Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
My drive wont connect to my computer. when i plug it in all i get is a blinking light on the drive. and no icon pops up on my screen. and when i try to go to my computer to try and open the drive, it says my computer folder is not responding. whats wrong?
  • Jose Velazquez
    Jose Velazquez May 13, 2010
    I just need to ask a few questions:
    How old is the computer?
    What operating system are you running?
    Is it a laptop or a desktop?
    Have you tried any other USB ports.
I WANNA ASK A QUESTION MY ... WERE I CONNECT THE USB CONNECTOR TO MY DRIVE WELL IT BROKE AND I RARELY USE AND I STILL HAVE THE PLASTIC ON IT SINCE I BOUGHT IT WILL IT COVER IT FOR THE WARRANTY THAT I GOT AT WAL MART
Posted on May 18, 2010
  • 666 Answers
Right click my computer<manage><disk management>look for external drive and check of file systems for ntfs in none found, format it for the file systems restoration.
Posted on May 13, 2010
Lonovo wont boot
If it seems like the computer is up and running except the screen is black, then try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If the computer is just not booting all the way or at all try the steps below:
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 13, 2012 | Computers & Internet
Black screen on neo netbook
Does it boot and it seems like everything is running except the screen is black? If so try this:
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 20, 2012 | Computers & Internet
Blank screen
Did it boot all the way? Do you hear the fan running, disk drive spinning? If it sounds like it booted but the display is black, try this:
When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 14, 2012 | Computers & Internet
Inspiron 1501 wont start
Does it look like it is running with the exception of the screen being black?
Does it ever post anything on the screen when you hit the power button?
Beep tones and blinking lights tells thetechnicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lightscontinuous.
Apr 06, 2012 | Dell Inspiron 1501 Laptop
Icon won't appear on desktop.
It is possible that your USB flash drive is dead.
The other solution is to try it on some other USB port of your PC (if you used front panel USB ports now try it on the back panel).
If it also wont work, try to connect it to some other PC
If it works with an other PC, your USB ports are dead
You can try going to device manager, and to unintall USBs and reinstalling them
Nov 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Device cannot work
Try cleaning your computer for spyware and viruses. Also try cleaning your registry out using a utility. Do your USB ports on the computer work with any other devices? Try using different USB ports and make sure theres no faults in you device list with the USB drivers. Let me know more info. What OS are you using. By unplugging it without safely removing is most dangerous to Flash memory but it's definitely possible to damage a hard drive by doing so. You might have corrupted your drive. Hope this helps.
Jul 25, 2009 | SimpleTech SimpleDrive 160 GB External USB...
Visioneer 9220 wont work
Dirty USB port. Try another Port. One of the 4 contacts is not making connection.
Mar 16, 2009 | Visioneer OneTouch 9220 USB Color Scanner
Memorex external usb floppy disk-drive does not appear or functio
As I understand it the computer recognizes the floppy drive.
Can you read other discs, write to them etc? If not drive is bad
If you can read other discs then your floppy disk is bad
Jan 23, 2009 | Memorex Computers & Internet
160 GB Lacie external drive is not reading on my laptop.
i suggest you buy laptop adapter and connect it to a PC so that you can view your file from My computer.note:the computer will see it as drive D
Jan 15, 2008 | Computers & Internet
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
732 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
