Question about Apple iPod MA446LL/A MP3 Player
When I connect my Ipod to the Laptop, Ipod is not recognized by either by itunes or its not showing as a disk. Only black 'apple symbol' is displaying in the Ipod. What is the solution for this ?
  • 600 Answers
Have you done a reboot on the iPod? my iPod is older so I wont confuse things with its reboot please check your instructions,
Posted on Aug 25, 2010
My ipod shows a connect to itunes symbol. When i connect it, it says "Itunes could not connect with the ipod 'ipod touch' because it is locked with a passcode. But my ipod wont let me type in the...
1. Reset or restore your iPod for a try, this can fix many general iPod problems. 2. You may try this iTunes alternative, I always use it to upload music and video to my iPod once my iTunes can't recognize my iPod, my friends recommend it to me, it's safe and works pretty well, you can also use it to copy music and video from ipod to computer for backup, it's useful when you lost your iTunes library. 3. Update your iTunes to the latest version. Plug in your iPod. If iTunes can't recognize it, then in iTunes in the top left corner click help> run diagnostics. On the box that comes up, check the last two things. Click next and it should identify your iPod. I got this method from Apple technical support. Hope it helps. Contact me if you have any other question.
Apr 06, 2011 | Apple iTunes
Tip
How do I Enable Disk Management for the iPod Touch
<p>If you want to use Disk Management to partition and format the iPod Touch, you must enable disk use on your iPod. By default, Apple iPod products configured to work with Apple's iTunes and not as portable drives on your computer. You can use iTunes on your hard drive mode to allow your iPod, allowing the computer to deal with and recognize the iPod as a portable unit. <br /> <p>1. Connect your iPod to your computer using the USB cable for iPod. <br /> <p><br /> <p>2. Launch iTunes. Select your iPod from the "Devices" from the iTunes browser. <br /> <p><br /> <p>3. Click on the "Summary" tab in the main iTunes window to change the settings for your iPod. <br /> <p><br /> <p>4. Go to the bottom of the Settings window and check the "Enable Disk Use". The computer recognizes the iPod Touch as a portable disk. <br /> <p><br /> <p>5. Quit iTunes. Run the Disk Management and check the disk devices connected to ensure that your iPod is displayed as a portable unit. <br />
on Aug 08, 2011 | Apple iPod touch
My ipod shows only white screen when i disconnect it from my laptop. when its connected its black it shows nothing.
play the ipod (kill the battery... let it die out) ... make sure you have the latest Itunes version.. once Ipod is dead plug back to laptop........ Itunes should show on screen and Ipod as well.....
now please note for future references always eject the ipod from laptop using Itunes eject on the left side of the screen........
Jan 11, 2011 | Apple iPod Photo MP3 Player
My i-pod touch has frozen and when i connect it to my laptop a symbol of u usb and itunes sign come up? I cant restore it to factory settings either because it isnt showing up in itunes
You need to do a complete restoral. Try This:
Try plugging it into your computer. Press and hold both the sleep and home buttons
at the same time until the screen goes black (can take longer than 10 seconds) then
let go of the sleep button (the button on the top of the unit) while keeping the
home button held in (the button on the front of the iPod). Keep the home button
held in until your computer recognizes new hardware. You should hear some sort of
sound coming from your computer speakers. That and the "installing new hardware"
notice should come up in your taskbar (this is where you computer shows the clock).
Let go of the home button once this happens. Open up iTunes and then restore it.
Feb 25, 2010 | Apple iPod touch
When i got done chrging my ipod it froze
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
Resolution If you experience any of the above issues, try the following steps:
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
Dec 17, 2009 | Apple iPod Photo MP3 Player
New iPod Nano 4G won't connect to iTunes.
Hi Paige,
  • First reset the device by pressing and holding Menu & Select till the apple symbol appears
  • Next check the USB port on both the PC and ipod are clear of dust etc.
  • Download and install the latest iTunes from the Apple site.
  • Connect the ipod to a USB port directly on the back of your PC (ie, not a USB hub or keyboard etc.)
  • If iTunes recognises it (properly or improperly) and suggests an ipod software update, do this.
  • On the main ipod page of iTunes press the restore button and choose the bottom option (if it gives you any) to restore the ipod to manufacturers settings.
  • After a couple of restarts once its done it should be fine.
All the best
Sean
PiDigital
Dec 25, 2008 | Apple iPod nano
Black and white screen and not recognized.
try this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
note in the end of my post there is the online service assistant where you can check your warranty and setup repairs with apple if required.
Jul 28, 2008 | Apple iPod MA446LL/A MP3 Player
Apple Ipod Classic-Itunes won't recognized Device
stupid question i know but please make sure you hve downloaded the correct countries version of itunes - here in aust a lot of ppl accidentally download english version - it dont work. try uninstalling and reinstalling itunes if that doesnt work and try reseting unit itself - menu and centre button hold both down untill apple icon appears.......
Apr 24, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod help
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
Feb 11, 2008 | Apple iPod 3rd generation MP3 Player
My Computer and iTunes does not recognize my iPod
hold down the middle button and the Menu button until the apple icon came up on my iPod. At once, the iPod icon returned to my desktop AND on my iTunes window. Works great now. Just like nothing happened.Good Luck!!!!!!!
Jan 11, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
37 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
