Question about Ricoh Aficio 1018D Copier
Do we need CD installer if we will use this machine as computer network printer
    Guru:
  • 1,049 Answers
It depends, you will need the drivers either from the CD or from a folder on a network share no matter how you setup the printer when you're printing directly to the printer.
But if you attach one Windows machine to it and then share it, the computer will install the driver automatically when you attach to the shared printer on that machine as long as the operating systems share the same driver.
Furthermore, you can also install the driver for other operating systems in the printer properties.
Posted on May 13, 2010
My computer latitude E6430 is not conecting to Brother 7420 printer?
Install the Brother Software suite on your computer. Since the printer does not have a network interface you must use the USB interface. Use the CD that shipped with the machine to install the software suite, including the drivers. For the type of printer select USB printer.
Here is the link to the manual, if you need it.
http://download.brother.com/welcome/doc000388/ALLFB_UsaEngQsg.pdf
Dec 25, 2013 | GPS
The network won't set up for the x464de
usually you must install net program on cd machine in your computer after than change your set up on your network.always to set up network for copy hard but after that you install cd program you can do it
Nov 27, 2013 | Lexmark X464de Multifunction Laser Printer...
I have Konica Minolta bizhub 350. My computer is already detected bizhub 350 but not print Thanks
When your computer has detected the photocopier machine, then the next step is to install the drivers, which you may find in CD-ROM or you can Google it.Drivers are easily available on the internet.Download the drivers, Install the printer and then execute print command.It will surely work. If you want to use it as a single pc printer then its ok, if you want to use it over network, as a network printer, then you have to assign IP address to machine.
Mar 26, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Can i scan over the network on a deskjet f380?
Yes, but the configuration needs to be a network, rather than hosted and shared, setup. After you get the printer connected and working on the network, you need to install printer on each machine, much like if that computer was going to host the printer, then look for the network printer, and good to go...
Network printers work much better and do not require a host computer, after set up.
Nov 04, 2010 | HP DeskJet F380 All-In-One Printer
I NEED TO INSTALL THIS PRINTER MFC-7420 on my laptop which do not have cd rom player
You have several options to do this:
- If you have spare PC, you may copy the content of the CD to a USB disk and install from the USB disk on the laptop
- Or you may just insert the CD on another computer on the network and share the CD-ROM drive by going to My Computer-Right Click on the CD Drive and click share. Now on your laptop go to My Network Places (usually on Control Panel) where you can see the shared CD drive from your other machine.
- Or if your laptop has internet access, visit Brother website and type your printer model to download the driver installer on your laptop machine.
Good luck and hope this helps.
Nov 03, 2010 | Brother MFC 7420 All-In-One Laser Printer
How do I change the ip address of the Dell 1720 dn printer to work with my network?
Ok the following instructions will help you reset the ip address of your printer however you must use the origina driver cd to do this. Follow the instructions below if you have no print server involved with this network. If you do use a print server let me know ok?
Print and Check the Network Setup Page
  1. When the Ready/Data light is on solid, press and release Continue to print a menu settings page and a network setup page.
  2. Under the Standard Network Card heading on the network setup page, make sure Status is Connected.
If Status is Not Connected:
    • Make sure the Ethernet cable is firmly plugged into the back of the printer.
    • Plug the Ethernet cable into another wall outlet.
  1. Under the "TCP/IP" heading on the network setup page, make sure the IP address, netmask, and gateway are what you expected.
  2. Ping the printer and verify that it responds. For example, at a command prompt on a network computer, type ping followed by the new printer IP address (for example, 192.168.0.11):
ping xxx.xxx.xxx.xxx
If the printer is active on the network, you will receive a reply.
  1. If your printer doesn't respond, or if the IP address is not what you expected:
    1. Insert the Drivers and Utilities CD into your computer.
    1. The Drivers and Utilities CD should launch the installation software automatically.
If the CD does not automatically launch, click Start® Run, type D:setup.exe (where D is the drive letter of your CD), and then click OK.
    1. When the Drivers and Utilities CD screen appears, click Set IP Address Utility.
    2. Select your printer from the "Configure Print Servers" list, and then click TCP/IP Settings.
    3. Make the necessary changes, and then click OK.
    4. Click Close.
    5. Print and check the network setup page to verify your changes.
Install Printer Drivers for All Clients
  2. The Drivers and Utilities CD should launch the installation software automatically.
If the CD does not automatically launch, click Start®Run, type D:setup.exe (where D is the drive letter of your CD), and then click OK.
  1. When the Drivers and Utilities CD screen appears, click Network Installation - Install the printer for use on a network.
  2. Select Install printer on one or more remote computers, and then click Next.
  3. Enter your Administrator user name and password, and then click Add.
  4. Select the clients or servers, and then click Next.
  5. Select the network printer you would like to install, and then click Next. If you do not see your printer listed, click Update to refresh the list or click Add Printer to add a printer to the network.
  6. Select your printer from the list. If you would like to change the printer name listed, enter a new name in the Printer Name field.
  7. If you want other users on the network to access this printer, select Share this printer with other computers, and then enter a share name that users will easily identify.
  8. Click Next.
  9. Select the software and documentation you want to install, and then click Install.
  10. When the Congratulations! screen appears, print a test page to verify the software is installed correctly.
  11. Click Finish to exit.
Aug 09, 2010 | Dell 1720dn Laser Printer
How do i download my printer on 2 my computer without the disc
Go to the manufactures website and download the drivers (software needed for your hardware to run) for your printer..drivers usually are free.
hope this helps.
Oct 22, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
I have connected mac to it and can't get the scanner to work`
kindly install the scan driver and software to your locla computer, if you connect its as a netowrk printer kindly install the network devices cd in your local machine and add the network scanner.
Oct 05, 2009 | Samsung SCX-4828FN All-In-One Laser...
How do i build a local area network in windows xp?
On the machine that the printer is connected to go to Start>Control Panel>Printer and Faxes>Right click the Printer that you want to Network and Left Click Sharing> Select the Option to Share the printer and Name it something that you wil remeber. On the Laptop go to printers and Faxes select add new printer and select Network Printer. And Choose the second option Put the Name of the Computer that the printer is connected to and then printer name. Example \\Desktop\HpPhotoSmart 8100. Also you will need to check to make sure that both machines are on the same Domain\Work Group. Go to Start>Control Panel >System>Computer Name Tab ( Here verify the Machines Name)> Join or Change Domain>Put the machines on the same Workgroup if they are not, Do the same on the laptop. To test this, on the laptop go to Start>run and type \\Desktop Name and you should see what is able to be shared. Walk thru the steps above to install the printer on the laptop and have the intall cd in the laptop to install the drivers and you should be good to go. I hope this is understandable. If not feel free to email me at smichael@phoenixschool.net and I will see if I can clarify this for you. Happy networking!
Dec 02, 2008 | Computers & Internet
HL-2070N Network configured setup questions.
The printer software u got is for vista machines only and can't be installed on the xp machines.to install it on xp machines u need xp supported software.
Click here to download the xp software of printer and then install it on ur xp machine and ur problem will be solved..
Goodluck,
Don't forget to rate me as fixya..
Feb 02, 2008 | Brother HL-2070N Laser Printer
55 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
