the operating system. what can i do
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram. Click on one of these links todownload HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Jul 22, 2011 | Dell Latitude D530 Notebook
I dont know how to use my recovery disk for my toshiba lap top
Here are the steps on how to install operating system using the recovery disc
- power on the computer and insert the disc - once the disc is inserted, turn off the computer - press the power button then after 2 seconds tap F12 repeatedly - select the cd/dvd option or ODD (optical disc drive) use the up and down arrow keys - press enter - once you see "press any key to boot from CD" press enter right away
it will show " Loading Windows"
- then after the next phase will be set of on screen instructions, you just have to select the right option.
Jul 09, 2011 | Computers & Internet
My Tashiba Lap Top a45-s150 is corrupt. WINDOWS/SYSTEMS32/CONFIG/SYSTEM. I bought a recovery disc but my computer only goes to this black screen. Help?
For that you need to repair your windows.
Insert recovery disk into cd/dvd rom then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios .
Then go to boot menu and set first boot device as cd/dvd rom then save settings and exit.
Then it boor with recovery disk follow the procedure and choose Repair option for repair windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 07, 2010 | Toshiba Computers & Internet
After a restore of the lap top a message came up of an error after that just a blank page no windows or anything
Try this fix....
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Oct 09, 2009 | Computers & Internet
Need to know how to put songs onto my mp3 player from my cd's
The device requires Widows Media Player 10 or higher in order to load songs onto it. I suggest trying to find a download for it. Sorry I can't be of more help. :(
Apr 19, 2009 | GPX ML648B MP3 Player
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at domnickr@yahoo.com
Mar 21, 2009 | Compaq Presario 1255 Notebook
8510p, reboot virus. crashed system. no system recovery done or
All versions of windows up and including windows vista are no longer supported.
This creates lots of problems trying to recover or install an older version of windows.
An IT friend as a favor may attempt a recovery but will take older versions of software. Mother boards etc can be swapped out etc and some parts/software available on line.
Most commercial computer repair may not be your least expensive choice.
Suggest finding an older computer used with windows 8 installed. Windows 10 takes a different hardware to get good performance and is usually not compatible to older machines.
The used market is filled with very inexpensive computers. Make sure if you elect to find a previously used it has some warranted!
If files are still intact on the old drive you may be able to install drive as a second slave drive and retrieve.
If you attempt to replace drive and do a fresh XP install (original generic discs) confirm that the (Windows Microsoft) numbers on the label of the lap top are ledge-able. The numbers are the licences required to register the software even if the XP is out of date you will likely be required to on line register with Microsoft.
Hope this helps
Jun 26, 2017 | IBM TravelStar 60GH 60 GB Hard Drive
I need to reinstall windows on packard bell imedia 5106
 Because you have a packard bell, I would assume this is a much older system.  You would have to put Windows 98 on it I presume unless you have enough memory to do XP.  Either way you will need one of the Windows CDs to load the software... I ve seen Win98 on Ebay for $50. Once you have the software, you will need a boot disk.. You can download this off the Internet.  What this boot disk does, is it loads the utilities that you need like to format the hard drive and it will also load the cd rom drivers so you can use your cd rom and install windows from the cd... Load the boot disk and once its loaded you can use the format command.  At the C Prompt, type     format C:     It will erase the Hard Drive. Once completed,  Reboot the computer with the boot disk still in. When it gets done you can install Windows. Most times it will assign the cd rom drive a letter. Usually D or E.   When it comes up type    E:\Setup This should start your install.                                                              Joe < Data Miner >
Oct 30, 2008 | Computers & Internet
I have the Windows 98 disk not have lost the key codes, I am trying to reinstall this onto a new hard drive with no operating system so I can then upgrade to windows xp, help anyone?
You don't need a windows 98 disk to install XP. It will load directly from your Cd drive. You have to set the bios to be the first boot disk. It is much easier to install XP on an empty drive than to upgrade.
Apr 18, 2008 | Computers & Internet
Dell OptiPlex GX150 PC Desktop Logo
51 people viewed this question
Alun Cox
