Question about Maytag MMV5156AAS Microwave Oven
Steamed out the control panel? - Maytag MMV5156AAS Microwave Oven
    President:
  • 1,796 Answers
Hi!!
Repair and parts for a microwave oven, (exept replacing the light bulb) are so expensive that I recommend just getting a new one. I fixed a couple myself and after one thing comes another one. Better off buying a new one.
Don't forget to rate this post. Good Luck.
Posted on May 13, 2010
Panasonic microwave NN-P295 display shows extra digit or letter like clockK, PressS and 12:322? Any ideas?
I would first try a hard reset by unplugging the oven a couple of minutes, then plugging it back in, setting the clock, and trying again.
If that didn't work, I would wonder if there is grease or moisture on the controller.
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information.
* on the tag in cooking cavity or around door frame or control frame or on back
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 04, 2017 | Panasonic Microwave Ovens
The vent will turn on randomly and not turn off!
Most over the range microwaves have a heat safety system built into them. If for instance you are cooking on the stove top for a long period of time on the burner directly under the micro control panel and the control panel get too hot, a thermostat in the microwave will automatically turn on the vent fan to help keep the control panel cooled off. My guess is that the safety thermostat (usually right behind the bottom of the control panel) may be going bad and needs replaced.
Apr 03, 2015 | Kenmore 30" Microwave Combination...
Microwave steams up and turnsoff
Hello friend, thank you for your inquiry!
If your Frigidaire microwave is steaming up and turning off it could be a possible problem with moisture getting into your control panel. I would suggest having a professional technician come out they can perform a proper diagnosis. I hope this is helpful. -Matt
Feb 12, 2015 | Frigidaire Microwave Ovens
Vent fan wont turn off
Steve,
The vent fan is thermostat controlled to protect the control panel. Once the panel temp drops, this will turn off by itself. This is normal for this to occur when your steaming and cooking for a long time. Good Luck
Apr 22, 2014 | Maytag Over-the-Range Microwave
Door switch not making reliable contact, is there a door adjustment procedure? Panasonic NNCS597 steam microwave
If you take off the cover panel, you can see the microswitch and its adjustment slot on the control panel side. This can be adjusted to operate correctly.
Apr 05, 2011 | Panasonic NNCS596S Microwave Oven
My stainless frigidaire range was on broil when all of a sudden the panel where the clock is get blurry,shows F1 and beeping.
That sounds like steam is condensing on the control panel. Are all of the fans working and is the exhaust clear?
Mar 01, 2011 | Microwave Ovens
The touch pad does not work
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, you probably have a failed membrane keypad.
Is it possible that some spray cleaner or steam accidentally got into the controls?
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
But please note that for some models, the membrane keypad is not
available as a separate part, so you would have to order the control
panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself
job.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
http://www.microwavedisplay.com
May 26, 2010 | KitchenAid KHHS179LSS Convection /...
Keypad does not work after steam hits it
Keypad failure can cause it to come on by itself, which can lead to a fire.
prototech@usa.net
May 24, 2010 | General Electric Microwave Oven
Microwave oven panel starting beeping from and doesn't work
You either have a shorted keypad or another problem with the control panel assembly.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Always spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Always use the vent fan when cooking on the stove top to keep steam and grease out of the controls.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Nov 23, 2008 | Whirlpool Microwave Ovens
The interior fan in my microwave stopped working. I could still use it but it would steam up. It stopped working comepletely now.
The interior (cooling) fan is critical to keep the magnetron cool. If it fails the magnetron will overheat.
This can cause it to trip the thermostat or thermal fuse, which will make the oven dead. If the magnetron is overheated too long of too often, it will be destroyed.
By contrast, the hood / exhaust / vent fan is important for keeping steam and grease out of the controls of your microwave.
The hood fan can fail due to problems with the motor or the control panel.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
We even have a video on our site that shows you how to safely & easily remove the control panel assembly in less than 5 minutes so you can check out your oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 23, 2008 | Maytag Microwave Ovens
Maytag MMV5156AAS Microwave Oven Logo
63 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
