I regularly use Disk Cleanup, as you should, to help clean some of the 'junk' out of my system and free up space. However, there are a couple things listed here I do not understand and am not sure I should 'mess with'. Let me say first that I have used up 20gb of my hard drive. I know not much, but I just recently did a new install. In Disk Cleanup I am comfortable deleting everything, but for two areas. They are: 1) System queued Windows Error Reporting Files: 988mb 2) TWO listings for: Per user archived Windows Error Reporting Files: 78.3gb each. That's GIGAbytes, not megabytes! I am wondering if I can safely delete #1. I think I can. But I don't see how I can delete #2. In the first place, I have only 'used up' 20 gb on my hard drive, so what is this anyway?? I'd like a definition of each and the green light or not to delete the files in each one. Thanks.
  • 192 Answers
1. Queued Windows Error files are files that are stored so that if you contact Microsoft for support it can be read or provided to them for diagnostics. They contain the error codes and information for boot errors or application errors.. THEY ARE OK TO DELETE IF SYSTEM IS RUNNING FINE.
2. Archived Windows Error Reporting are just accumulated reports from the first type of file above. YOU CAN DELETE THEM AS WELL BY CHECKING ALL THE BOXES IN DISK CLEANUP AND SAYING DELETE ALL.
Posted on Jun 02, 2010
Usb speed 900kbps
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Watch the demo (1:00) this should speed up your computer
Mar 12, 2013 | Computers & Internet
Tip
Freeing up extra hard drive space
Are you out of hard drive space but can't find anything you'd like to remove from your computer?
Maybe you should try doing a Disk Cleanup.
Disk Cleanup will remove unnecessary files from your hard drive and if it hasn't been done on your system previously, free up a lot of space in the process.
To do a Disk Cleanup:
1) Go to My Computer.
2) Right click on your C drive.
3) Click Properties.
4) Click the "Disk Cleanup" button next to the visual representation of your hard drive space.
Disk Cleanup will calculate how much space you can free up and
what should be removed.
5) Under "Files to delete" select any files you don't want or need.
Generally all of the tabs can be selected and none of the files are
needed by your system. Below on "Description" you can view what
the files listed under each tab are for.
6) Once you have selected all of the files you want to remove click OK.
7) Disk Cleanup will remove the files from your system.
Disk Cleanup is complete.
on Dec 21, 2009 | Computers & Internet
Why is my o/s drive red instead of green
Maybe you need to remove some junk from your HDD, try freeware CCLEANER at : http://www.filehippo.com/download_ccleaner/ Download, install ,run and remove the junk to free uo disk space. UNINSTALL unnessary programs. Open Disk Cleanup in Accessories, System Tools, Disk Cleanup, More Options, System Restore and Shadow Copies, Cleanup. Sounds like you need a larger HDD or a external HDD to put Music, Movies, etc. on.
Feb 07, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Hp netbook is running so very slow
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Jan 17, 2013 | HP Mini 1000 Netbook
Hello - the computer is running really slow but has 97% disc space available. Sometimes it is so slow to log onto a search engine that it will 'time out'. Any ideas on how to speed it up. Have ...
Hi emr1518...
Here are a couple of things that will help speed up your computer.
1...Disk Cleanup...Start>All Programs>Accessories>System Tools>Disk Cleanup...this will clear your hard drive of things that you no longer need.
2...Disk Defragmenter...Start>All Programs>Accessories>System Tools>Disk Defragmenter...this will put your used files back where they belong so your computer will run faster.
After you run those programs...then go to the following webpage and download,install and run Microsoft Safety Scanner and it is FREE at this webpage...
http://www.microsoft.com/security/scanner/en-ca/default.aspx
Then go to the following webpage and download,install and run SuperAntiSpyware also for FREE, and it will remove any spyware,malware,etc from your computer...
http://www.superantispyware.com/download.html
Please take time to rate me thumbs up
Sep 20, 2011 | Dell Vostro 200 PC Desktop
My computer is running slow and would like to know how to fix it.
Install Ccleaner, Download from:- http://www.piriform.com/ccleaner
Than clean your pc
Install Antivirus (If not) due to viruses too your pc may run slow
Apr 25, 2011 | Computers & Internet
Too slow
Try: http://www.piriform.com/ccleaner
Mar 09, 2011 | Computers & Internet
Acer 4720z. sluggish performance
The first thing is always make sure that you dont got any trojans, viruses, worms, or spyware on your computer.
www.avast.com Offers a HOME EDITION free Virus scanner,
Download this
Install
Remove your computer from the internet, and do a FULL SYSTEM SCAN
Step 2, would be just cleaning out the files and cookies on your computer though internet explorer.
In Internet explorer click on "TOOLS"
Then "Internet Options"
under "Browsing History, under the general tab click "Delete".
Please rate me and give me feed back, ty for your time and I hope this works for you.
Sep 27, 2009 | Acer Aspire 4720 Notebook
Low disk space on recovery H disk
Have you emptied the internet files? Go to tools on the toolbar, the go to options and empty temporary internet files. Run disk defragment from the start button when you are done.
Jan 17, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
272 people viewed this question
David Payne
David Payne
