Question about Maytag 24 in. MD5600 Jetclean II Built-in Dishwasher
Dish soap is not dissolving - Maytag 24 in. MD5600 Jetclean II Built-in Dishwasher
  • 4 Answers
First try a different brand of soap. Check that the soap door has opened about half way through the wash cycle. You may need a water softener.
Posted on May 13, 2010
SOURCE: GE Nautilus Soap does not dissolve
The Water Inlet Valve is not Working. This is a small piece at the bottom of the dishwasher where the inlet hose connects to. The Valve is stuck and water will not enter the dishwasher itself. Of course this is one of the most expensive pieces of the dishwasher to replace!
Posted on Jul 26, 2008
  • 423 Answers
SOURCE: Dishwasher wont dissolve soap and not washing properly
The make and model number can probably be found around the door edge (usually right side) If you can find it, post the make and mode # here.
Recommend you get a box of brand name detergent powder (like Electrosol or Cascade) and begin only using that. (Neve use gel or tablets) Cheap Cheap, generic detergent does not dissolve properly, leaves residue of its own and cleans poorly.
If problems continue, check the heating element as it is very possible that it has failed and the dishwasher needs to get to the proper temperature to activate the detergent. Also check to see if the holes in the spray arms are not blocked with debris.
If the heating element is working, then the wash pump motor has begun to fail and you need to decide to replace it or replace the entire dishwasher.
Posted on Apr 08, 2009
  • 630 Answers
SOURCE: Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Posted on Jul 02, 2009
  • 96 Answers
SOURCE: dity dihes not getting rinsed
your food trap is pluged take the screan off the sump and clean it out. if that dont work your pump is getting week
Posted on Dec 06, 2009
Testimonial: "thanks for the great advice"
sparkyuiop
  • 91 Answers
SOURCE: Our dishwasher is not cleaning dishes well and the
Make sure you have the salt filled up. If you do then it is probably caused by a blockage in the plastic tube matrix inside. You can repair this yourself with a bit of confidence and common sense.
Posted on Jan 12, 2010
Why is my soap not dissolving in the dispenser
could be a few things, could be the spray arms aren't turning and washing the soap out more likely tho is it isn't heating properly as this is the main thing that dissolves the soap and washes the dishes, are the dishes hot when you open the dishwasher?
Oct 07, 2014 | Samsung Dishwashers
Dishwasher does not dissolve soap
If you have hard water, use only a little bit of soap. And you will probably need to add a rinse agent too. The government recently outlawed phosphate in detergent - now most detergents don't clean very well and don't dissolve either. This map shows the hard water regions in USA:
http://www.citriclean.net/why-citriclean/
Mar 16, 2013 | Dishwashers
Dishwasher soap is not dissolving.
Try emptying the dishwasher and putting a few tablespoons of vegatable oil in the bottom. Run the cycle without soap and no dishs. Often dish soap (palmolive) builds up and creates soap suds that won't go away during a normal cycle. The oil binds with the soap residue to get rid of it. It worked for my Kenmore. I know do it every few months. Good Luck!!!
Thanks
Jun 22, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Dishes not clean, soap not dissolving completly(powerball tabs and cascade gel)
first step would be to cut your soap usage in half. To much soap will cause the problems above.
Jun 10, 2010 | Maytag MDBS561AWS Stainless Steel...
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Help! My dishwasher doesn't rinse soap off my dishes anymore
try a few applications of jet dry DISHWASHER cleaner to remove excessive build up of calcium/hard water deposits...sounds like the water temperature is too low upon the initial fill cycle to assist in dissolving the soap.the water temp. must 125 degrees to insure soap activation/ and dissolve it.check for obstructed spray arm as well
Mar 06, 2010 | Frigidaire 24 in. PLD2850 Built-in...
What is happening, is that your dishes are washing dry. Start the dishwasher and slowly turn the timer till it starts to fill. Let it go and see how they are after
Jun 20, 2008 | GE Nautilus 24" Built-in Dishwasher
Tablets not dissolving
Sounds like whatever soap you are using is just too much soap your dishwsher can handle. The soap "packs" are usulally an overload of soap for most dishwashers. Just a few teaspoons of regular name brand soap sometimes will cure lots of dishwsher ills!!!
Apr 12, 2008 | Zanussi 18 in. DA4342 Free-standing...
Dishwashers Logo
87 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
