Question about Whirlpool 24 in. ADP5740 Free-standing Dishwasher
Dishwasher not working
My dishwasher isnt working anymore . it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. when you start it the bottom fills with water and after rhe cycle has finished the water is gone so no issues with it being blocked i imagine.
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
  • Whirlpool Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 14, 2011
Tablet keeps coming out of the dispenser on my hotpoint fdl 570 dishwasher on all cycles and falls on to the floor, result is that the crockery isn't always clean on the top tray. Machine is still...
Hi Jeanette,
Maybe I misunderstood your question, but the tablet is supposed to come out of the dispenser and fall into the bottom of the dishwasher. It needs to fall into the hot water in the bottom of the washer to dissolve. The dispenser releases the tablet at different points in the cycle depending on which wash cycle is selected. On a shorter cycle it will be released soon after starting. On longer cycles, there is usually a rinse first, so the tablet will be released a little later. There would only be a problem if the tablet wasn't being released, or wasn't dissolving completely.
There are a number of reasons for poor cleaning on the top rack. The most common are the upper spray-arm not spinning, incorrect stacking or overloading. If the upper spray-arm isn't spinning, there may be caused by a blockage in the spray-arm or the water delivery system, but, as the dishwasher is new and it's not happening every time, it's possible that the dishwasher isn't levelled correctly. The spray-arms aren't motorised, they use water pressure to spin, but they wont spin if they aren't balanced, i.e. the dishwasher isn't level.
You can check whether the spray arm/s are spinning by pointing them front-to-back, or left-to-right (so you can remember the position) and allow the dishwasher to run for a few minutes. Then open the door and check the position of the spray arms. They should continue to rotate slowly for a short while after opening the door, but if they're in the same place and static, they're not spinning. I'd suggest repeating this a couple of times to eliminate the possibility of them having stopped in the exact same place you left them.
If the spray arms are spinning, test the dishwasher with only a small load in the top rack. If the top rack comes out clean with a small load, you may be overloading it or stacking it incorrectly some of the time. There should be a correct stacking guide in your user manual.
Hope this helps. If you need further assistance, check whether the arms are spinning then post back.
Regards,
BElectric
Jul 03, 2011 | Dishwashers
Dishwasher does not clean dishes. Some soap remains in soap dish. Have tried on the enrgy saver cycle and 1 hour cycle.
Hi jerry1413,
Firstly, make sure you are using powdered soap, and not the 3 in 1 tablets. The 3 in 1 Tablets only release certain parts of itself on certain temperatures, and because all dishwashers aren't alike, they won't have the best of results on all makes & models. Cycles aren't run the same way on every Make, and don't follow the same order either. Trust Me ;-) , stick to Powder.
Furthermore, check the following link for some advice and suggestions on getting your dishwasher to clean properly again:
WHAT TO DO IF YOUR DISHWASHER ISN'T CLEANING WELL ANYMORE...
Kind Regards :-)
* If you found this solution helpful, please rate it?
Jun 18, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I am getting no water in the dishwasher, it goes thru the cycle and spits out the tablet.
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Oct 06, 2010 | Bosch SHV68 Built-in Dishwasher
Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Tablet falls out & doesn't dissolve especially on fast cycle
Hi and wlecome...
You should not use anything other than powered dishwasher detergent in these products. They are not designed for tablet-style detergents. The reason is because the dispenser does not "open" during the wash cycle like you would see on a conventional dishwaser. The incoming water pours over the detergent and releases the mixture out the bottom of the dispenser. If you need a user guide, you can get one here: http://fisherpaykelparts.net/index.php?blockitemid=29
Jan 22, 2009 | Fisher and Paykel 23 in. DS603H W Built-in...
Bosch Exxcel Dishwasher
no not if it getting hot it still sounds like the motor isnt coming on put the spray arms in the same position turn it on then open the door are the arms still in the same position or haved the moved.those cleaners need hot moving water to melt the seal.
Aug 30, 2008 | Dishwashers
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwasher tablets not dissolving
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Apr 10, 2006 | Bosch 24 in. SGS66E02 Exxcel Built-in...
Whirlpool 24 in. ADP5740 Free-standing Dishwasher Logo
315 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
