Question about Hunter "Lexus" Traditional 52" Ceiling Fan "Black" w/ three Blade Choices
Fan moves very slow what is the promblem?
Fan moves very slow. you can hear it on but wont turn until 45 seconds to a minuet
  • 389 Answers
Sounds like you need to oil the fan shaft. They get dusty and dirty and it gathers in the oil that was in it.
add more oil and it should fix the problem. THE RAZ
Posted on May 13, 2010
1996 olds aurora runs hot when idling or low speed normal at fast speed what could the problem be
If you have a viscous fan hub The one where the fan spins free on the water pump then the symptom you describe is a result of it not working any more. With the engine cold start the engine and run at around 2000rpm If the fan is working properly you will hear the air noise from the fan for a few seconds then the noise will dissapear as the fan slows down. When the engine is hot viscous fluid ( silicon ) is pumped from one side in the fan hub to the other creating drag which makes the fan spin and draw air through the radiator. If this is not happening then the fan is stalled by the load of trying to move air and as such the temp rises. As you move off the air flows through the radiator and the fan becomes useless until you stop again. Noemal fix is a new viscous hub. If you have electric fans check that they are working as planned
Jan 11, 2013 | 1996 Oldsmobile Aurora
My 6100 has been overheating a lot lately, so I opened it up and followed ubercam's cleaning instructions. Everything went just fine. I put everything back together, turned it on, and then nothing. It...
my whirlpool awm1203 washing machine wont turn when the timer moves on to the next setting the dial moves then you can hear it click but doesnt turn on
Jan 09, 2011 | Computers & Internet
HP DV7 laptop turns off after about 45 seconds.
it is graphic card problem, its very common in dv7, the display chipset fail to render properly and system turn off, if system under warranty ask them to replace bec its very common and if warranty is near to end then definately go for extended warranty.
Feb 08, 2010 | HP Pavilion dv7-1129wm Notebook
Electric engine cooling fan switches on for about one second only
thats sound normal..like i always say if it's not broke don't try to fix it..
Dec 04, 2008 | 2001 Subaru Forester
Ps3
No if you have no sound/ video its just at the main screen and wont start up so the fan willl spin slow and you wont hear it..
shut it off then turn it on and wait for the red light to appear.
Push and HOLD the power button down until you hear it beep.. eventually it will reset itself and the screen will appear.
IF you do have a/v then you need a new fan costs 30$ PLUS shipping let me know if you need one!
Jun 30, 2008 | Sony Playstation 3 (PS3) Console
Waher maytag
Pull your washer forward then tilt the top backwards until it sits at about a 45 degree angle. There should be a belt and 3 pulleys underneath. Remove the belt (one of the pulleys will move to allow slack) Ignore the moving pulley and the large pulley in the center. The third pulley is your pump. Try to turn it by hand, it should move freely. Presumably, it wont and will need to be replaced.
May 26, 2008 | Amana NAV5800A Top Load Washer
My sansa wont turn on or do anything
Powercycling usually takes care of it with the e200
Hold the menu/power button down for 45 seconds and continue to hold it regardless of what it does.
after 45 seconds, let go and wait 15 seconds, not hold the power button down to the count of 1-2-3 and let go.
It should come on
Jan 25, 2008 | SanDisk Sansa e250 MP3 Player
Hunter "Lexus" Traditional 52" Ceiling Fan "Black" w/ three Blade Choices Logo
824 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
