Question about Yamaha RX-V2600 Receiver
I have a yamaha RX-V 2500 receiver that won't turn on.The front display stated to check the speakers, now the unit won't turn on at all you here is a clicking sound coming from the left rear of the unit. Please some one tell me what is wring with my receiver.
    Brigadier General:
  • 8,546 Answers
Have you checked the speaker connections as requested? How about disconnecting all speakers and seeing what happens? If it works, you have a shorted speaker or wire.
Posted on May 15, 2010
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
How do i turn on all 5 speakers for my yamaha rx-v463 receiver
To turn on all 5 speakers from your reciever you will want to press the audio selct button on either your remote or on the front of the unit itself. This will scroll through the different sound fields and the easiest thing to do is to look at the front right of the recievers display. While scrolling through you will see the speaker icons and all 5 channels should light up when your on the correct soundfield. Dolby digital 5.1 and all channel stereo are common soundfields that use all the speakers. It is important to remember that your surround speakers are only intended to reproduce sound effects, and not full range audio like the fronts. Of course, if it is your desire you can definately override this.
Hope this helped,
Thanks
Jan 03, 2011 | Yamaha RX-V463 Receiver
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
Dec 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha RX-V365 Receiver I have no sound coming from my front R & L speaker terminals, the sub, rear L & R are all fine. Independently or factory set-up nothing comes out? Can anyone suggest what...
The front channels have a separate protection circuit from the rears and sub sections. It is possible that the unit i is not turning on the fronts. Without seeing the unit and testing some parts, I can't state for sure either the problem or solution. Can you provide more history? Did this just happen out of the blue?
Dan
Aug 23, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
My Yamaha RX-V390 receiver when volume turns up it turns off
Does it display something on LCD? Maybe you have connected speakers with wrong impendance and the receiver is overheating.
Check the impedance of speakers, it should be at least 6 ohm. Also check the receiver manual if it has settings for impendace (6 or 8 ohm).
Feb 01, 2010 | Yamaha RX-V390 Receiver
Yamaha RX-V563 AV receiver. Not getting sound out of the Front B
check in the manula setup from the Menu button and press enter it should show front speaker enabled
Apr 03, 2009 | Yamaha RX-V563 Receiver
Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Mar 02, 2009 | Yamaha RX-V1400 Receiver
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha RX-V2600 Receiver Logo
452 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
