Question about HP G60-120US Laptop
When switching on, there is sometimes an ?alarm?
When switching on my HP laptop, there is sometimes an ‘alarm’ sound that can only be stopped by removing the battery.
  • HP Master
  • 12,061 Answers
That alarm you hear is usually the Flat battery Alarm, you need to connect your PC to the Wall supply, IF it still does it, most likely your battery maybe need to be reset, or a new one obtained. http://digg.com/hardware/Tutorial:_How_to_re-calibrate_your_Laptop_Battery_
Check this link above...
Posted on May 13, 2010
Tip
TGHK watch instructions
This is not for Tag Heuer, it's for TGHK watches.Here's the procedure: Press the MODE switch to step through the modes until you see the seconds blinking (righter after the ALARM set mode). Press the RESET switch to advance to the function you want to change (e.g. hours). Press the START switch to increment the hour to the correct time. Press the RESET switch to advance to minutes and, again, increment the setting using the START switch. (Hold the switch down to advance the numbers rapidly.) When you have stepped through all the elements and have everything as you want it, press the MODE switch once to return to normal time display. To set the ALARM: Press the MODE switch to display the alarm function. Press RESET once to see the hours blinking. Press the START/STOP switch to advance to the desired hour. Press RESET to advance to the minutes and set the minutes using the START/STOP switch. Press the RE#SET switch. The time will stop blinking. Set the alarm sound for either ALARM or CHIME using the START/STOP switch. Press MODE to return to the time display. To turn the ALARM off: Press the MODE switch to advance to the alarm mode. Next to the AL indicator there will be either a small ALM or CHI displayed. Press the START/STOP switch until they both are off. Press MODE to return to the time display.
on Mar 18, 2010 | Watches
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
HP chimes or alarm bells ring every few minutes. Why and how can I stop it?
Go to control panel and click on sounds and change sound scheme to no sound here the pic for reference. 6815fe2c-869c-41fa-b83a-2afc30214d94.jpg
Feb 14, 2014 | HP Computers & Internet
My ford mondeo lx petrol 98' alarm goes off, sometimes more than once i have to keep going to the parking lot to open and close the door only for the alarm to stop but after some time it goes off again.
Your problem is most likely the central locking / alram switch fitted aroun the door lock inside the door void. Try using the passenger door to lock / unlock. If this stops the alarm triggering then you need to replace the switch behind the lock in the drivers door.
Feb 16, 2011 | Code-Alarm Code Alarm Transponder
How do you set aliam on my nokie e51
Got ot the link below page 67-68 will tell you how to set the alarm.
http://nds1.nokia.com/phones/files/guides/Nokia_E51_UG_en.pdf
Or
Alarm clock
Open the alarm clock tab.
To set an alarm, select Options > Set alarm. When an
alarm is active, is displayed.
To switch off the alarm, select Stop, or to stop the alarm
for 5 minutes, select Snooze. If the alarm time is reached
while the device is switched off, the device switches itself
on and starts sounding the alarm tone. If you select
Stop, the device asks whether you want to activate the
device for calls. Select No to switch off the device or Yes
to make and receive calls. Do not select Yes when wireless
phone use may cause interference or danger.
To change the alarm time, select Options > Reset
alarm.
To remove the alarm, select Options > Remove alarm.
Good luck please rate 4 thumbs up and please leave a testimonial.
Oct 28, 2010 | Cell Phones
Alarm stopped working
sounds like the system is in valet mode.
locate a switch under dash if a toggle switch is found then turn on key and flip switch. turn key off if led is off try alarm.
If a push button switch is found then turn ignition on and press the switch for 10 seconds, then turn key off iff led is off try alarm.
Sep 22, 2009 | Vehicle Parts & Accessories
Laptop sounds alarm 30 seconds when turned on
your system has got Viruses. Better you Re-install the OS after formatting your Hard Drive. Your problem will be solved.
Feb 04, 2008 | Acer Aspire 5050-3242 Notebook
My compaq laptop freezes after 30 minutes
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. Have you expierenced that problem also? There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
Nov 27, 2007 | HP Compaq nx6110 PC Laptop
HP G60-120US Laptop Logo
168 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
