Question about Olympus Mju Tough 8000 Compact Digital Camera
Olympus tough 8000 camera will not turn on but when i charge it the blue light comes on indicating its charged, what do i do? how can i fix this?
rajdeepdutta
  • 2517 Answers
SOURCE: battery charger says charged. camera will not turn on
Hi there i can 't get your these word." camera charger is blue, used battery and new,". Please let me know the battery is new or or its old? If its old then the battery life is finished. Thats why he can't store the power.
Thanks.
Posted on Feb 15, 2010
  • 699 Answers
SOURCE: microSD atchment write protect
The microSD card has no visible write protect tab that you can access: you need to use a Micro-SD to SD/mini-SD adapter that usually comes with your Micro-SD card and use the ON/OFF sliding tab on the adapter to disable or enable the wiite protection on your Micro-SD card: test the access via the adapter card before removing it.
Hope it helps: let me know how you go!
Posted on Mar 07, 2010
lock123
  • 6831 Answers
SOURCE: my olympus camera tough-6010 will
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 30, 2010
  • 3 Answers
SOURCE: My Olympus Tough 8000 charges up to a blue light
i have the same problem too. Mine is mju tough 6010 and it just beeps and switch off. The metal cover in front of the lens won't open. Mine is just 1 month old.
Posted on Sep 14, 2010
SOURCE: How come my battery wont charge on my brand new
We had this same problem...battery indicator light not showing and battery not charging. We found out by accident that if the battery cover is open, it won't charge. So open the battery cover, open the USB cover, shut the battery cover and then plug in the USB as normal. It worked for us, hope it will work for you too.
Posted on Mar 21, 2011
Not charging not turning on/off lens window open. Where can I take this to get it repaired? Old model but camera barely used for 1 year.
Olympus cameras have to be sent back to Olympus themselves which unfortunately they charge for, you can get the address from their website
Mar 24, 2016 | Olympus Mju Tough 8000 Compact Digital...
Olympus Tough-8000 Flash Charging Warning
It could be the capacitor in the flash is defect, but it also could be your battery (batteries) are to low on voltage. ALthough when that happens the camera should switch of.
There could be all other kinds of defects, like oxidation of some contacts or a broken flat cable in the camera, But my guess is the capacitor does not charge to the correct voltage.
Dec 08, 2013 | Olympus Mju Tough 8000 Compact Digital...
Olympus Tough 8000 wont charge
Rechargeable batteries will fail if stored for long periods in a partly charged or in a zero charge state.
You need to replace this battery with a new one.
Sep 27, 2012 | Olympus Stylus Tough 8000 µ Tough 8000...
Olympus tough tg-310 wont let me take pictures
Camera CCD unit fault. Repair cost approx 100$.
Aug 07, 2012 | Olympus TOUGH TG-310 Digital Camera
Camera is new ... only two months old... will not stayed charged, I give it a full charge, put it away but next time I want to use it, the battery is dead.. it is turned off, nothing is on, but battery is...
This could be caused by a short circuit in the camera. As the camera is only two months old, don't recommend that you try fixing this yourself. Instead contact Olympus directly to inquire of warranty repair. If you live in the US, here's the contact info.
Jun 11, 2011 | Olympus Stylus Tough 6010 / ? TOUGH-6010...
Olympus 8000 turns on then turns off again, wont stay on
This happened to mine suddenly as well. I bought a new SD card and presto! All better. I think these things fry SD cards, cause this is my 3rd card.
Apr 24, 2011 | Olympus Mju Tough 8000 Compact Digital...
My Olympus Tough 8000 charges up to a blue light but when I unplug the charger and switch it on, it just beeps multiple times and switches straight off. I've only used it for a week and it's a new,...
Aug 27, 2010 | Olympus Mju Tough 8000 Compact Digital...
My olympus tough 3000 will not turn on, when i turn on orange light at the top just stays on but nothing comes up on the screen
.' i have a problem with my camera olympus u tough 3000, when i turn it on..it is okay but after 4 or 5 seconds it will automatically shut off.. help me please... if what should i do.. what is the best solution to fix this..
Aug 05, 2010 | Olympus Mju Tough 8000 Compact Digital...
Battery charger says charged. camera will not turn on
Thanks.
Feb 15, 2010 | Olympus Mju Tough 8000 Compact Digital...
Olympus Mju Tough 8000 Compact Digital Camera Logo
614 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
