Question about Samsung SGH-A877 Impression Cell Phone
Touch screen is malfunctioning - Samsung SGH-A877 Impression Cell Phone
  • 30 Answers
You may need a new digitizer they can be purchased on ebay
Posted on May 13, 2010
Touch screen is off about 1" frome the top cant use menu or any other touch screen button on the bottom
Posted on Aug 24, 2010
I have a problem for bizhub 350 touch screen malfunction totally not working....please help me to solve this problem...thanks..
you must execute touchpanel adjustment.In the right side on copier in neighborough to USB connector located one plastic door.Pull out the plastic and press a little microswitch.After press the switch wait to appaire a * symbol and press 3.In the blue yield introduction 00000000 and press END.On the touchscreen appaire screen adjustment.
Dec 11, 2013 | Minolta bizhub 350 Black and White Copier
Touch screen not responding
Try calibrating the screen via your settings menu in the touch input selection, at the bottom you'll see calibrate touch screen.
Nov 25, 2013 | Nokia E7 (16 GB) Smartphone
LA PANTALLA TACTIL NO FUNCIONA
google translated
TOUCH SCREEN NOT WORKING
DO NOT OPERATE AS TOUCH PANTLLA
Touchscreen computers and handheld devices are the newest wave of technological gadgets as of 2010. While these devices function impressively, they can malfunction just like any other technical device. Troubleshooting the touchscreen is simple and often will correct any issues.
Identify how the screen is behaving. A touchscreen will malfunction in one of two areas--sensitivity or position. If you touch the screen and the cursor is not centered on your finger, this is a position error and requires recalibration of the screen. If you touch the screen and it does not register your touch without pressing hard, this is a sensitivity error. If you touch the screen and nothing happens, this can be a sensitivity error or a malfunctioning screen. Calibrate the screen. For all main errors, calibrating the screen will correct the issue. Every device has a different method of calibration but can usually be found under a "Tools" or "Diagnostics" menu option. Reload the device. For handheld devices, remove the battery and let the device rest for no less than five minutes. For computer or computer system devices, power down the device, disconnect the touchscreen device from the computer and remove any power cords to it. Allow the device to rest for five minutes. Reattach the device or reinstall the battery and power up the device. If issues persist, reload the software for the device. For handheld devices, do a full wipe of the device and return it to factory specifications. For add-on devices to a computer or computer system, uninstall the device and reinstall the drivers. If reloading, registering or calibrating the device does not work, consult the manufacturer for possible warranty replacement options.
Feb 26, 2013 | Computers & Internet
My Samsung Omnia's touch screen somehow malfunctioned. It just started pressing itself Randomly, more especially the bottom left corner of the screen, Phone button when on home screen. What might
does your phone have the unresponsive touch screen? if it occurs, try this. Take your fingernail and run it along the screen and the plastic housing. Push hard as you do it, and it will free up the screen. This has happened to me as well. and my phone's working now. this was a solution given by mephisto250 on youtube. :)
Nov 01, 2012 | Samsung SGH-i900 Omnia Unlocked Cellular...
The touch screen problems.malfunction.touch screen lost function even touch.model no exad kw avx-800
if the screen gets wet it will corrode at the data wire and not pick up a signal
Jun 28, 2011 | JVC KW-AVX800 CD Player
On my samsung eternity, the touch screen wont work. i can do anything but touch the screen it wont work! how do i fix it?
Hey buddy,
The issue can be with the flex of your phone that connects to the touch screen. The connection might be loose thereby disabling the touch screen functionality.
The best solution is to take it to Samsung repair shop and get it repaired by an expert. They are well experienced with touch phone firmware malfunction issues.
Thanks!
Dec 14, 2010 | Samsung Eternity Cell Phone
The touch screen does not work
When the touch screen on your phone is malfunctioning,it indicates that the inner touch pad embedded with the LCD screen is bad hence the touch screen will not respond to any touch whatsoever.
However,the only solution is to disassemble the phone and replace the LCD screen of your phone to restore it back to a normal working condition.
Hope you are technically inclined,Good luck!!
Aug 14, 2010 | Cell Phones
Touch screen not working
First thing you have mentioned you are using Nokia 70 which dont have the touch screen feature....
If your phone is not recognising the stylus completely, it means your touch screen is malfunctioning or it is broken from inside... you need to get the touchscreen changed.... i will not suggest you to change it your self as touch screen is very deligated....
Jul 09, 2009 | Nokia N70 Cellular Phone
Motorokr touch screen malfunction
choose that master reset on setting wizard,,
dont do again anything with that screen calibaration,,,
Dec 20, 2008 | Motorola Mobility ROKR E6 Smartphone
Minolta dialta di250
The C0048 error code not exist.Malfunction resetting procedure:
Turn OFF,then ON the power switch or open and close the side cover for all malfunctions except C05XX codes.
Use Trouble reset of the Initial screen to reset all malfunctions.
To right side the touch panel(screen display)near display contrast button exist a little hole (reset switch).Insert a hairpin to touch the switch.
Enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screen being displayed.Touch TROUBLE RESET,and EXIT to go back to the basic screen.
May 07, 2008 | Minolta DiALTA Di520 Laser Printer
Samsung SGH-A877 Impression Cell Phone Logo
295 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
