Each time its turned on, i unable to change the channel and nor will it remain on, it just keep shwing please wait but when it attempt to come on , it repeats itself and return to please wait
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Assuming this to be a LCD TV, from what you have described it seems the issue is with the power board or the main board and we’ll need to check few things. When you open the unit up; take a look at the power board-the board where the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all the inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 13, 2010
  • jamestownes May 13, 2010
    I don't have the expertise to repair the problem and because the tv was purchased on May 12, 2010, I will return it back to Best Buy and see if they will repair or replace. Thank very much for your assistance. Please discontinue the subscription. I am obligated to pay the $9.99. Thanks.
    James R. Townes
Error code 204038
Error Code: 204038
The Wii console was unable to connect to the Wii Shop Channel.
  • Check for wireless interference, which can affect the signal strength to the Wii console. To help minimize wireless interference, try the following:
    • Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Wii console is an open area without objects or electronics blocking the signal. (For instance, if the Wii is placed in a crowded entertainment center, try moving the Wii somewhere with more room.)
    • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
  • There could be a temporary network issue with Nintendo's servers. Please wait a few hours and try to access the Internet Channel again.
  • If the above steps did not resolve your issue, please call 1-800-255-3700 for assistance.
Jan 26, 2014 | Nintendo Wii Console
This problem never happened before , We on the tv and the channels keep changing by it self . We are not touching any buttons and we even tried offing the tv and switching the power off . Each time we on...
As a test, block its (or the cable Box's) remote infrared sensor so even you can't change the channels with a remote. Then watch and wait. If it keeps happening, you have a poltergeist or a defective unit.
If not, something out 'there' is emitting infrared signals that the unit interprets as channel commands. Find the remote someone is sitting on or that guy across the street who's aiming at your TV with HIS remote.
Mar 06, 2011 | JVC Audio Players & Recorders
When I turn on the tv, Get a blank screen with
Unplug it,replug it back an hour later,the tv should set back to the factory setting.
Mar 22, 2010 | Toshiba 22LV505 22 in. LCD TV
Starview super box gone off. I did a system reconfig and rebooted now only terestrial channels remain. Any new codes?
hi there mate i am looking for new codes for ntl 5401 box for Feb 2010,
my box stopped working it says "channel changed , please wait for saving" i dont know what to do? please help
Feb 13, 2010 | StarTech.com StarView IP SV1100KVMIP...
Wash cycle stuck
You can attempt to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main computer for the washer. Sometimes resetting it is all that is required to correct momentary program glitches. If the problem reoccurs following a CCU reset, then you have a legitimate problem. Let me know if you still experience problems. I hope this helps you.
Jul 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
Very odd tv problem
Digital receivers whether external to the TV (converter box, satellite) or built in are digital processors(computers). Just like computers there are times when they freeze up. This can happen if the data stream is corrupted too much to render the picture, but enough signal to lock. The processor attempts to "wait" long enough to gather enough information to begin. Just like computers, these need to be re-booted by turning on or off and sometimes unplugged and plugged in. You have either too low of signal quality or too high of signal strength, which is a problem with digital receivers.
Mar 03, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Channel changing
You can obtian the user manual at http://www.thomsonnetwork.com/EN/Public. It is likely that during intital set up you selected iether VCR or cable box. If so unplug the tv for about 5 minutes. Whenit is turned on again you will get the intial setup screen. Select "nl" when asked if you have a VCR or cable box.
Apr 15, 2007 | GE 46GW947 46" Rear Projection Television
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
