Question about Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
I forgot my child lock which i changed recently, how can i fix this?
How to turn off the child lock on a dryer
This information is from the manual:
Child Lock can be used to prevent your children from changing options on control panel while the dryer is running. When child lock is enabled, all the buttons will be locked and Child Lock glows. To enable Child Lock, Press and Hold OPTION for 3 seconds, A single beep tone is heard and Child Lock is displayed on the status window. To disable child Lock, press and hold OPTION for 3 seconds again.
May 27, 2014 | LG DLE2514 Electric Dryer
Tip
My Miele washing machine is locked.
Recently I received many requests from users in troubles because they could not unlock their washing machine.
I decided to publish a tip illustrating the unlock procedure.
These instructions apply to most Miele front loading washing machines. They will work on all the W4800 series washers.
Instructions on how to set on and off your Miele’s child lock function are also contained in the user manual.
If you attempt to open the door while the Child Lock function is activated you will get the message "Machine locked" and the picture below on display:
If the door lock is locked during the wash cycle, press the pause button, and the door will open.
In order to deactivate the Child Lock:
  • Press and hold the "Heavy Soil" button until the display shows an unlocked pad lock picture and says Ready to Use (hold up to ten seconds, it should be less).
If you want to re-activate the Child Lock:
  • Press and hold the "Heavy Soil" again, until the display shows a locked pad lock picture and says Ready to Use .
The drum door cannot be opened, and the machine may stay locked if one of conditions below is occurring:
  1. The water temperature is more than 55°C (130°F).
  2. The water level is too high.
  3. The Child Lock function is activated.
  4. There is a fault.
If the washer is in one of the above conditions, you will get the machine locking even if child lock is off.
If the door is locked because of a fault, and there is water in the drum, the machine will also lock up.
In that case the door will open only after accessing the drain pump.
The pump service door is opened using a tool stored behind the dispenser drawer.
The tool must be used only after disconnecting power.
I think I will post a detailed procedure on how to fix a blocked drain pump on the next tip.
I hope this tip has helped you to fix your problem.
Goodbye.
on Dec 10, 2009 | Miele W4840 Front Load Washer
Turn off child lock
Setting child lock
The child lock can be set to prevent a programme being accidentally started or a programme in operation being accidentally changed. The child lock function locks all buttons and the programme knob. The child lock can be activated or deactivated by holding down the OPTION and OK buttons simultaneously for 5 seconds.
  • Before programme is started: Appliance cannot be used
  • After programme is started: Programme in operation cannot be changed
The icon appears in the display to indicate that the child safety device is activated. The child safety device is not deactivated once the programme comes to an end. If you want to set a new programme, you must first deactivate the child safety device.
Dado
Below is Child Lock Icon
Mar 11, 2014 | AEG Dryers
LF.com ParentAccount instead
How do I obtain a parent code for my child's leap pad ultra? My child started the ultra before I could set up anything.
Dec 29, 2013 | LeapFrog LeapPad2 Explorer - Green
How to get child lock off of my daughters TV I forgot the code help!
The procedure to unlock the child lock to TVs will differ brand to brand. The general procedure to most TVs are:
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Check this. If you wish to get more details about unlock a TV, check the site linked here. Pull up older posts. Unlock procedure to many popular brand TVs are given in detail.
google.com/+GopakumarGopalan
Nov 25, 2013 | Televison & Video
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
Jun 07, 2013 | Televison & Video
The machine (HVF 344) has stuck on the last minute of the programme and is permanently locked. The child lock has also come on. How can this be solved?
The child lock comes on when you press the child lock key for two second. To remove the child lock, press the same key for 4 seconds, this worked for me when I recently faced the issue!
Feb 15, 2010 | Hotpoint Washing Machines
Child lock flashing and cant use machine
Press and hold the child lock button for at least 3 seconds.
This should reset the washer to normal use.
Plz rate my solution.
Thankyou.
Jan 28, 2009 | Hotpoint Aquarius WD640 Front Load...
Door locks
Regarding the rear door child locks: There is a small lever on the latch side of the door, you can only see it with the door open. Move it to the other position.
Regarding the front door locks: You either have a bad door lock switch, or the power lock solenoids are beginning to fail. To check this, you will need to pull the door panels off, & measure the actual voltage at the solenoids whilst manipulating the lock switch. If you have 12 + VDC, I would suggest replacing the door lock solenoids. Not hard to change, but it IS time consuming. Best left to a dealer. Expect to pay 1 hour per side to change each solenoid.
Sep 28, 2008 | 2004 Toyota ECHO
Child lock
i have no clue
Aug 16, 2008 | 2000 Mercury Mystique
Open Questions:
See all Sharp 27DV-S100 27 in. TV/VCR/DVD Combo Questions
Sharp 27DV-S100 27 in. TV/VCR/DVD Combo Logo
308 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
