Question about Mitsubishi WS-65611 65" Rear Projection Television
How to get the best color, sharpness, contrast adjustment on my mitsubishi ws 65611 tv
  • Mitsubishi Master
  • 12,061 Answers
Ws-65611 color shadows
You need to turn down the voltage on all 3 crt's. You have a red one, a blue one and a green one. Slowly adjust the knob down until you don't see the shadow any more. Then adjust your color in the user menu.
Aug 21, 2012 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65611 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65611 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65611 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Mitsubishi WS-65611 Repair kit from TV-Repairkits.com no fix.....
I have a few ideas but they all will require some more information from you. I know these sets very well-if you fixed the convergence problem my hat is off to you--it can be a do it yourself job but not the most easy set to do it on.
Let me assume you adjusted the convergence in the customer mode--it does on any of the HD models have to be adjusted in the regular and then the HD modes.
The only other thing here that may be the problem is FOCUS. A simple way to determine this is to remove the back cover--turn the set on and call up the advanced convergence grid---then cover the lens for each tube one at a time--with red and blue lens covered are the lines in sharp focus or look blurry?
Repeat this with only red or blue not covered and see what you think--if one of the tubes is out of focus you will see it there--
There is also a TECH menu for adjusting the convergence-like the customer menu but it saves the adjustments into the set's memory--you will need to hit menu and a four digit code based on the actual model number of the set.
Check to see if focus is or is not your problem-easy to tell--green, red, blue lines will either be sharp or out of focus--if out ask and I will tell you the simple way to adjust that.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 22, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WS-65611 has a blurred image with the colors creating almost a double image. was told it might be a color wheel. Should i order a new one? Best Buy said it would be a $150 house call to...
The model number you have posted does not have a color wheel at all.
If it is WS-65611 go into the customer menu and select convergence--if it is 3d and will not adjust there--you have a convergence problem.
I HAVE AVAILABLE START TO FINISH, STEP BY STEP INSTRUCTIONS for replacing this part in this set--available here for free.
If someone told you it is a color wheel and you have the correct model number here posted--they are not very smart--this model does not have a color wheel and the later Mitsubishi sets that did have one--they do not sell the color wheel for them.
If you want the instructions let me know and I will post them here for you. I have repaired hundreds of these sets and the instructions are based on actual experience doing this repair.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 14, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Download Mitsubishi WS-65611 HDTV Manual
Have you misplaced your Mitsubishi WS-65611 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65611 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Tip
I hope that helps.
on May 04, 2010 | Televison & Video
Mitsubishi ws-65611
the buttons on the front have shorted. replace the volume plus button.
Mar 01, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Tip
I hope that helps.
Tip
I hope that helps.
Mitsubishi WS-65611 65" Rear Projection Television Logo
154 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
