Question about HP LaserJet 1020 Printer
I have refilled the cartridge and replace new magnetic roller spring which was broken but there is three black lines (1-2")in size appeared on the right side of the paper from top to bottom. what is the problem
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Replace drum
Posted on Jun 28, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 121 Answers
Please do not use the refilled cartridge. this problem is very common and cause due to the usage of refilled cartridge.
Posted on May 13, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Xerox 6180mfp repeating pattern
They are caused by a component in the toner cartridge.
Originally the cleaning roller was a plain roller, but at some time the 'bean counters' decided they could save a tiny bit of money on each cartridge by using a spiral foam roller instead. The foam also seems to be of a different type, and doesn't age well.
There are two solutions.
1. Replace the cartridge that is producing the coloured squiggle/
2, dismantle an OLD cartridge and if it has a plain (non-spiral) foam roller, swap that (along with it's supports - the new type are a different size).
Either of the above will cure the problem, but a new replacement cartridge may also show the problem in time, as it WILL have the spiral cleaning roller.
Nov 15, 2012 | Xerox Phaser 6180N Laser Printer
PRINT PAGE COMES OUT BLANK AFTER REFILLING
your toner cartridge have a magnet roller.kindly inspect the magnet roller contact spring.it must be broke or bend.replace the mag roller or the contact spring
Aug 30, 2012 | HP Office Equipment & Supplies
Black line appear when printing what is the remendy?
Dirty print out is basically due to cartridge related issues. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is usually located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Moreover, black streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. In this case refilling would not help.
So, it is recommended that you replace the cartridge with a genuine one (not any replacement or refill).
Let me know if any further clarification is required.
Hope it helps! Good Luck!
CreativeTECH
Apr 07, 2011 | Brother MFC 7420 All-In-One Laser Printer
Dear Sir, We have canon xerox machine and our deler ask high cost for spares Ex. OPC - 6000, Tonar - 2350 also he told if you fefile your tonar it damege your machine due to this magnetic rod ,OPC can...
Please let me know the model of your machine. In general, if you are having print quality issues, such as lines dots or black patches, these are usually due to toner cartridge. Genuine Replacement of Toner cartridge is advisable.
However, you may get your toner cartridge re-filled, if its parts are working properly. Cartridge parts like OPC, PCR and magnetic roller can be replaced. Re-filling the toner is always cheaper and costs around 1/4th of the new toner price. So, check for the price of new toner and compare.
I have refilled/ refurbished toners myself and had no issues. Properly re-filled/ refurbished cartridge would NOT cause any damage to the printer. So, you may get your toner refilled by some good professional and it would work fine.
Hope it helps. Let me know if any clarifications are required!
CreativeTECH
Nov 10, 2010 | Xerox Office Equipment & Supplies
After I refilled HP C9700A toner, the magnetic
The only solution is to get a new cartridge. It is not possible to fix this one. Gerrit Jan
Nov 10, 2009 | HP Printer Cartridges (Complete List): ,...
How to refill canon lbp 2900 cartridge
r u a professional??
if so pull out the toner cartridge, unscrew from both side, gently remove the drum & the magnetic mesh roller, be careful that the teflon cover is not affected n there is spring on one side, clean the drum with a soft cotton cloth n keep aside, now clean neatly the container vessel & magnetic-mesh roller using a brush, refill using 'original' refill pack, don't refill till brim, reassemble all, after reassembly, clean all toner spills using soft cotton cloth, blow some heat on the drum using a hair dryer..itz ready
..always hv an expert supervision n always use genuine spare n refills..dis will make ur pc last long....
Oct 27, 2009 | Canon LASER SHOT LBP-2900 Printer
Why are documents printing with a black stripe on right side?
You most likely have a defective cartridge. It is also possible that your Charge and/or Transfer rollers have become defective.
Inspect the cartridge for any band of remaining toner.
You should notice one or two long thin rollers, with the cartridge removed. There will be a dark roller that should appear textured, but not dull. And they may also be a lighter colored roller with no marks.
These are the three common problems that create lines.
Lastly
If the band is mostly straight, it is most likely the cartridge
If the band is wavy or broken in anyway, it is probably the roller(s)
Let us know what you find
Apr 15, 2009 | Dell 3000cn Color Laser Printer
Printer is putting a 1/2 dark black line on the back of the pages
dear friend
looks like problem related with refilled cartridges
are you using refilled cartridges??
if yes then you have to check whether they are leaking or not,
if they are leaking, you have to maintain cleaning level
thats all you can do
thanks
Apr 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Jul 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP LaserJet 1020 Printer Logo
145 people viewed this question
Seeker5211
Seeker5211
